jon450 Posted February 4, 2013 Share Posted February 4, 2013 I have a 09 diesal estate manual gearbox, i.m changing the box and rear diff oil at the weekend, am i right in thinking that the front diff is part of the gearbox so i only need to change the one lot of oil. Also is it in obvious for the oil drain as well dont want to undo the wrong plug. Thx Jon Link to comment Share on other sites More sharing options...
Max Capacity Posted February 4, 2013 Share Posted February 4, 2013 I'll assume you have the 70torx to remove the plug. if it's a 6 speed you may need to remove the drain plug too. The car will need to have the rear end jacked up the drain all the fluid. I'm also guessing you need either 5 qt's of Extra-S or Amsoil Severgear 75w-90 or the cocktail of 3qt redline lightweight shockproof and .8 Motul 300 and .8 Motul in the read diff. Do not over tighten the plugs in the read diff. BAC5.2 is the expert on this stuff, may be he'll chime in soon. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jon450 Posted February 4, 2013 Author Share Posted February 4, 2013 sorry 5 speed box 3.5 ltr of 70w90 gl5 oil but am i right about the front diff and box all in one using the same oil? Link to comment Share on other sites More sharing options...
Max Capacity Posted February 4, 2013 Share Posted February 4, 2013 Yes, should be the same as our 5mt's. Make sure you only use one of the three fluids I mentioned. You don't know how picky these tranny's are. Many have learned the hard way. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jon450 Posted February 5, 2013 Author Share Posted February 5, 2013 Ok thanks don't know if we have these oil's in the UK. Will look for something similar Link to comment Share on other sites More sharing options...
Max Capacity Posted February 5, 2013 Share Posted February 5, 2013 The dealer should have Extra-S. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
bluesuby Posted February 5, 2013 Share Posted February 5, 2013 I've had good success with Redline 75-90 NS. The dealer may have Extra-S but I'm not certain they will sell small quantities to DIYers. Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted February 6, 2013 I Donated Too Share Posted February 6, 2013 jon450 - Halfords on Weeden Road, Daventry or Kettering have suitable oil... don't buy their home grown brand for these cars, use the good stuff... not comma oil either - they should have Castrol Syntrans 75W-90 - whichever one is nearest to you, just give them a call first to make sure they have enough in stock. Link to comment Share on other sites More sharing options...
jon450 Posted February 6, 2013 Author Share Posted February 6, 2013 Ok will have a look in Halfords today.I was going to use this stuff http://www.ebay.co.uk/itm/290374838419?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 I have used this guys for ages for other stuff, he is cheap, he is the supplyer but will deal with the public, but I dont want to bugger the box if this is no good. Jon Link to comment Share on other sites More sharing options...
BoozeRS05 Posted February 6, 2013 Share Posted February 6, 2013 I used regular old valvoline 75w90 for a spell and it was fine... I know the difference btw extraS and valvoline first hand , but it's also what dealerships use in the other 90% of the 5mt Subarus in North America they service. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
