Unknown1329 Posted April 15, 2013 Share Posted April 15, 2013 Hello my 99 LGT is having a problem with the wheel shaking around 55-60 and around 70 I feel like I loose all control of the car. The biggest thing that is different from most shaking issues is mine only happens sometimes. On my way to work it'll do it and on the way home it won't it happens at all different times. I don't know where to look for an answer. I just got four new tires 2 months ago and an alignment at same time. It is on off problem and the intensity of the shaking changes. Sometimes it's a little sometimes I have to stop because I can't control the car. Any ideas would be helpful. I travel the highway at 70 to and from work daily and really need to figure out how to stop this. Thanks in advance, Spencer Link to comment Share on other sites More sharing options...
Stang70Fastback Posted April 15, 2013 Share Posted April 15, 2013 It could be anything from poorly balanced tire (though that wouldn't usually be an intermittent problem) to a blown strut allowing the wheel to bounce around. Picture when you get a crappy shopping cart at the supermarket and if you go too fast one of the wheels starts shuddering violently and you have to slow down a lot to get it to stop. Link to comment Share on other sites More sharing options...
Sludgeroo Posted April 15, 2013 Share Posted April 15, 2013 That strut issue is probably it or it can also be a tie rod end. Jack the car up and grab ahold of the tire and try to turn it as if you were turning the steering wheel. There should be 0 play if any at all. Sometimes if its on the edge of alignment the tie rod pin can shake inside the inner eyelet. When its intermittent it because of the various surfaces you drive on. Check the inside of the tires to see if they are scrubbing. Looking at how tires wear can tell a whole hell of a lot of what's going on in your front end components. Link to comment Share on other sites More sharing options...
Sludgeroo Posted April 15, 2013 Share Posted April 15, 2013 But just to make sure you have a good baseline, (not that you wouldn't) make sure all 4 are balanced and are all at the SAME psi. Link to comment Share on other sites More sharing options...
Stang70Fastback Posted April 15, 2013 Share Posted April 15, 2013 Yeah, as Sludgeroo said, anything that allows play could cause this. Could even be a bad wheel bearing. Link to comment Share on other sites More sharing options...
Sludgeroo Posted April 15, 2013 Share Posted April 15, 2013 That too! Link to comment Share on other sites More sharing options...
Unknown1329 Posted April 15, 2013 Author Share Posted April 15, 2013 Thank you for the responses. I will check into what you recommended as soon as I get the time Link to comment Share on other sites More sharing options...
snederhiser Posted April 15, 2013 Share Posted April 15, 2013 Hello; Go back to the tire shop that did the alignment and tell them your problems. You could have lost a weight, faulty tire, or loose tie rod end. This should cost you about zero dollars, maybe a small fee involved if something else is discovered. Steven. Link to comment Share on other sites More sharing options...
Fire Away Posted April 18, 2013 Share Posted April 18, 2013 I am having the exact same issue. Around 60mph and up the steering wheel shakes. It smooths out and then starts again. All tires are at the same psi. I know I need an alignment because the PO did a wheel bearing and didn't properly align the rear alignment when he was done. So, the car pulls slightly to the left. My first thought was the alignment and possibly bad wheel balance. Link to comment Share on other sites More sharing options...
Fire Away Posted April 22, 2013 Share Posted April 22, 2013 Mine ended up being wheels/tires that were off balance. Hopefully OP's fix will be as easy as mine! Link to comment Share on other sites More sharing options...
JJay03 Posted April 22, 2013 Share Posted April 22, 2013 I am having the exact same issue. Around 60mph and up the steering wheel shakes. It smooths out and then starts again. All tires are at the same psi. I know I need an alignment because the PO did a wheel bearing and didn't properly align the rear alignment when he was done. So, the car pulls slightly to the left. My first thought was the alignment and possibly bad wheel balance. Doing a rear bearing shouldnt mess up the alignment. The rear strut to knuckle bolts do not have an adjustment. The adjustment is done where the lateral links connect to the subframe. I have a slight wobble also I think mine might be some junk that I need to clean off inside the rim. Link to comment Share on other sites More sharing options...
spooln30 Posted April 23, 2013 Share Posted April 23, 2013 Does it only do it at certain speeds? Link to comment Share on other sites More sharing options...
JJay03 Posted April 23, 2013 Share Posted April 23, 2013 Does it only do it at certain speeds? Highway speeds and sometimes it is not noticeable. Link to comment Share on other sites More sharing options...
wannarally89 Posted July 24, 2013 Share Posted July 24, 2013 sorry to bump an old thread, but has anyone had their issue fixed? what was the cause/ solution? I am also getting some wobble around 65-75 highway, but it is intermittent... and light to be shed onto the situation? Link to comment Share on other sites More sharing options...
pleaidestar Posted July 24, 2013 Share Posted July 24, 2013 I replaced my ball joints about a month ago along with my rotors and pads,they were wobbling around while braking above 50mph and had a warped rotor in the front. Wobbling went away but I have a clunk when I go over a speed bump (outer tie rods popped) fml. My struts and end links are two years old. Link to comment Share on other sites More sharing options...
Zues Marine Posted July 25, 2013 Share Posted July 25, 2013 off balance tires would be the first thing id check with what you described, 'wannarally89' Link to comment Share on other sites More sharing options...
