garygbnj Posted April 2, 2013 Share Posted April 2, 2013 Lgt 2006 stage 2 145k miles. Daily driver. Is there a consensus as to using dino oil (I changed at 5k) or synthetic oil (I switched and am changing at 5k). Synthetic is much more costly. Does it make a difference? thanks gary Link to comment Share on other sites More sharing options...
_karu_ Posted April 2, 2013 Share Posted April 2, 2013 I go with Dino oil and change every 3 months/3000 miles. Whichever comes earlier. I prefer fresh fluid every 3 months. But that's just me. Link to comment Share on other sites More sharing options...
BigTDogg MA Posted April 2, 2013 Share Posted April 2, 2013 LGT? Yeah, peanut oil is the only appropriate lubricant. High flashpoint, high in Omega 3-6-9 fatty acids, just a great all around lipid. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 2, 2013 Share Posted April 2, 2013 LGT? Yeah, peanut oil is the only appropriate lubricant. High flashpoint, high in Omega 3-6-9 fatty acids, just a great all around lipid. Sounds like somebody had to much Redbull this morning. Poor new guy. I used dino oil for my first 154,000 miles. OCI between 3750 and 5000 miles. The turbo went at 142,000 miles. I replaced the short block at 154,000 because of oil useage and I plan to keep the car for a long time. I could have kept the orginal short block in there and kept adding oil, but I didn't want to. Now I use Amsoil European 5w-40 with 5-6000 mile oil changes. OP there are a ton of oil threads. Read them! The important thing is to keep the oil topped off, NEVER,NEVER,NEVER let it get low. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
BigTDogg MA Posted April 2, 2013 Share Posted April 2, 2013 OP there are a ton of oil threads. Read them! The important thing is to keep the oil topped off, NEVER,NEVER,NEVER let it get low. This. I'm a dick because this question gets asked far too much. All you gotta do is do a bit of searching, or look at stickies. Link to comment Share on other sites More sharing options...
Nrw Posted April 2, 2013 Share Posted April 2, 2013 I like to use Crisco Link to comment Share on other sites More sharing options...
heiche Posted April 2, 2013 Share Posted April 2, 2013 I'm relatively new and wondering if this would be an appropriate response post: "this has been asked to death... to death..." but seriously, either way has its fans. dino or synth. lots to search. BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
RabidWombat Posted April 2, 2013 Share Posted April 2, 2013 Personally, I wouldn't try to push conventional oil to 5k unless you're doing basically all highway miles. After 3750, the conventional oil is looking pretty toast, and I'm 100% stock. If you want to try it, just get am oil analysis. That'll tell you the correct answer. Link to comment Share on other sites More sharing options...
rob-2 Posted April 2, 2013 Share Posted April 2, 2013 For a few dollars more you can go from dino to syn oil. I believe the heat properties of synthetic or semi syn are better for motors. I believe the OCI was lowered to 3750 because the car was originally spec'd to run dino. Feel pretty comfortable with a good, non-mobil1 5w30 or royal purpal, syn oil running 7500 miles. Check oil level regularly. Link to comment Share on other sites More sharing options...
rkhousman Posted April 2, 2013 Share Posted April 2, 2013 I use astroglide the lubricating properties are excellent! Link to comment Share on other sites More sharing options...
Max Capacity Posted April 2, 2013 Share Posted April 2, 2013 This. I'm a dick because this question gets asked far too much. All you gotta do is do a bit of searching, or look at stickies. Don't worry, I know your a ... LOL You were just getting fed up with all the oil threads... Us old timers get that way every now and then. lol 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
