aweak_reception Posted May 28, 2013 Share Posted May 28, 2013 Hey all - long time lurker, can't even begin to put in to words how much I've learned through this forum. Sorry if this is long as hell... I've had my 07 LGT 5MT for going on 2 years now. I've decided that it's a keeper so it's time to actually have some fun with it. Car is at 80k bone stock never modified, Looking to go Stage 2: What i'm sure about: Open source base tune from Infamous (or anyone know where I can find a safe base map free edition until I can get it in to a tuner)? CNT Catted DP Factory CBE Considering: Grimmspeed cross pipe -OR- Invidia Up-pipe I realize that my 07 is already catless Up pipe, just wondering what would give me better results of the two? Would I expect to see much from swapping the up pipe? I do not plan on upgrading the CBE at this time, doesn't seem entirely necessary now and I'd like to keep it somewhat quiet. I do plan on upgrading the FMIC at a later time, but I need to throw some cash at suspension bushings for now so it will have to wait. This leads me to another question; will my stock FMIC and BPV be able to handle this (my assumption is stage 2 will put me at 16-17)? Anyone have a similar set up? Thanks in advance. Link to comment Share on other sites More sharing options...
Moddiction Posted May 29, 2013 Share Posted May 29, 2013 I'd leave the stock uppipe in there. Already catless so I wouldn't waste the money replacing it. The stock TMIC should hold 16 psi I would think but once you go a bit higher over time it will start to split it seems. You can get the "Bullet Proof" kit to prevent the end tanks from separating. You don't have a FMIC= front mount intercooler if stock. It is a TMIC= top mount intercooler. Check with your tuner. Many like to tune with the Grimmspeed ebcs. Tuner I am going to also suggests replacing the stock BPV with a Forge one to prevent boost leaks. WWW.MODDICTION.COM Moddiction Stainless steel and Titanium shift knobs. Drivetrain, suspension, brakes, exhaust, cooling, fuel, gauges+MUCH more! Link to comment Share on other sites More sharing options...
05LEGASTI Posted May 29, 2013 Share Posted May 29, 2013 To my understanding the 07 does have a catless up pipe. Your factory top mount should have no issue holding 17 psi. But over time they have a tendency to split at the seams. I have an 05, so I did a catless up pipe and catless down pipe with at first stock cat back. Let me tell u how horrible that sounded. In my opinion it was just flat out bad. You may have better luck with a catted down pipe though. I'm running the Cobb stage 2 sence 71k, now at 109k and no issues at all. Link to comment Share on other sites More sharing options...
AZP Installs Posted May 29, 2013 Share Posted May 29, 2013 Having done a lot of installs on subies over the years and specifically Legacies... UP- You are fine with the OEM one unless you are going for big power where the OEM won't hold the pressure. Not an issue in this case. The OEM is catless already. DP- I would consider going with the Invidia Catted DP or Cobb Catted DP. Price is a little more but the build quality and quality control (flanges lining up, hangers lining up, etc) are much better on the Invidia and Cobb. I would consider going with an upgraded DW65 upgraded fuel pump and grimmspeed or cobb EBCS as well. Soon after you will likely need a TMIC and Injectors to get an optimal stage 2 tune out of it. We've seen lots of stage 2 pro-tuned cars max out the injectors. -Mike Paisan AZP's First Private Track Event, June 19 at NJMP Thunderbolt $315 including Classroom and Mentor! http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/145749898/original.jpg http://www.pbase.com/paisan/image/133406601.jpg http://www.whiteline.com.au/images/logos/perf1.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
aweak_reception Posted May 31, 2013 Author Share Posted May 31, 2013 Thanks for the input guys. As of now I'm rolling with a stage 2 OTS map from Infamous (hopefully they get get some issues sorted out on their end, looks like they're backed up from what I've learned AFTER placing an order). I also found a decent deal on an Invidia catted DP as opposed to the CNT and am going to proceed with the bulletproof mod as suggested. I think I will also see how the stock BPV works out for now. This car is not a DD so if i break something it's not too much of an emergency... I'll let y'all know how it works out You don't have a FMIC= front mount intercooler if stock. It is a TMIC= top mount intercooler. I was trying so hard to nail all of my acronyms on my first post, lol. Link to comment Share on other sites More sharing options...
DeltaNu1142 Posted May 31, 2013 Share Posted May 31, 2013 My BPV was fine through stage 2. Some will tell you it will work well into stage 3 pressures. Mine did not. YMMV. I have a Grimmspeed EBCS I could sell if you need one. Tits mcgee Link to comment Share on other sites More sharing options...
stuck686 Posted May 31, 2013 Share Posted May 31, 2013 u dont need an EBCS lol i would get a grimmspeed 3" to 2.5" adapter for ur stock cbe Link to comment Share on other sites More sharing options...
