Shello007 Posted June 23, 2013 Share Posted June 23, 2013 Has anyone else have these issues? I'm driving , then A/P just goes blank and reset. Connection to OBDII recepatacle is pretty secure. Also, Wouldn't it be great if they could update software that would allow it to shut off when ignition is shut off? My 'screen saver' ( Turning Cogs) are burnt into my screen. Suggestions anyone? Link to comment Share on other sites More sharing options...
chimera Posted June 23, 2013 Share Posted June 23, 2013 v1 or v2? From what I've read on here v1 had alot of intermittent issues like this. Edit: not that this necessarily helps answer your question, but it may help narrow down your search. Link to comment Share on other sites More sharing options...
Shello007 Posted June 23, 2013 Author Share Posted June 23, 2013 Sorry. I should have mention...it's a version 2. Sent from my SCH-I535 using Tapatalk 2 Link to comment Share on other sites More sharing options...
BlazeRex Posted June 24, 2013 Share Posted June 24, 2013 Ask Cobb themselves. Customer support from them is top notch. Link to comment Share on other sites More sharing options...
acumenhokie Posted June 24, 2013 Share Posted June 24, 2013 I have an AP3 and not had this issue. In regards to not turning off I contacted Cobb support about it a month ago and there's no way other than unplugging (officially). I had my installer hard wire it in so now it turns on and off with the acc position. Link to comment Share on other sites More sharing options...
COBB Tuning Posted June 26, 2013 Share Posted June 26, 2013 Do you have the V2 Accesport that uses a silver dongle connecting to the OBD port or our updated V2b Accessport which uses a 1-piece cable? Are you able to shake any of the connections and cause the Accessport to reset? Marshall@COBB Link to comment Share on other sites More sharing options...
Shello007 Posted June 27, 2013 Author Share Posted June 27, 2013 I have the second one you described. The cable is pretty secured. I have it mounted next to instrument cluster. While cruising on highway, at times, without bumps it will simply reset, go back to home screen. Link to comment Share on other sites More sharing options...
ScoobyGT15 Posted August 9, 2013 Share Posted August 9, 2013 Mine does this too. I tried wiggling the wire to see if thats what is causing it but its not. Did you ever contact Cobb, or get your problem resolved? Wondering if theres an easy solution?? Link to comment Share on other sites More sharing options...
Shello007 Posted August 9, 2013 Author Share Posted August 9, 2013 I haven't contacted them. Since I've adjusted the connection, and re routed the wire away from left foot rest, it seems to have eliminated this problem. Sent from my SCH-I535 using Tapatalk 2 Link to comment Share on other sites More sharing options...
Tkingsley03 Posted August 10, 2013 Share Posted August 10, 2013 You may of just been bumping the cord enough to break the connection. I'd say roll with it unless it acts up again. Could be a short in the cable Link to comment Share on other sites More sharing options...
