blankdeluxe Posted May 14, 2013 Share Posted May 14, 2013 Good deal? Or too good to be true? http://www.ebay.com/itm/97-Subaru-WRX-STi-Engine-5-Speed-JDM-EJ20T-Dohc-2-0L-Motor-Gearbox-EJ20-Turbo-/261212902988?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cd180964c&vxp=mtr Link to comment Share on other sites More sharing options...
Zues Marine Posted May 14, 2013 Share Posted May 14, 2013 doesnt look like it comes with any wiring? or did i miss it? Link to comment Share on other sites More sharing options...
blankdeluxe Posted May 14, 2013 Author Share Posted May 14, 2013 doesnt look like it comes with any wiring? or did i miss it? You are correct. I missed that. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted May 14, 2013 Share Posted May 14, 2013 If you have an EJ22, the only things that are useful to you on that engine are the heads, intake/exhaust manifolds, & turbo assembly w/various sensors & vacuum lines. Link to comment Share on other sites More sharing options...
blankdeluxe Posted May 16, 2013 Author Share Posted May 16, 2013 doesnt look like it comes with any wiring? or did i miss it? If you have an EJ22, the only things that are useful to you on that engine are the heads, intake/exhaust manifolds, & turbo assembly w/various sensors & vacuum lines. I have a EJ22 but I'm looking to find as complete motor/tranny combo and do a STI swap in it. I would rather keep my motor as it is and sell it off to offset some of the price of the new motor. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted May 16, 2013 Share Posted May 16, 2013 The EJ22 block will be more useful to you than the EJ20 block as it has 20% more displacement yet has the same internal components as the EJ20 block you're going to buy. The EJ20 heads will fit on the EJ22 just fine & everything will work together. If anything, you could sell the EJ22 heads & EJ20 block for as much as you'd get for the whole EJ22 assembly. You'd still be doing the STi swap but with 20% more potential. Link to comment Share on other sites More sharing options...
blankdeluxe Posted May 16, 2013 Author Share Posted May 16, 2013 The EJ22 block will be more useful to you than the EJ20 block as it has 20% more displacement yet has the same internal components as the EJ20 block you're going to buy. The EJ20 heads will fit on the EJ22 just fine & everything will work together. If anything, you could sell the EJ22 heads & EJ20 block for as much as you'd get for the whole EJ22 assembly. You'd still be doing the STi swap but with 20% more potential. Ah, I evidently have a butt load more reading to do on what I want to build here. Any pros of keeping the ej22 over going with the ej257? Link to comment Share on other sites More sharing options...
Zues Marine Posted May 16, 2013 Share Posted May 16, 2013 gas is cheaper^ Link to comment Share on other sites More sharing options...
blankdeluxe Posted May 16, 2013 Author Share Posted May 16, 2013 gas is cheaper^ I'm not worried about the gas prices. Less then ten miles to work and I have a handful of other cars if I need to drive something else for a while. How bad of mileage are you talking with the 2.5? Link to comment Share on other sites More sharing options...
Zues Marine Posted May 16, 2013 Share Posted May 16, 2013 i meant more of different octane requirements and their ~10¢ price differences the ej257 requires premium but will still get you good mileage, 22-28ish is my guess what you should consider doing is buying a wrecked wrx or sti and swapping all the motor/interior stuff from there, that way you have absolutely everything necessary, and a huge plus is the fact you wont have to merge your harness' which is extremely time consuming and articulative, plus you'll have all the suspension stuff and can sell off whatever you wont end up needing and/or wont fit Link to comment Share on other sites More sharing options...
pleaidestar Posted May 16, 2013 Share Posted May 16, 2013 There's one....^..lol..yeah, that motor has a bit going for it besides its toughness, the castings are thick and workable if you want to pnp like a mad man. With a tough block you can go n/a crazy or boost it to a comfy level with the stock rods and pistons. Make it better for boosting with a 22t block and internals. Personally I want to raise compression to like 10.5~11.0-1, and rev to 7~8 (pipe dream), but I f I win the lotto its going to happen ..finding the right information is really the hardest part for that, I don't know of anyone doing high compression builds with ej motors. Link to comment Share on other sites More sharing options...
Zues Marine Posted May 16, 2013 Share Posted May 16, 2013 doesnt the 2.5/2.2 frankenmotor bring compression up to around that range? not too spendy if you go that route, but youll stay n/a.. PnP with the cams setup on the torque grind... ohhh man, fun. Link to comment Share on other sites More sharing options...
pleaidestar Posted May 16, 2013 Share Posted May 16, 2013 I thought that build lowers compression to around 8 to 1, dohcej22e1 would be the guy to ask about that. The ej18 cams are supposed to have a pretty sharp grind to them to make up for displacement all the way around. Yet another thing to find out. Link to comment Share on other sites More sharing options...
blankdeluxe Posted May 16, 2013 Author Share Posted May 16, 2013 i meant more of different octane requirements and their ~10¢ price differences the ej257 requires premium but will still get you good mileage, 22-28ish is my guess what you should consider doing is buying a wrecked wrx or sti and swapping all the motor/interior stuff from there, that way you have absolutely everything necessary, and a huge plus is the fact you wont have to merge your harness' which is extremely time consuming and articulative, plus you'll have all the suspension stuff and can sell off whatever you wont end up needing and/or wont fit I can handle buying premium gas if thats what it takes for a sweet car. But by the sound of things, keeping the 2.2 and building from there might be the best option for me. I have considered the WRX/STI builder from a crashed chassis but they are basically impossible to get at a good price here in Colorado. Everyone and their mom wants them so they go for a premium. And I have suspension covered already so I don't need any of those parts now. I guess I will just work on all my cosmetic stuff for now and then work on rebuilding my bank account for doing a massive drive-train overhaul this winter or next spring. Link to comment Share on other sites More sharing options...
blankdeluxe Posted May 16, 2013 Author Share Posted May 16, 2013 Thanks for all the help and heads up on this everyone. Link to comment Share on other sites More sharing options...
pleaidestar Posted May 16, 2013 Share Posted May 16, 2013 Good luck man.. Dyslexia strikes again zues, frankenmotor stays sohc. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted May 16, 2013 Share Posted May 16, 2013 Ah, I evidently have a butt load more reading to do on what I want to build here. Any pros of keeping the ej22 over going with the ej257? If you want the extra 30% in power/tq, then it is the way to go but the block is semi-reinforced & is also super strong like the EJ22 blocks are. EJ22+: Strong (thick cylinder walls). Shorter stroke (79mm crank means higher rpms). Near equally sized rod journals 52mm (EJ257 rods can be used in an EJ22 block). 99-01 EJ22 blocks are Phase 2 design, tougher than the already strong EJ22E. Compatible with ALL DOHC/SOHC EJ20 & 97-99 EJ25D cylinder heads. EJ257+: Strong (semi-reinforced cylinder walls). Larger cylinder bore (30% extra displacement & potential for power). Phase 2 block is stronger than that of Phase 1. It's up to you to choose what you would want it for. Both blocks tend to help make TQ>HP, so both would be good daily drivers. I'd not choose a 22/25 hybrid simply due to the fact that the EJ22 heads simply do not breathe well enough without PnP to justify a very small hp increase/giant low-end increase but with head work, the 22/25 hybrid is a formidable engine. Link to comment Share on other sites More sharing options...
