MaStaMooN Posted April 29, 2013 Share Posted April 29, 2013 Hi, Well looks like my passenger side valve cover gasket is leaking. And looking around here it seems pretty common. Shop wants 200 bucks installed to do the job. http://legacygt.com/forums/attachment.php?attachmentid=150183&stc=1&d=1367253040 But while I was under there, I noticed this pipe was shot.. can anybody tell me what it is? http://legacygt.com/forums/attachment.php?attachmentid=150182&stc=1&d=1367253007 Thanks! Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
MaStaMooN Posted April 29, 2013 Author Share Posted April 29, 2013 Dealership wants 500 bucks to swap out 1 valve cover gasket!! -yikes! Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted April 29, 2013 Moderators Share Posted April 29, 2013 It says $200 installed--seems pretty good to me. Is that your oil cross over pipe? "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
MaStaMooN Posted April 29, 2013 Author Share Posted April 29, 2013 It says $200 installed--seems pretty good to me. Is that your oil cross over pipe? Is that what it is? Oil huh.. guess I should replace that asap! Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
apexi Posted April 29, 2013 Share Posted April 29, 2013 I called three dealers who all quoted me between $530-$550 for both valve cover gaskets and 4 spark plug tube seals, I wonder if they were quoting you for both sides? Or if it is just that much harder to do on a LGT, that they charge you a lot more. $200 sounds like a good deal though, I would let the shop do it for that much. Link to comment Share on other sites More sharing options...
FJuan Posted April 29, 2013 Share Posted April 29, 2013 Yes, that pipe is the oil cooler crossover pipe. It goes from the water pump to the oil cooler, which is what your oil filter is attached to. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
MaStaMooN Posted April 30, 2013 Author Share Posted April 30, 2013 Yes, that pipe is the oil cooler crossover pipe. It goes from the water pump to the oil cooler, which is what your oil filter is attached to. So it carries coolant or oil? Sent from my SCH-I535 using Tapatalk 2 Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
mwiener2 Posted April 30, 2013 Share Posted April 30, 2013 Coolant Crossover pipe from oil cooler to water pump. Contains coolant, not oil. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Captain Ned Posted April 30, 2013 Share Posted April 30, 2013 That one isn't going to be carrying much of anything in the near future. Link to comment Share on other sites More sharing options...
apexi Posted April 30, 2013 Share Posted April 30, 2013 Came across these threads that may be of interest to you as well http://legacygt.com/forums/showthread.php/water-pump-oil-cooler-hardline-p-n-194067.html http://legacygt.com/forums/showthread.php/if-you-dont-want-get-towed-off-road-replace-your-174696.html?t=174696 Link to comment Share on other sites More sharing options...
AZP Installs Posted April 30, 2013 Share Posted April 30, 2013 We quoted him $230 per side (parts and labor w/ spark plug tubes). We would also be able to replace that crossover tube for you as well. -Mike Paisan http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/145749898/original.jpg http://www.pbase.com/paisan/image/133406601.jpg http://www.whiteline.com.au/images/logos/perf1.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
Captain Ned Posted April 30, 2013 Share Posted April 30, 2013 @ MaStaMooN: NJ, so you're in the salt belt (VT here), and the pipe sits right over an exhaust pipe. Dousing things in high-test salt brine then making them very hot is a quick path to rot. Should probably take a hint from the marine world and wrap a zinc sacrificial anode around the replacement. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 30, 2013 Share Posted April 30, 2013 We quoted him $230 per side (parts and labor w/ spark plug tubes). We would also be able to replace that crossover tube for you as well. -Mike Paisan http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/145749898/original.jpg http://www.pbase.com/paisan/image/133406601.jpg http://www.whiteline.com.au/images/logos/perf1.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs "Race Tested, Enthusiast Approved!" OP, you need to get your to these guy's. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
MaStaMooN Posted April 30, 2013 Author Share Posted April 30, 2013 Really want to do it myself for 60ish dollars in parts.. just doesn't look like a good time. lol Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
Max Capacity Posted April 30, 2013 Share Posted April 30, 2013 remember there is a mess to clean up after you do the work yourself. Your paying these guy's to take care of all the mess and give you back a ready to drive car with a cooling system that has been burped and a VC that no longer leaks. Rey at AZP and I are on email right now, I'm getting ready to place an order with him. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Charged Posted May 1, 2013 Share Posted May 1, 2013 Yeah, when I did my TB the other weekend I found a really rusty coolant pipe as well. Luckily there was enough good metal left that I was able to sand it down, give it a coat of POR15, and spray some paint on it. It must be a salt magnet even with the splash panel in place. Link to comment Share on other sites More sharing options...
Charged Posted May 1, 2013 Share Posted May 1, 2013 BTW, how old is your crank pulley? Looks pretty rusty too...might be worth replacing if it's original. I had mine go at around 100K and from what I've heard that's not uncommon. Link to comment Share on other sites More sharing options...
MaStaMooN Posted May 1, 2013 Author Share Posted May 1, 2013 BTW, how old is your crank pulley? Looks pretty rusty too...might be worth replacing if it's original. I had mine go at around 100K and from what I've heard that's not uncommon. Yeah thats on the plan when I do the timing belt in about 10k miles.. hoping it lasts till then.. car is coming up on 100k and starting to need this and that, my bank account is feeling the pain. Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
AZP Installs Posted May 2, 2013 Share Posted May 2, 2013 Yeah thats on the plan when I do the timing belt in about 10k miles.. hoping it lasts till then.. car is coming up on 100k and starting to need this and that, my bank account is feeling the pain. Why not hold off and do it all together? -mike Link to comment Share on other sites More sharing options...
MaStaMooN Posted May 2, 2013 Author Share Posted May 2, 2013 Why not hold off and do it all together? -mike Tired of the smell, smoke and wasting expensive oil right now. And need to spread these costs out a bit. Sent from my SCH-I535 using Tapatalk 2 Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
AZP Installs Posted May 2, 2013 Share Posted May 2, 2013 Tired of the smell, smoke and wasting expensive oil right now. And need to spread these costs out a bit. Sent from my SCH-I535 using Tapatalk 2 Gotcha. Well let us know if we can help. -Mike Paisan AZP's First Private Track Event, June 19 at NJMP Thunderbolt $315 including Classroom and Mentor! http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/145749898/original.jpg http://www.pbase.com/paisan/image/133406601.jpg http://www.whiteline.com.au/images/logos/perf1.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
06legsleeper Posted May 3, 2013 Share Posted May 3, 2013 well worth what they quoted you for sure ... . my passanger side leaks a tiny bit .. i did my up pipe a few weeks ago, and while i was there i figured id check the bolts on the vc..... turns out 2 were loose, odd.. but i snuged them up . so far so good my next mission is doing my clutch and fw .... clutch was ify when i bought the car and ive been stage 2 since the first 3 weeks i bought it so . smfw and stage 2 clutch on the way ... well if you like working on your own car (which i do) then just tackle it yourself . if you rather not deal with it then the quote you got is a great price Link to comment Share on other sites More sharing options...
