chessyB Posted April 24, 2013 Share Posted April 24, 2013 So I lowered my car in the proses my friend "who is quite stupid" broke my CV shaft. I replaced that, I hit the pin out from the top so I took the intake piping off. I hooked it all back up now it WONT IDLE I'm lost at what it could be. Link to comment Share on other sites More sharing options...
EJ25subie05 Posted April 24, 2013 Share Posted April 24, 2013 what intake piping? the intake itself? is the maf plugged in? just go through everything you have touched Link to comment Share on other sites More sharing options...
chessyB Posted April 24, 2013 Author Share Posted April 24, 2013 I have the 2.5 box I just unhooked it from the maf and the throttle body, then I was able to get to the roll pin. Link to comment Share on other sites More sharing options...
Zues Marine Posted April 24, 2013 Share Posted April 24, 2013 im willing to bet one of your hoses is loose Link to comment Share on other sites More sharing options...
chessyB Posted April 24, 2013 Author Share Posted April 24, 2013 I made all the clamps tight, I made sure everything was sealed, its still doing it. I did make a temporary fix I tighten the throttle cable so that it idles at like 1500 rpm now but it dose not die. still anyone one have idea on what it really could be Link to comment Share on other sites More sharing options...
Zues Marine Posted April 24, 2013 Share Posted April 24, 2013 and you've got both smaller hoses coming off the heads going into the 'T' on the pipe and the fat one hooked up closest to the MAF? Link to comment Share on other sites More sharing options...
Sludgeroo Posted April 24, 2013 Share Posted April 24, 2013 There isn't much that could have been messed with with that intake system. There are 3 hoses. 2 from each valve cover and one from the crankcase. Also why I never work on cars before work! Link to comment Share on other sites More sharing options...
pleaidestar Posted April 24, 2013 Share Posted April 24, 2013 Sounds like the iacv, car won't idle at all when that is disconnected from the tube, check and make sure it isn't kinked or plugged... is a large tube that has a lot of schmutz going through it. Link to comment Share on other sites More sharing options...
pleaidestar Posted April 24, 2013 Share Posted April 24, 2013 Hope I don't sound like capt. Obvious, but not to much can do that when you r+r the intake, hope you get it though bub. Link to comment Share on other sites More sharing options...
Sludgeroo Posted April 24, 2013 Share Posted April 24, 2013 ^He said schmutz! Link to comment Share on other sites More sharing options...
johnegg Posted April 24, 2013 Share Posted April 24, 2013 there is a large hose, about 1 inch in diameter from the IAC on the passenger side intake that connects to the very bottom of the black plastic intake plenum which connects the air filter box and the air box at the throttle body. it is easy to miss because the connection point is absolutely underneath the plenum. that is your problem connect it. Link to comment Share on other sites More sharing options...
chessyB Posted April 25, 2013 Author Share Posted April 25, 2013 On mine I have two houses, one that is on the bottom of the pipe going from the box to the MAF, the other is on the back of the box it has the two houses going from the valve covers into one house then into the box. By box I don't mean the place the air filter goes I mean the big one that comes right off the throttle body. Link to comment Share on other sites More sharing options...
chessyB Posted April 25, 2013 Author Share Posted April 25, 2013 here are some pics I took just now I have them both hooked up. Sorry I know they suck just took them really quick with my phone Link to comment Share on other sites More sharing options...
monkeyposeur Posted April 25, 2013 Share Posted April 25, 2013 My bet is on the MAF. Link to comment Share on other sites More sharing options...
BAC5.2 Posted April 25, 2013 Share Posted April 25, 2013 Your first mistake was hitting the roll pin out from the top. Next time don't do that. Also, make sure the coolant temp sensor and TPS sensors are still plugged in. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
