matts_pats Posted October 27, 2015 Share Posted October 27, 2015 ^^^ thats what I did, although i didnt even lift the car just turned the wheel. Others here have said they couldnt get it done this way .... I only changed the bulbs though..not a retrofit, isnt that you are doing. Link to comment Share on other sites More sharing options...
ChrisCrash Posted October 27, 2015 Share Posted October 27, 2015 ^^^ thats what I did, although i didnt even lift the car just turned the wheel. Others here have said they couldnt get it done this way .... I only changed the bulbs though..not a retrofit, isnt that you are doing. I was just trying to offer an alternative to pulling off the bumper for changing lights. Turning the wheel worked fine for me as well with stock wheels but I have larger wheels on now so its either learn contortionism, pop off the bumper, or lift it a bit. Many kudos to JLGT for showing how to remove the bumper though, once you do it a few times it can be just as fast as jacking up the car a bit. Link to comment Share on other sites More sharing options...
s2baru Posted October 27, 2015 Share Posted October 27, 2015 Don't remove the front bumper like i did....smh Link to comment Share on other sites More sharing options...
BBPeik Posted October 27, 2015 Share Posted October 27, 2015 I just jack it up and pull the fender liner as the others did. Works great My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
mr_pacman Posted October 28, 2015 Share Posted October 28, 2015 I tried doing it a few times just by peeling back the fender liner. My biggest challenge was the twist cap for the headlight to get access to the bulb. Once I got it off, I couldn't get it back on as the tabs are not aligned and I was doing it blind. Next time, I'll pull the bumper and just take out the entire until so I can make sure the twist cap is on properly. Link to comment Share on other sites More sharing options...
boxer3.6R Posted October 29, 2015 Share Posted October 29, 2015 You can only do the fender liner if you have skinny girly forearms. I can barely get my forearm up there. It takes me less time to drop the bumper than try to get my manly arm to change the bulb. Link to comment Share on other sites More sharing options...
ChrisCrash Posted October 29, 2015 Share Posted October 29, 2015 ^^ Link to comment Share on other sites More sharing options...
GhiaAddict Posted June 6, 2016 Share Posted June 6, 2016 Thanks for the search feature that led me to this thread. Removed bumper and swapped headlight bulbs so much easier than before. Unfortunately after putting everything back did I notice one of my LED bulbs is not working on one of the two sides. Grrrrrr... At least I already planned on replacing with Black housing Outback lamps so I will just wait until that purchase before fixing. Link to comment Share on other sites More sharing options...
Humble Rumble Posted August 16, 2017 Share Posted August 16, 2017 Bumping this because it's a super useful resource and Photobucket completely f*cked it. Tried getting around it, but JLGT, could you re-host and re-post your images on Imgur? They're currently all broken thanks to Photobucket. 2012 Legacy 3.6R Build Thread 5th Gen Legacy BM/BR Body Kit Compendium Thread Link to comment Share on other sites More sharing options...
Timothy.B Posted August 17, 2017 Share Posted August 17, 2017 I went in blind because the photobuckets were missing. I figured it out though. Hardest part honestly was getting the darn bumper back on. Timothy.B's 2011 LEGACY 3.6R Link to comment Share on other sites More sharing options...
GTEASER Posted August 17, 2017 Share Posted August 17, 2017 I had the same issue with the rear bumper when I did the Ecohitch, easy to remove but PITA to get back on. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Zee199969 Posted August 17, 2017 Share Posted August 17, 2017 The first time was the most difficult, but after a couple of attempts it goes on pretty easy. Sent from my ONEPLUS A5000 using Tapatalk My "Build" Link to comment Share on other sites More sharing options...
mr_pacman Posted August 19, 2017 Share Posted August 19, 2017 Hey everyone. I saved the pictures for the bumper removal and the headlight removal that were on this thread and the other thread. It's fairly rudimentary as I simply copy and pasted the the posts into word and then saved as a PDF. However, it should do the trick. I'm not really up to date on how to share things over the internet. I have a Google Drive. Is there a way to share those files without giving the entire internet access to my google drive? Otherwise perhaps I could email them to someone and they can share them? James Link to comment Share on other sites More sharing options...
FLlegacy Posted August 19, 2017 Share Posted August 19, 2017 Hey everyone. I saved the pictures for the bumper removal and the headlight removal that were on this thread and the other thread. It's fairly rudimentary as I simply copy and pasted the the posts into word and then saved as a PDF. However, it should do the trick. I'm not really up to date on how to share things over the internet. I have a Google Drive. Is there a way to share those files without giving the entire internet access to my google drive? Otherwise perhaps I could email them to someone and they can share them? JamesYou can upload pdfs to the site with the advanced options. Sent from my SAMSUNG-SM-G920A using Tapatalk Link to comment Share on other sites More sharing options...
JLGT Posted August 19, 2017 Author Share Posted August 19, 2017 I will fix it soon. Link to comment Share on other sites More sharing options...
JLGT Posted August 19, 2017 Author Share Posted August 19, 2017 Done Link to comment Share on other sites More sharing options...
