Grimmrican Posted January 8, 2013 Share Posted January 8, 2013 Sup guys in the next few weeks I'll be working on a project for my wagon. I'm curious on a few things and hoping u guys can help. I looking for case bolts for a 2.2 block and head bolts for a 2.0 Rex. I kno I'll need a 2.0t ecu but what about the harness?? Please help Link to comment Share on other sites More sharing options...
sbw Posted January 8, 2013 Share Posted January 8, 2013 Im confused. Lets start over. What are you trying to do exactly? Link to comment Share on other sites More sharing options...
Grimmrican Posted January 8, 2013 Author Share Posted January 8, 2013 Sorry I was in a bit of a rush as I wrote this. Ok from the beginning. I'm putting together an engine. 2.2 block with wrx 2.0 heads turboed. I'm going to put in some acl race bearings and blah blah blah. But my concerns are: where can I find the case and head bolts. Everyone I've talked to said go with apr. Where can I obtain these bolts. And also. With this hybrid setup I'm curious as to what harness (if need be) should I use when I do the engine swap? Link to comment Share on other sites More sharing options...
subikid90 Posted January 8, 2013 Share Posted January 8, 2013 For case bolts go OEM, no need to spend money on ARP's. For the head bolts you have two choices, ARP 2000 and Custom Aged 625+. http://www.importimageracing.com/arp-head-studs-for-02-13-subaru-wrx-sti.html http://www.importimageracing.com/arp-custom-age-head-stud-kit-subaru-ej-series-dohc.html For what you are doing the ARP 2000's will be just fine. Always run the matching harness and intake manifold to you heads. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Grimmrican Posted January 8, 2013 Author Share Posted January 8, 2013 If I could hit the thanks button a million times I would. Thank u much Link to comment Share on other sites More sharing options...
Grimmrican Posted January 8, 2013 Author Share Posted January 8, 2013 Also another question..... When I click the first Link I noticed the head bolts r for a 2013. Does it matter?? Link to comment Share on other sites More sharing options...
subikid90 Posted January 8, 2013 Share Posted January 8, 2013 No all EJ's use the same head bolts -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Grimmrican Posted January 8, 2013 Author Share Posted January 8, 2013 Sweet thanx again Link to comment Share on other sites More sharing options...
Baddog Posted January 9, 2013 Share Posted January 9, 2013 2.2 and 2.5 are different though. Link to comment Share on other sites More sharing options...
Grimmrican Posted January 9, 2013 Author Share Posted January 9, 2013 I'm not going 2.5. I'm doing 2.0 heads on a 2.2 block Link to comment Share on other sites More sharing options...
subikid90 Posted January 9, 2013 Share Posted January 9, 2013 2.2 and 2.5 are different though. Not completely true. DOHC and SOHC are different. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
SpecBamf41 Posted January 9, 2013 Share Posted January 9, 2013 so meaning arp's work on every block and only dohc heads right? never thought about this before, but who actually likes there sohc heads? BNR18g on 93oct Link to comment Share on other sites More sharing options...
subikid90 Posted January 9, 2013 Share Posted January 9, 2013 so meaning arp's work on every block and only dohc heads right? never thought about this before, but who actually likes there sohc heads? They make a set for both DOHC and SOHC in the ARP 2000 material and DOHC in the Custom Age 625+ material. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
SBT Posted January 9, 2013 Share Posted January 9, 2013 Is this on a 2.2T block? - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted January 9, 2013 Share Posted January 9, 2013 I'm not going 2.5. I'm doing 2.0 heads on a 2.2 block Recipe for the DOHC EJ22 Turbo that you're trying to build: 205 Timing Belt & Pulleys. 205 Heads/Wiring/ECU/Intercooler/Intake-Exhaust manifolds. 205 Crank Gear (you MUST have this as it is what the ECU needs to determine crank position). Turbo crossmember or cut crossmember w/welded reinforcement. EJ22 Phase 2 MLS Gaskets (order them thick because the Phase 1 2.2 pistons clear the deck & the coolant passages match those of the 205 heads.) Wiring for WRX dashboard (use the whole dash, if you can). WRX fuel pump. Keep your manual transmission (if you have one) but 2 extra holes may need to be drilled into the case where it connects to the engine. Link to comment Share on other sites More sharing options...
Grimmrican Posted January 9, 2013 Author Share Posted January 9, 2013 Is this on a 2.2T block? Non turbo block Link to comment Share on other sites More sharing options...
SBT Posted January 10, 2013 Share Posted January 10, 2013 ^ Be careful, especially if you're planning to boost over 5-6psi. Open decks are not known for their boost-holding capability. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Grimmrican Posted January 10, 2013 Author Share Posted January 10, 2013 Yea I'm not trying to go boost happy with the car. It's more of a pride and doing it in general. I was thinking 8psi but good to know not to go over 6 Link to comment Share on other sites More sharing options...
SBT Posted January 10, 2013 Share Posted January 10, 2013 Are you doing standalone EM? - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Grimmrican Posted January 10, 2013 Author Share Posted January 10, 2013 Em?? Link to comment Share on other sites More sharing options...
SBT Posted January 10, 2013 Share Posted January 10, 2013 Engine Management? - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Grimmrican Posted January 10, 2013 Author Share Posted January 10, 2013 Oh. No I'm gonna use a stock 2.0 ecu I'm not going to build n tune just yet. Link to comment Share on other sites More sharing options...
SBT Posted January 10, 2013 Share Posted January 10, 2013 GLWT - should be a fun build. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Grimmrican Posted January 10, 2013 Author Share Posted January 10, 2013 I'm sorry I'm still a noob when it comes acronyms Link to comment Share on other sites More sharing options...
subikid90 Posted January 10, 2013 Share Posted January 10, 2013 Good Luck With That -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
