phesa1005 Posted May 27, 2013 Share Posted May 27, 2013 I've been getting 15.9 mpg and babying the car also all stock. Did all tune up and still the same. I don't know what's wrong with the car or am I pumping bad gas. Link to comment Share on other sites More sharing options...
silen7guardian Posted May 27, 2013 Share Posted May 27, 2013 Check/clean/replace injectors, MAF sensor, O2 sensors, vacuum leaks, PCV valve, air filter, etc. Could any number of things, or it could be all of them. I'm sure there's other things to check that I'm forgetting... Especially if yours is an earlier LGT, I'd start by cleaning the MAF sensor (MAF sensor cleaner is about $3) and replacing the O2 Sensors, as they'll likely need to be replaced anyway. Link to comment Share on other sites More sharing options...
ALX2987 Posted May 27, 2013 Share Posted May 27, 2013 Has I been stock it's whole life? If it was modified previously there may still be a tune that's not for a stock setup. Does it drive/boost smoothly? Link to comment Share on other sites More sharing options...
phesa1005 Posted May 27, 2013 Author Share Posted May 27, 2013 It's stock never modified Link to comment Share on other sites More sharing options...
Burock Posted May 27, 2013 Share Posted May 27, 2013 That's about what my Legacy GT got as stock w/ my lead foot. Once I went to Stage 2+, my average is about 19.5mpg. If I drive very conservatively, I can get low to mid 20s, but it takes the fun out of owning this car. I usually am having the most fun at 10 mpg average. Link to comment Share on other sites More sharing options...
phesa1005 Posted May 27, 2013 Author Share Posted May 27, 2013 I did all the tune up and check everything. So I guess I'll stage two and get a tune lol Link to comment Share on other sites More sharing options...
lee07 Posted May 27, 2013 Share Posted May 27, 2013 That's what I get on E85 with mixed driving, maybe a bit more, 16-17mpg. Stock I was getting 19-21 mixed driving Using 91 or 93? Link to comment Share on other sites More sharing options...
MAP Posted May 27, 2013 Share Posted May 27, 2013 16 to 17mpg is what i normally get on my normal commutte (20 mi each way)but its almost all street. On highway i can get close to 30 mpg if i take it easy. The car passed california smog check easily. All stock. Link to comment Share on other sites More sharing options...
MisterE22 Posted May 28, 2013 Share Posted May 28, 2013 5MT or 5EAT? Link to comment Share on other sites More sharing options...
phesa1005 Posted May 28, 2013 Author Share Posted May 28, 2013 Its a 5eat!! Something is wrong with my car then. Link to comment Share on other sites More sharing options...
careercadaver Posted May 28, 2013 Share Posted May 28, 2013 Mine did this as the o2 sensor was on its way out... Link to comment Share on other sites More sharing options...
EJ25subie05 Posted May 28, 2013 Share Posted May 28, 2013 how many miles do you put on a full tank of gas? are those the computer readings or did you calculate those #'s? Link to comment Share on other sites More sharing options...
famaya26 Posted May 28, 2013 Share Posted May 28, 2013 This is what my 05 averages when driving to work through stop and go traffic. Link to comment Share on other sites More sharing options...
MAP Posted May 28, 2013 Share Posted May 28, 2013 Phesa1005, What kind of driving do you do? (I.e. percentage of street vs highway) Low tire air pressure can significantly affect mpg with these low profile tires. As someone mentioned, the upstream sensor may need changing as well. Link to comment Share on other sites More sharing options...
chimera Posted May 28, 2013 Share Posted May 28, 2013 Mines stock 5eat (tiptronic) and ranges from 15 (thrashing it everywhere) to 18 (mix of smooth and relatively hard driving) to 24mpg (nana driving) My pick will be faulty O2 sensor Link to comment Share on other sites More sharing options...
iNVAR Posted May 28, 2013 Share Posted May 28, 2013 in stop and go traffic, that is about right. so it depends. don't jump to the conclusion just yet that something is wrong. see if you can find a tactrix or vagcom cable and hook it up and pull a learningview. if you don't know how to do that, search. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted May 28, 2013 Share Posted May 28, 2013 Before spending money, I would go for a ride 100% highway, and see how your mileage is. I'd shoot for 100 miles maybe and see how it goes. Link to comment Share on other sites More sharing options...
phesa1005 Posted May 28, 2013 Author Share Posted May 28, 2013 I got about 100k miles and I usually put 16 gal and getting 250 to a tank with mix driving Link to comment Share on other sites More sharing options...
famaya26 Posted May 28, 2013 Share Posted May 28, 2013 I got 350 Average when I drove to So Cal Link to comment Share on other sites More sharing options...
mwiener2 Posted May 28, 2013 Share Posted May 28, 2013 I call broken TMIC My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Jefferson Posted May 28, 2013 Share Posted May 28, 2013 I have no idea if the Legacy Gt has a coolant temp sensor, but I would think it would. On the 1st gen SS there is and it has alot to do with the performance of the engine, mileage included. Might be worth checking into. I know there is alot of difference between the obd1 cars and the ones now, but... Jeff Link to comment Share on other sites More sharing options...
mwiener2 Posted May 29, 2013 Share Posted May 29, 2013 His coolant gauge would read funny too if that was it. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Jefferson Posted May 29, 2013 Share Posted May 29, 2013 On the SS there are 2 different coolant temp sensors, one for the gauge and one for the ecu. Like I say I have no idea how they did it on the GT. It would be worth looking into I think. Jeff Link to comment Share on other sites More sharing options...
mwiener2 Posted May 30, 2013 Share Posted May 30, 2013 It's not an SS, it's not his problem. If you don't know what you are talking about (you don't) don't offer advice, because it isn't helpful and you are polluting the internet. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
iNVAR Posted May 30, 2013 Share Posted May 30, 2013 Remember that time you thought timing on our cars would keep advancing by itself and that a knock sensor is a microphone? Link to comment Share on other sites More sharing options...
