1055 Posted July 18, 2013 Share Posted July 18, 2013 Missing tooth will absolutely cause a no start issue.. I think on a phase I 22 motor the crank is spark and cam is fuel. Link to comment Share on other sites More sharing options...
Dragon-Wagon Posted July 18, 2013 Share Posted July 18, 2013 Sub'ed! Link to comment Share on other sites More sharing options...
twisty Posted July 19, 2013 Share Posted July 19, 2013 I was looking at my pictures i took of the timing today, and realized that when i removed the crank pulley i broke off one of the teeth which i think is how the crank sensor gets it's readings. The timing belt was still off on this pic, i corrected afterward. yup, thats broken. had the same issue on mine. well, it wasnt a broken tooth, but the PO had cranked down the sensor so much it was hitting the teeth, and took the front half of all of them off. had constant misfire codes, even tho it ran pretty damn well. luckily that part is only 35 at the dealer. probably way cheaper online or used. Link to comment Share on other sites More sharing options...
scoobydoo73 Posted July 21, 2013 Author Share Posted July 21, 2013 Ordered one today on ebay. 36 shipped. Link to comment Share on other sites More sharing options...
scoobydoo73 Posted August 1, 2013 Author Share Posted August 1, 2013 Got the pulley in today, but it has six timing marks, i could swear the old one only had three?? Link to comment Share on other sites More sharing options...
scoobydoo73 Posted August 4, 2013 Author Share Posted August 4, 2013 So there were two teeth missing on the old pulley. Installed new one, it runs baby!! Sounds like a rally car.... Link to comment Share on other sites More sharing options...
1055 Posted August 4, 2013 Share Posted August 4, 2013 So there were two teeth missing on the old pulley. Installed new one, it runs baby!! Sounds like a rally car.... Haha.. loud as all hell right? Enjoy it man.. I miss it. Kick myself for letting it go, want to make another one. Link to comment Share on other sites More sharing options...
scoobydoo73 Posted August 14, 2013 Author Share Posted August 14, 2013 I made a trip to pick and pull today. Things I really wanted but didn't acquire...windshield, i bought one of the pull knife's from harbor freight, figured i would rock a windshield out. Did not happen, popped a big crack in the first one and never got the second to budge, so i'm leaving that one to a pro, it's like 200 bucks installed. Oil pan, yea didn't want to have to pull a motor to get to the back oil pan bolts, i'll eventually just order one and deal the headache of install later. What i did get was a new timing cover set, winshield trim pieces and lots of clips, second gen seatbelt to convert from the auto seatbelts, and found an underseat sub. Link to comment Share on other sites More sharing options...
1055 Posted August 14, 2013 Share Posted August 14, 2013 I should have had the windshield replaced before you took it. No fault glass replacement for free in ct... Link to comment Share on other sites More sharing options...
scoobydoo73 Posted August 26, 2013 Author Share Posted August 26, 2013 Cleaned the headlights before http://i299.photobucket.com/albums/mm311/scoobydoo731/cruck/2013-08-26111232_zps4d2544ed.jpg after http://i299.photobucket.com/albums/mm311/scoobydoo731/cruck/2013-08-26111226_zps232a84c6.jpg http://i299.photobucket.com/albums/mm311/scoobydoo731/cruck/2013-08-26145926_zpsaf1277ac.jpg Also got the new winshield and put on the side trim pieces http://i299.photobucket.com/albums/mm311/scoobydoo731/cruck/2013-08-26145932_zps99c79a76.jpg Link to comment Share on other sites More sharing options...
scoobydoo73 Posted August 26, 2013 Author Share Posted August 26, 2013 Picked up some new corner lights at pick and pull http://i299.photobucket.com/albums/mm311/scoobydoo731/cruck/2013-08-26183544_zpsfa8bba2b.jpg http://i299.photobucket.com/albums/mm311/scoobydoo731/cruck/2013-08-26183536_zps55a16852.jpg Link to comment Share on other sites More sharing options...
scoobydoo73 Posted August 30, 2013 Author Share Posted August 30, 2013 I was replacing the side markers as well, passenger went in pretty easy, driver side is at this point right now. http://i299.photobucket.com/albums/mm311/scoobydoo731/cruck/2013-08-27143335_zps397de42c.jpg Link to comment Share on other sites More sharing options...
scoobydoo73 Posted September 10, 2013 Author Share Posted September 10, 2013 So i had all the lights fixed, car running good, drove it over to merchant's to drop it off for inspection. I knew it wouldn't pass but it would give me 15 days of being able to drive it. Car runs great over to the shop, they are able to drive it in the bay, got to leave and it won't start. Push it out into the parking lot, i could start it but had to keep the throttle open and it ran like crap especially at lower rpm's. I could get it to roll in first gear, but as soon as the 2 shift was made it was dead. Now i have to figure out what happened now. I just want to drive this thing. Link to comment Share on other sites More sharing options...
1055 Posted September 10, 2013 Share Posted September 10, 2013 Check out the MAF sensor. I had a similiar issue with it doing the exact same thing.. would bog and stall repeatedly until I cleaned it. That filter may be due for a cleaning..... Link to comment Share on other sites More sharing options...
scoobydoo73 Posted September 15, 2013 Author Share Posted September 15, 2013 So I had to retime the engine today. I'm still trying to figure out what happened to the timing during a state inspection where they would have driven the car 30ft at the most. I also ordered about 150 bucks worth of stuff on ebay and rock auto. Link to comment Share on other sites More sharing options...
1055 Posted September 15, 2013 Share Posted September 15, 2013 So I had to retime the engine today. I'm still trying to figure out what happened to the timing during a state inspection where they would have driven the car 30ft at the most. I also ordered about 150 bucks worth of stuff on ebay and rock auto. Wait.. WHAT? It jumped time?? Link to comment Share on other sites More sharing options...
scoobydoo73 Posted September 18, 2013 Author Share Posted September 18, 2013 It's very suspicious but i can't imagine someone taking the time to deliberately mess up the timing at a state inspection. I drove it over to the shop, wouldn't run when i went to pick it up. Last weekend I set the timing again, it runs great again. I did find a piece of rubber inside the timing cover, likely just a piece of the timing cover gasket fell off. I don't think that would have caused it. Drove it about 45 or so miles today to the subaru meet, people defenitely crowded around. Link to comment Share on other sites More sharing options...
1055 Posted September 18, 2013 Share Posted September 18, 2013 I'm kicking myself for letting it go man.. I miss it. Was such a blast to operate.. Link to comment Share on other sites More sharing options...
scoobydoo73 Posted October 5, 2013 Author Share Posted October 5, 2013 Well I think i'm going to have to get rid of this thing. It's running good and drives good, but I can't drive it due to the state inspections here. I'm just too frustrated to even try and get it to pass. So if anyone is interested, it's got some good new parts and fresh brakes, i just need something different right now, prefereably something i can get antique tags for. Link to comment Share on other sites More sharing options...
1055 Posted October 5, 2013 Share Posted October 5, 2013 Well I think i'm going to have to get rid of this thing. It's running good and drives good, but I can't drive it due to the state inspections here. I'm just too frustrated to even try and get it to pass. So if anyone is interested, it's got some good new parts and fresh brakes, i just need something different right now, prefereably something i can get antique tags for. Why wont it pass? And it doesn't qualify for antique down there? Link to comment Share on other sites More sharing options...
scoobydoo73 Posted October 7, 2013 Author Share Posted October 7, 2013 It's 25 years for antique down here. Ridicolous stuff like safety glass, rear window defroster, stuff that i don't want to get into spending a lot of money on. Link to comment Share on other sites More sharing options...
1055 Posted October 7, 2013 Share Posted October 7, 2013 It's 25 years for antique down here. Ridicolous stuff like safety glass, rear window defroster, stuff that i don't want to get into spending a lot of money on. Rear window defroster? Does it even snow down there? And it has to be actual glass instead of plexi? Link to comment Share on other sites More sharing options...
tacoornot Posted October 10, 2013 Share Posted October 10, 2013 i kind of want it back.... lol. Link to comment Share on other sites More sharing options...
1055 Posted October 10, 2013 Share Posted October 10, 2013 i kind of want it back.... lol. Dooo eeettttt!! Link to comment Share on other sites More sharing options...
scoobydoo73 Posted October 12, 2013 Author Share Posted October 12, 2013 It's sitting right now but I'm hanging on to it until the right person might want it back. I got it running good, got the brakes working right, and swapped in a manual seatbelt on the drivers side, plus the new driver's fender. I want to keep it, but logically I know i souldn't. For now i just bought a forester this week for a daily. Link to comment Share on other sites More sharing options...
