Jp2627 Posted January 28, 2013 Share Posted January 28, 2013 Temp gauge never moves but here in Massachusetts it's 20 degrees today and I see heat pouring out from the hood scoop area when I'm idling and I've only driven 15 min. The car drives fine and has all of its power but I'm just worried about it. I'm trying to learn about this car, i love it and put tons of miles on it. Should this be a concern to me? Especially since its freezing cold outside. Is there something I should have checked? Thanks Link to comment Share on other sites More sharing options...
bluesuby Posted January 28, 2013 Share Posted January 28, 2013 Do you see "heat" or steam?Check the seams on the radiator....could be a slow weep or leak which would not affect the operating temperature. Are you losing coolant level in the reservoir tank? Link to comment Share on other sites More sharing options...
Jp2627 Posted January 29, 2013 Author Share Posted January 29, 2013 Thanks guys. It's def not steam it's just heat that you can see coming up from the hood. I will check the few ideas that u suggested and let you know. Link to comment Share on other sites More sharing options...
bomberlegacy Posted January 29, 2013 Share Posted January 29, 2013 My total uneducated opinion..it sounds normal. 180+ degrees under the hood, you should see some radiating heat when its cold out. '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
12sechatch Posted February 10, 2013 Share Posted February 10, 2013 ^^that isn't an uneducated opinion...what we call that is common sense. Link to comment Share on other sites More sharing options...
AkumaMax Posted February 21, 2013 Share Posted February 21, 2013 If you are not smelling anything Sweet from the car then everything should be as normal. Link to comment Share on other sites More sharing options...
lee07 Posted February 22, 2013 Share Posted February 22, 2013 wet snow/ice? Link to comment Share on other sites More sharing options...
