DJBRANDER Posted May 1, 2013 Share Posted May 1, 2013 So when I purchased my car the clutch was kinda slipping when I had alot of people or stuff in it, it's progressively gotten worse. So it's time to replace it. Now I've done some research and the OEM one is a decent price, but if I want to go with an upgrade which one do you think I should choose? Does anyone have any suggestions to ones you have installed or ones that you've previously had that you like? Link to comment Share on other sites More sharing options...
Sludgeroo Posted May 1, 2013 Share Posted May 1, 2013 Im in the same boat. Bump for some help. Link to comment Share on other sites More sharing options...
Kennyfvholla Posted May 1, 2013 Share Posted May 1, 2013 Exedy KSB04 It's perfect. Search it on here and you'll see all the nice things I've said about it. It's $150 and MUCH MUCH better than OEM. Link to comment Share on other sites More sharing options...
Zues Marine Posted May 1, 2013 Share Posted May 1, 2013 ^this. Link to comment Share on other sites More sharing options...
Sludgeroo Posted May 1, 2013 Share Posted May 1, 2013 Is there an upgrade for the cable on the cable clutches? Like some sort of thicker braided cable or is it just a good idea to replace with OEM?. I feel like that would be alot stiffer once it stretches.. I hate how soft my clutch feels, makes me wonder if the person before me was a person who sits on the clutch at red lights, because the pressure plate feels weaker than it should.. Link to comment Share on other sites More sharing options...
Zues Marine Posted May 1, 2013 Share Posted May 1, 2013 you probably have air in your lines Link to comment Share on other sites More sharing options...
Sludgeroo Posted May 1, 2013 Share Posted May 1, 2013 No like my clutch fork and throw out bearing are attached to a pull cable. Ill post a pic in a min. Link to comment Share on other sites More sharing options...
DJBRANDER Posted May 2, 2013 Author Share Posted May 2, 2013 Exedy KSB04 It's perfect. Search it on here and you'll see all the nice things I've said about it. It's $150 and MUCH MUCH better than OEM. Nice! thats how much an OEM one costs, I think I'll do that. Link to comment Share on other sites More sharing options...
Kennyfvholla Posted May 2, 2013 Share Posted May 2, 2013 Sludge, you shouldn't have a cable clutch..... But maybe yours is one of those weird ones. Being a Brighton and all.... Honestly, cable clutches feel very different from hydraulic clutches. There may be nothin lg wrong. You have a 2.2 so your pressure plate might be really light as well. I dont know for sure. Link to comment Share on other sites More sharing options...
Sludgeroo Posted May 2, 2013 Share Posted May 2, 2013 Yea I wouldn't pull wool over yer guy's eyes. The black cable on the backside of the "cable stop" goes into the firewall.. and to my pedal ass'y. http://s4.postimg.org/g1gfvfefh/2013_05_02_07_44_17_674.jpg Link to comment Share on other sites More sharing options...
DJBRANDER Posted May 2, 2013 Author Share Posted May 2, 2013 Yeah mines a brighton too, I also have a cable clutch. Link to comment Share on other sites More sharing options...
DJBRANDER Posted May 2, 2013 Author Share Posted May 2, 2013 Exedy KSB04 It's perfect. Search it on here and you'll see all the nice things I've said about it. It's $150 and MUCH MUCH better than OEM. why does it come up as an 05 Legacy clutch? Will it fit? https://www.google.com/#hl=en&tbm=shop&sclient=psy-ab&q=Exedy+KSB04&oq=Exedy+KSB04&gs_l=serp.3..0.73824.73824.2.74702.1.1.0.0.0.0.133.133.0j1.1.0...0.0...1c.1.12.psy-ab.uoXZmFBooT4&pbx=1&bav=on.2,or.r_qf.&bvm=bv.45960087,d.aWM&fp=220a55c2c69df914&biw=1280&bih=832 Link to comment Share on other sites More sharing options...
Zues Marine Posted May 2, 2013 Share Posted May 2, 2013 type your year in http://www.carid.com/1999-subaru-legacy-transmission-drivetrain/exedy-oe-replacement-clutch-kit-7058649.html?%22cagpspn=pla%22&gclid=CNaxodD397YCFep7QgoduHoAIg Link to comment Share on other sites More sharing options...
DJBRANDER Posted May 2, 2013 Author Share Posted May 2, 2013 now since I have a 2.2, can I still run the 2.5 Clutch? Or will I need the flywheel as well? Link to comment Share on other sites More sharing options...
Kennyfvholla Posted May 2, 2013 Share Posted May 2, 2013 why does it come up as an 05 Legacy clutch? Will it fit? https://www.google.com/#hl=en&tbm=shop&sclient=psy-ab&q=Exedy+KSB04&oq=Exedy+KSB04&gs_l=serp.3..0.73824.73824.2.74702.1.1.0.0.0.0.133.133.0j1.1.0...0.0...1c.1.12.psy-ab.uoXZmFBooT4&pbx=1&bav=on.2,or.r_qf.&bvm=bv.45960087,d.aWM&fp=220a55c2c69df914&biw=1280&bih=832 Because it's made to fit a LOT of Subaru's, including that one. now since I have a 2.2, can I still run the 2.5 Clutch? Or will I need the flywheel as well? Crud. I forgot you guys had 2.2's Yeah, you'd need a 2.5 flywheel as well. It won't work with the 2.2's If you went Exedy, you'd have to use this one with the 2.2 flywheel: 15010 EDIT: BUT.... Now I'm seeing that there are no size differences between the two clutches.... I wonder if the pressure plate is different. I am not quite sure what the 2.5/2.2 differences are. Link to comment Share on other sites More sharing options...
DJBRANDER Posted May 2, 2013 Author Share Posted May 2, 2013 so after talking to some people and looking on NASIOC, it looks like we will need the 2.5 N/A flywheel to make it work. BUT after searching around http://www.partsgeek.com/gbproducts/DC/394-05057360.html?utm_source=google&utm_medium=ff&utm_content=DN&utm_campaign=PartsGeek+Google+Base&utm_term=1990-2000+Subaru+Legacy+Flywheel+Sachs+NFW6605+90-00+Subaru+Flywheel+1993+1997&fp=pp&gbm=a&gclid=CK-l-cCj-LYCFdNzMgodKHgAyg This flywheel is for the 98 N/A 2.2 and 2.5. So I'm very confused. I think that if it's an N/A clutch it will fit, but not a turbo one. Link to comment Share on other sites More sharing options...
DJBRANDER Posted May 2, 2013 Author Share Posted May 2, 2013 http://www.streetsideauto.com/p/exedy-15010/?utm_source=googlepepla&utm_medium=adword&utm_content=pla&gclid=CLaY7Y6k-LYCFfFcMgodPXEAyQ BUT why bother? Because this clutch set is $144 anyway. And it says for the 2.2 Link to comment Share on other sites More sharing options...
Kennyfvholla Posted May 2, 2013 Share Posted May 2, 2013 Turbo cars have a "pull" style hydraulic system and pressure plate. It's completely different. Let me check the OE part numbers for the 2.2 / 2.5 flywheel and get back to you. The 15010 should work just fine. The KSB04 is just a little bit more performance oriented. The pressure plate has a higher rating. Link to comment Share on other sites More sharing options...
Sludgeroo Posted May 2, 2013 Share Posted May 2, 2013 I want performance lol Link to comment Share on other sites More sharing options...
DJBRANDER Posted May 3, 2013 Author Share Posted May 3, 2013 Turbo cars have a "pull" style hydraulic system and pressure plate. It's completely different. Let me check the OE part numbers for the 2.2 / 2.5 flywheel and get back to you. The 15010 should work just fine. The KSB04 is just a little bit more performance oriented. The pressure plate has a higher rating. Thanks for all the help! I really appreciate it! Link to comment Share on other sites More sharing options...
Sludgeroo Posted May 3, 2013 Share Posted May 3, 2013 I still am kinda confused... Link to comment Share on other sites More sharing options...
DJBRANDER Posted May 3, 2013 Author Share Posted May 3, 2013 I still am kinda confused... well we have the part # for an exedy clutch for the 2.2 so we dont have to bother with the 2.5. http://www.streetsideauto.com/p/exedy-15010/?utm_source=googlepepla&utm_medium=adword&utm_content=pla&gclid=CJDzmZm2-rYCFRN0MgodXkoAbw this is what we need Link to comment Share on other sites More sharing options...
Sludgeroo Posted May 3, 2013 Share Posted May 3, 2013 Is this still better than OEM? I just hate how lame this pedal feels. Link to comment Share on other sites More sharing options...
DJBRANDER Posted May 10, 2013 Author Share Posted May 10, 2013 so I picked up the Exedy stage 1 clutch and brand spankin new flywheel. Resurfacing the flywheel is $50 and a brand new one is $60. I think the $10 difference is worth my time to drive to a NAPA and wait a few hours. Just one less movie I can take my gf too, its ok though she rarely puts out after a date anyway. So I'll be installing it later next week and I'll let you guys know how it goes. My friend is letting me borrow his shop out by me to make this alot less painful. Also my strut tower bars are ordered so they should be coming in soon too. Since the back of the wagon is so flippy floppy I thought it was a decent investment. THEN I will refinish my wheels after new tires are ordered. Link to comment Share on other sites More sharing options...
Idaho subaru Posted October 27, 2013 Share Posted October 27, 2013 So, assuming you've had the clutch in for awhile now, any updates on performance? Link to comment Share on other sites More sharing options...
