washingtonOBXT Posted February 20, 2013 Share Posted February 20, 2013 im changing out my struts and springs for king springs with 04 kybs in the rear, i got the spring and top hat off, but how do i get the dust boot off? a picture is attatched to illustrate what mine looks like. also, i did not see a rubber bushing that many struts have, is this because the bump stop is on the frame of the car? Link to comment Share on other sites More sharing options...
washingtonOBXT Posted February 20, 2013 Author Share Posted February 20, 2013 im doing this this afternoon so i need to figure it out, any help would be much apreciated Link to comment Share on other sites More sharing options...
Rester5350 Posted February 20, 2013 Share Posted February 20, 2013 I used a thin flathead screwdriver to brake the grime loose and pulled it off. I also think that I started from the inside of the boot. Good luck. Link to comment Share on other sites More sharing options...
Dbl_D718 Posted February 20, 2013 Share Posted February 20, 2013 It just pulls off, but it'll be stuck on there pretty good. I didn't need any tools to get them off though; just pulled/pushed until it came off...wasn't too hard. MODS: PW TMIC, Cobb catted DP, HKS cat-back, AVO filter, Bren e-tune; Konis/Epics, Advan RCII Link to comment Share on other sites More sharing options...
mwiener2 Posted February 20, 2013 Share Posted February 20, 2013 pull harder My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Underdog Posted February 21, 2013 Share Posted February 21, 2013 If you really get stuck you can use channel locks to grab a third of the boot at a time and pinch it slightly to loosen the rust between the boot and the shaft. The Crimson Dynamo Link to comment Share on other sites More sharing options...
Rester5350 Posted February 21, 2013 Share Posted February 21, 2013 If you play with it enough it will come! Link to comment Share on other sites More sharing options...
Rester5350 Posted February 24, 2013 Share Posted February 24, 2013 How did everything work out for you? Link to comment Share on other sites More sharing options...
