candt Posted January 17, 2013 Share Posted January 17, 2013 My Air Bag light started staying constantly lit in my dashboard this week, and after doing some research it is the overhead display for the passenger air bag status, being either on or off. It appears I need to pull this down and resolder some wires together. Does anyone know how this thing comes down? Does it have to be pryed off, or are there some screws to release it? Its an 09 SE. Link to comment Share on other sites More sharing options...
golunnova Posted January 18, 2013 Share Posted January 18, 2013 Is your airbag light staying on when you have no one sitting on the passenger seat? Link to comment Share on other sites More sharing options...
candt Posted January 18, 2013 Author Share Posted January 18, 2013 I have yet to have a passenger in my car, and the air bag light will stay lit in the dash. I've noticed that the over head display which should say "on" or "off" sometimes will say nothing. Link to comment Share on other sites More sharing options...
BA_SUBARU24 Posted January 19, 2013 Share Posted January 19, 2013 I have the exact issue. I took my car 2007 LGT into my Subaru dealer to see what was up. He told me I was the 4th one to come in this week with the same problem! They checked all wires and everything and that wasnt an issue on mine. This is what I got in my write up: Air bag light is on code 26 stored in history, light was not on when tested today, needs the map light airbag light assy replaced estimate to repair $250. Costed me $50.00 just for them to look at it. Link to comment Share on other sites More sharing options...
AkumaMax Posted January 19, 2013 Share Posted January 19, 2013 Well if it's the map light just buy one off Ebay for $50 save $200 from stealership. As for the OP's question you have to pop off the light cover with a flat head to uncover 2 Phillips head scres. Undo and pull it down. Replace with new or used unit and done. Link to comment Share on other sites More sharing options...
candt Posted January 19, 2013 Author Share Posted January 19, 2013 Thanks akuma max for the post. I may just replace this myself. Link to comment Share on other sites More sharing options...
candt Posted January 20, 2013 Author Share Posted January 20, 2013 Something else I noticed on my car unrelated to the air bag light...On one of my front fenders, there are washers behind the bolts that hold the fender on, and on the other side there are no washers. Is it possible it came this way from the factory? Link to comment Share on other sites More sharing options...
ericem Posted January 21, 2013 Share Posted January 21, 2013 probably got into a accident. Link to comment Share on other sites More sharing options...
JermTheElf Posted January 21, 2013 Share Posted January 21, 2013 Check the harness to the back of the clock as well RKelly Link to comment Share on other sites More sharing options...
GEE-OTTO Posted January 21, 2013 Share Posted January 21, 2013 Same thing with my 09 the AB light is intermittent but I found that moving the passenger seat forward or aft will keep it off for a while. I encountered this yesterday after washing my car and I move the seat to vacuum, once i started my car the light was on. So i played with seat position and the light went off. The culprit here is the Air Bag module like Max alluded to, it is easy enough to replace if you want to save some $$$. Link to comment Share on other sites More sharing options...
slvrlegacygt Posted January 22, 2013 Share Posted January 22, 2013 I had a problem with my airbag light coming on and staying on. I would adjust the seat and that would turn the light off sometimes. It eventually came back and would stay on permanently. Luckily I work at a dealer ship and had a tech who I'm friends with scan the the code for me and it turns out my seat belt buckle was defective. I took it to subaru and they did it under the lifetime seatbelt warranty so they replaced it for free. Link to comment Share on other sites More sharing options...
candt Posted January 22, 2013 Author Share Posted January 22, 2013 tonight on the drive home, the pass air bag light in the middle didnt come on til I was half home, but the off light was on, and of course the air bag light in the dash. Heres my question....does this in any way affect the air bag system, or is it simply just a matter of the light being on or off? Link to comment Share on other sites More sharing options...
eddie13231 Posted January 24, 2013 Share Posted January 24, 2013 Hey guys I had this same problem during the fall. Intermittent dash red airbag light. It would come on randomly but when it did it would stay on. If I re-started the car a few times it would then go off. I did a lot of research online and it is usually due to a faulty module within the dash itself that needs replaced. I called SOA and got this covered due to it being a safety issue as a courtesy. I had to pay but they sent me a check for the repair. I believe it was in the realm of $350.00. I would try calling SOA because if the airbag light is on the airbags will not deploy. This is on a 2007 2.5 NA Link to comment Share on other sites More sharing options...
DocHolladay23 Posted January 24, 2013 Share Posted January 24, 2013 ...I would try calling SOA because if the airbag light is on the airbags will not deploy. Did SOA say that? I have a hard time believing a light on the dash would prevent a safety device from working... [sIGPIC][/sIGPIC] You want stickers? Hit me up here!!! You want a shirt? Hit me up here!!! Link to comment Share on other sites More sharing options...
eddie13231 Posted January 25, 2013 Share Posted January 25, 2013 Did SOA say that? I have a hard time believing a light on the dash would prevent a safety device from working... Yes. The dealer said it would not deploy and SOA said would likely not deploy. Hence SOA covered the repair b/c I complained. Link to comment Share on other sites More sharing options...
DocHolladay23 Posted January 25, 2013 Share Posted January 25, 2013 Interesting, well for anyone who has the dash light they may want to check out this thread. Several of us have had sucess with re-soldering a few connection in the map light circuit board. [sIGPIC][/sIGPIC] You want stickers? Hit me up here!!! You want a shirt? Hit me up here!!! Link to comment Share on other sites More sharing options...
