InsertEnigmaHere Posted February 19, 2013 Share Posted February 19, 2013 Picked up some wrx front seats the other day, but having issues taking the old seats out. 4 out of the 5 bolts came out no problem, but the lower bolt holding the right rear of the driver seat rail refuses to come out. It spins but won't unscrew and the same bolt on the other seat does the same thing. I tried prying on the bracket but that didn't help. Anyone else have this issue? Link to comment Share on other sites More sharing options...
Sludgeroo Posted February 19, 2013 Share Posted February 19, 2013 Yea its rusted and stripped it seems like (thread wise). Hit it with some kick ass penetrating oil (aerocroil or oil of wintergreen) and while unthreading it have someone give you positive pressure outward. So wedge a pry bar like you were and keep working it. Or... drill out the bolt and clean out the remaining metal in the threads, go to the hardware store and grab some taps that size and clean her out and be sure not to damage threads. GL. Link to comment Share on other sites More sharing options...
InsertEnigmaHere Posted February 19, 2013 Author Share Posted February 19, 2013 Ok cool, thanks. Do you know, is there a nut on the other side or anything? Haven't gotten a chance to check underneath yet Link to comment Share on other sites More sharing options...
Sludgeroo Posted February 19, 2013 Share Posted February 19, 2013 The threads are right in the floorboard. Looking underneath wont do ya good. Another method if it becomes an absolute female dog, is to actually go under with a pin punch and try wacking them out inward towards the cabin. But that usually results in having to drill bigger and re tap with a different thread Link to comment Share on other sites More sharing options...
nightspeed98 Posted February 19, 2013 Share Posted February 19, 2013 You could try to have someone with a center punch or screwdriver push up on the other end of the screw under the car (if you can see it) and continue unscrewing it. Word of caution. BE EXTREMELY CAREFUL IF YOU OR SOMEONE GETS UNDER THE CAR. WITHOUT THE CORRECT EQUIPMENT, PEOPLE HAVE DIED. just thought I'd share that part. Link to comment Share on other sites More sharing options...
pleaidestar Posted February 19, 2013 Share Posted February 19, 2013 After you get them out...just say **** it and weld the new seats in.... Link to comment Share on other sites More sharing options...
pleaidestar Posted February 19, 2013 Share Posted February 19, 2013 Im kidding...that's african engineering, hey what makes a person a good welder??? Link to comment Share on other sites More sharing options...
subikid90 Posted February 19, 2013 Share Posted February 19, 2013 I am almost positive the threads for the seats are weld nuts. If those nuts break off then you are going to have to cut the bolt to remove the seat. I am also pretty sure you cannot reach the weld nuts from under the car. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
InsertEnigmaHere Posted February 19, 2013 Author Share Posted February 19, 2013 I'll get it up on the lift tomorrow and see what (if anything) I can find. I've been reading around and it definitely sounds like there's broken weld nuts involved. This also just happens to be the bolt ISN'T used on the wrx seats. Link to comment Share on other sites More sharing options...
InsertEnigmaHere Posted February 19, 2013 Author Share Posted February 19, 2013 The bolt right above the one in question (that actually came out) goes right through and you can see the back of the trans so it should be accessible. I know I'm not the only one who's had this issue so I'm not terribly concerned lol Link to comment Share on other sites More sharing options...
Sludgeroo Posted February 20, 2013 Share Posted February 20, 2013 I am almost positive the threads for the seats are weld nuts. If those nuts break off then you are going to have to cut the bolt to remove the seat. I am also pretty sure you cannot reach the weld nuts from under the car. That's right, I checked my parts SUS Link to comment Share on other sites More sharing options...
pleaidestar Posted February 20, 2013 Share Posted February 20, 2013 Tough crowd..its a grinder Link to comment Share on other sites More sharing options...
pleaidestar Posted February 20, 2013 Share Posted February 20, 2013 they are weld nuts,they are in the drive shaft tunnel. Tough as heck to get to. Link to comment Share on other sites More sharing options...
pleaidestar Posted February 20, 2013 Share Posted February 20, 2013 Hm, my old lady was right, I guess I'm not that funny. Anyways have fun... Link to comment Share on other sites More sharing options...
InsertEnigmaHere Posted February 20, 2013 Author Share Posted February 20, 2013 Either way, it sounds like it can be worked out one way or the other, haha. Cheers Link to comment Share on other sites More sharing options...
pleaidestar Posted February 20, 2013 Share Posted February 20, 2013 Everything can work out, gotta keep humor still Link to comment Share on other sites More sharing options...
InsertEnigmaHere Posted February 20, 2013 Author Share Posted February 20, 2013 Got the bolts out! They were indeed weld nuts that separated from the body and they WERE accessible from underneath the car, at the bottom edge of the driveshaft tunnel. Thanks for your guys' help! Link to comment Share on other sites More sharing options...
pleaidestar Posted February 21, 2013 Share Posted February 21, 2013 if you have access to a welder just run the bolt back into the nut after you get your seats situated and put a couple quick tacks on the nut to weld it back to the body, you don't need a full weld in there metal kind of thin so be careful not to blow through....good luck enigma, glad you got it out bud. Link to comment Share on other sites More sharing options...
spooln30 Posted February 24, 2013 Share Posted February 24, 2013 Im kidding...that's african engineering, hey what makes a person a good welder??? That sounds a tad racist. Just saying and in any case I dont even understand what that is supposed to mean. Link to comment Share on other sites More sharing options...
pleaidestar Posted February 24, 2013 Share Posted February 24, 2013 Well maybe I'm African and an engineer. It was a joke bub, lighten up.... If there are any African engineers on this board, I extend my deepest apologies for not being politically correct. Link to comment Share on other sites More sharing options...
nightspeed98 Posted February 25, 2013 Share Posted February 25, 2013 i'm Hispanic, my wife is white, my half brother is black. that being said, i can explain it and not give a good god damn what others have to say on the matter. he meant the bad words jerry/nigger rigging or the peruvian hammer fix. there said it. am i on time out or are the balls still swinging? Link to comment Share on other sites More sharing options...
jarmerson Posted February 25, 2013 Share Posted February 25, 2013 I wasn't gonna say anything but the subtlety of the comment earlier wasnt so subtle. I was thinking 'makeshift' fits better The only reason I look at other peoples cars is so I can see my Subie in the reflection - Carver Snell Check out 2nd Gen Legacy Enthusiast & Resource Directory Link to comment Share on other sites More sharing options...
nightspeed98 Posted February 25, 2013 Share Posted February 25, 2013 lol Link to comment Share on other sites More sharing options...
Sludgeroo Posted February 25, 2013 Share Posted February 25, 2013 Would "Engineered with a tad to much tom foolery" be an adequate replacement? Link to comment Share on other sites More sharing options...
pleaidestar Posted February 25, 2013 Share Posted February 25, 2013 I thought my post was kind of subtle, even borderline funny. I'm a white guy married to a Mexican girl, two good friends of mine are black...doesn't really matter to me either...I didn't mean any harm. Link to comment Share on other sites More sharing options...
