Tehnation Posted March 14, 2013 Share Posted March 14, 2013 Any way to tell if pump is busted. Tried doing a flush like http://legacygt.com/forums/showthread.php/howto-replace-power-steering-fluid-15-minutes-172976.html but when I spin the pump nothing comes out....... Link to comment Share on other sites More sharing options...
Max Capacity Posted March 14, 2013 Share Posted March 14, 2013 What made you think it needed to be flushed ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Tehnation Posted March 14, 2013 Author Share Posted March 14, 2013 It didnt work. I didnt have power steering and it was making loud noises so I figured a flush would fix it. But when I spin the powersteering pump no fluid moves, the fluid only moves when I move the steering wheel. Link to comment Share on other sites More sharing options...
Tehnation Posted March 14, 2013 Author Share Posted March 14, 2013 I had changed my passenger side valve cover gasket, and some other things, and I removed one of the psteering lines to get to a spot, but I think when I reconnected everything a lot of air got in system. Then it completely just stopped working. Link to comment Share on other sites More sharing options...
Tehnation Posted March 14, 2013 Author Share Posted March 14, 2013 I pulled the top line on pump with the o ring, there was some fluid inside pump, but it just sits, I thought turning the powersteering wheel would move the fluid , but it just sat there, so i'm thinking its the pump based on that. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 14, 2013 Share Posted March 14, 2013 Have you put it all back together and strated the engine with the tires off the ground and tryed steering ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Tehnation Posted March 14, 2013 Author Share Posted March 14, 2013 I just figured it out! LOL, i'm just stupid! I had to turn the wheel steering wheel before spinning the steering pump. I moved the wheel back and forth, some fluid came out, then i started turning the steering pump and it started moving fluid from resevoir to pump, when it stopped I had to turn the steering wheel and repeat. Apparently I am amazing at breaking s*** Link to comment Share on other sites More sharing options...
