20lgt06 Posted March 17, 2013 Share Posted March 17, 2013 Dont mean to hijack but what are peoples settings on the koni yellow with your set up, mine can be jaring over pot holes. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted March 17, 2013 I Donated Share Posted March 17, 2013 Dont mean to hijack but what are peoples settings on the koni yellow with your set up, mine can be jaring over pot holes. I just re-set mine to full hard in the front, and approximately halfway in the back. I might tone down the front a bit for daily driving. We don't have a lot of potholes down here, though -- just manhole covers and storm drains. Link to comment Share on other sites More sharing options...
fahr_side Posted March 17, 2013 Share Posted March 17, 2013 Dont mean to hijack but what are peoples settings on the koni yellow with your set up, mine can be jaring over pot holes. There is a certain range of shaft speed in compression that the Koni doesn't deal with well, compared to the rest of the damping range. The result is that certain square-edged bumps are much harsher than you expect, given that the overall feel is very plush. Not really a lot you can do about that. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
road race legacy Posted March 17, 2013 Author Share Posted March 17, 2013 Got my Epic spring from Mike at Infamous Performance and the Yellows from tunersports.com Cant wait to put them on but I first must order some strut mounts because I don't feel like taking everything apart again. Better have piece of mind. Anyone know a good place to order them from? From what I read looks like the ones on ebay and some on line parts store don't fit right and/or wear out quickly. Link to comment Share on other sites More sharing options...
road race legacy Posted March 27, 2013 Author Share Posted March 27, 2013 Got all 4 strut mounts from infamous also. I will try to install the rears by myself today when i get home from work and i will do the fronts on saturday at my friends shop. Next week will go for an alignment. Link to comment Share on other sites More sharing options...
road race legacy Posted March 31, 2013 Author Share Posted March 31, 2013 Did the rears on this past week and I did the fronts today. WOW. It rides amazing. No more clunking from the blown front left shock. For the guys with the yellows...how stiff do you have them set for the street? I set the front camber bolts as fast as negative as possible but I would like to get a bit more out of it. Any suggestions? Link to comment Share on other sites More sharing options...
AZP Installs Posted April 1, 2013 Share Posted April 1, 2013 Did the rears on this past week and I did the fronts today. WOW. It rides amazing. No more clunking from the blown front left shock. For the guys with the yellows...how stiff do you have them set for the street? I set the front camber bolts as fast as negative as possible but I would like to get a bit more out of it. Any suggestions? What are your alignment settings? What other mods do you have? Roll Center Kit? If you go too negative you'll end up wearing your tires prematurely. -mike Link to comment Share on other sites More sharing options...
road race legacy Posted April 1, 2013 Author Share Posted April 1, 2013 Hey, thanks for the quick reply. I don't know what the alignment setting are since I just installed the epic springs and koni yellows this past weekend. I did set the front camber as far in as it can go. From what I've read on here the stock camber bolt will give around 1.5 degrees of negative camber. I would like to run a bit more but its not the end of the world. I'm not worried about the tires. I ran way more than 2 degrees of negative camber on all my other cars with no tires issues. However the TOE was always 0. No other suspension mods besides running some 17x8 +38mm offset rims with 245/40-17 tires. In the future I would like to add a rear sway bar but for now I'm pretty happy on how the car drives with the new suspension and new mounts all around. Link to comment Share on other sites More sharing options...
road race legacy Posted May 8, 2013 Author Share Posted May 8, 2013 Finally got some time off from work and had a chance to do some work on the car. Got the yellows and epic springs installed. Did everything in my driveway, fairly easy, took about 5 hours for the complete install. Drove around with the stock rims and tires for a week or so for everything to seat properly then I put on the new Rota rims and took it for an alignment. Had the TOE set to 0 all the way around, front camber is at -1.7* and rear is at -.5* Wheels-17X8 ROTA G-FORCE 5X100 +48 HYPER BLACK Tires- Continental DW's 245/40-17 Camber- Ingalls camber bolts Link to comment Share on other sites More sharing options...
road race legacy Posted May 8, 2013 Author Share Posted May 8, 2013 More pics. Link to comment Share on other sites More sharing options...
road race legacy Posted May 8, 2013 Author Share Posted May 8, 2013 and few more Link to comment Share on other sites More sharing options...
WaspGT Posted May 16, 2013 Share Posted May 16, 2013 Very nice! Link to comment Share on other sites More sharing options...
road race legacy Posted May 28, 2013 Author Share Posted May 28, 2013 Took advantage of the long weekend (even though it only took less than 2 hours) and decided to put on the new rear sway bar along with some goodies. *WhiteLine 20mm rear sway bar *KartBoy end links *AVO Rear Stabilizer Mount Brace Huge improvement in how the car drives, feels and handles. It really complements the yellows and epic springs. Link to comment Share on other sites More sharing options...
AZP Installs Posted May 29, 2013 Share Posted May 29, 2013 SWEET! Now your login is "Road Race Legacy", so I hope you are signing up for our Track Day at NJMP! http://AZPTrackEvents.com -Mike Paisan AZP's First Private Track Event, June 19 at NJMP Thunderbolt $315 including Classroom and Mentor! http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/145749898/original.jpg http://www.pbase.com/paisan/image/133406601.jpg http://www.whiteline.com.au/images/logos/perf1.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
idiot4hire Posted May 29, 2013 Share Posted May 29, 2013 Anyone try Koni with S-Techs? S tech stink at everything. I have them and they are awful especially at autox I hit the bump stops all the Time. I and going to get koni's and HR springs this summer Link to comment Share on other sites More sharing options...
road race legacy Posted May 29, 2013 Author Share Posted May 29, 2013 SWEET! Now your login is "Road Race Legacy", so I hope you are signing up for our Track Day at NJMP! http://AZPTrackEvents.com -Mike Paisan The car rides and handles nice but its not a track car. Its my daily driver with a an automatic transmission and NA engine. Thanks for the invite though. Link to comment Share on other sites More sharing options...
AZP Installs Posted May 29, 2013 Share Posted May 29, 2013 The car rides and handles nice but its not a track car. Its my daily driver with a an automatic transmission and NA engine. Thanks for the invite though. Gotcha, although this event has nothing to do with the capabilities of the car. It actually has more to do with learning to drive whatever car we have better and harder. It is the "nut behind the wheel" mod so to speak. My first race car was a 1996 Impreza L with a 4EAT trans and it was a blast! -Mike Paisan AZP's First Private Track Event, June 19 at NJMP Thunderbolt $315 including Classroom and Mentor! http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/145749898/original.jpg http://www.pbase.com/paisan/image/133406601.jpg http://www.whiteline.com.au/images/logos/perf1.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
road race legacy Posted May 29, 2013 Author Share Posted May 29, 2013 I understand. I've been autoxing with almost every car I owned since back in the late 90's. Started with my 93 civic, 91 eclipse gsx, 91 galant vr4, then the 04 audi s4. I thought about autoxing the legacy if there's an event closer to me like at Nassau Coliseum in Long Island. Not really willing to drive to jersey even though the thought of driving on a track sounds great compared to a parking lot with cones. Link to comment Share on other sites More sharing options...
AZP Installs Posted May 29, 2013 Share Posted May 29, 2013 Yeah it is a bit of a hike understandably. We Auto-xed back in the late 90s early 2000s at Nassau Col in our Subies and Hondas as well. Probably know a lot of the same people. -Mike Paisan AZP's First Private Track Event, June 19 at NJMP Thunderbolt $315 including Classroom and Mentor! http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/145749898/original.jpg http://www.pbase.com/paisan/image/133406601.jpg http://www.whiteline.com.au/images/logos/perf1.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
N.sane Posted May 30, 2013 Share Posted May 30, 2013 Autocrossing with an automatic 2.5i? AWWW YEAAA [ame=http://www.youtube.com/watch?v=fFmye-AQGHM]www.youtube.com/watch?v=fFmye-AQGHM[/ame] Go for it if you get the chance. You'll love the car even more. Link to comment Share on other sites More sharing options...
AZP Installs Posted May 30, 2013 Share Posted May 30, 2013 [ame=http://www.youtube.com/watch?v=IlCsq6__6tM&feature=share&list=PLE4302CCE57C2C689]Team IAC Road Racing, Aug 2004 - YouTube[/ame] Link to comment Share on other sites More sharing options...
