candt Posted April 8, 2013 Share Posted April 8, 2013 I am looking for the white plastic clip that clips to the ABS lines that are coming out of the ABS module. It is on the passenger side of the engine compartment, and it is a clip that attaches the four lines to the side of the engine compartment. There is a little hole that it clips into, and mine is broken. Anybody know what I am talking about? And where can I get one of these other than the dealership? Link to comment Share on other sites More sharing options...
Max Capacity Posted April 8, 2013 Share Posted April 8, 2013 Is there a issue with the clip missing ? are the lines banging around ? Duck tape may work. A zip tie, may be... I wouldn't worry about it unless there is a issue right now. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JmP6889928 Posted April 8, 2013 Share Posted April 8, 2013 Dealership. Link to comment Share on other sites More sharing options...
candt Posted April 9, 2013 Author Share Posted April 9, 2013 Its not actually missing. There is a little hole where it is supposed to pop into, and when I push the clip into the hole, it doesnt stay there, so something on the clip snapped off. The only reason I am wanting to replace it is because it is rattling against the side of the engine compartment. I couldnt figure out what that rattle was for quite a while, now that I know what it is, I want to take care of it. I might give the zip tie a try. Otherwise I suppose I will have to head to the dealership. Link to comment Share on other sites More sharing options...
JmP6889928 Posted April 10, 2013 Share Posted April 10, 2013 Rubber insulated wire strap clamp and small nut and bolt. Link to comment Share on other sites More sharing options...
