schspeedster Posted April 19, 2009 Share Posted April 19, 2009 This isn't exactly along the same lines, but does anyone know about disabling the panic button on the remote? I hate its location, I always seem to press it with the keys in my pocket, if I move the wrong way. Drives me nuts. I like the older remotes, where you had to press/hold lock and unlock at the same time. Anyway, just wondering. I'm sure I could clip the back of the plastic button piece or something, but this is the only key fob I have for now (need to get more made) and I don't want to screw it up. I would also like to disable my panic button. Maybe can glue a plastic piece over button? Link to comment Share on other sites More sharing options...
Siper2 Posted April 19, 2009 Share Posted April 19, 2009 I scared my poor dog the other day, we were walking the neighborhood and came in through the garage. As usual, I breathed the right way and the alarm went off. Yeah, annoying. Link to comment Share on other sites More sharing options...
satellite_guy Posted April 23, 2009 Share Posted April 23, 2009 OK, I checked the manual - it is different on my 06, I had to sit in the driver's seat, hold the unlock switch up on the driver's door and put the key in the ignition and take it out at least 6 times in 10 seconds, then open and close the driver's door. Worked like a charm! That's the ticket, worked on my 06. Now I don't have to be that guy with the beeping car Link to comment Share on other sites More sharing options...
ChubRock Posted April 28, 2009 Share Posted April 28, 2009 what do you mean by holding the unlock switch up?? Link to comment Share on other sites More sharing options...
Pawlwawl06 Posted April 28, 2009 Share Posted April 28, 2009 on the driver's door, just push the lock up and hold it while you do the rest. Link to comment Share on other sites More sharing options...
07gtlimited Posted May 17, 2009 Share Posted May 17, 2009 Open the FOB and put scotch tape over the contacts! Replace the battery while in there! Link to comment Share on other sites More sharing options...
Jimaa66 Posted June 4, 2010 Share Posted June 4, 2010 Tried this is my '07, but had to hold the button down, not up. And yes- silent openning....perfect! Thanks! Link to comment Share on other sites More sharing options...
Zephrant Posted September 29, 2010 Share Posted September 29, 2010 Just tried it on my 06, and it was hold the lock button down, or in the "unlock" position, then insert/remove the key six times, and open/close the door. Works great, thanks! Link to comment Share on other sites More sharing options...
jigg306 Posted April 23, 2013 Share Posted April 23, 2013 I've been saying that I need to read the manual, but never do- thanks Link to comment Share on other sites More sharing options...
biker921 Posted April 29, 2013 Share Posted April 29, 2013 Thank you. Great write up. Link to comment Share on other sites More sharing options...
PtPixel Posted April 30, 2013 Share Posted April 30, 2013 Does anyone know of the JDM version for this or for the seatbelt chime? The manual doesn't have any instructions and neither this method for the alarm (Default setting is has no chirp, only indicators) or the seatbelt click method seem to work...? In the mean time I've disconnected the wire under the driver seat but any weight on the passenger seat will set the chime off... Link to comment Share on other sites More sharing options...
Rocktman Posted July 18, 2013 Share Posted July 18, 2013 I just got my 2014 Legacy 2.5i yesterday & found these instructions on page 2-21 in the owners manual: Selecting audible signal operation(models without “keyless access with pushbutton start system”) Using an electronic chirp, the system will give you an audible signal when the doors lock and unlock. If desired, you may turn the audible signal off. To deactivate the audible signal, perform the following procedure. You can also use the same steps to restore the function. 1. Sit in the driver’s seat and shut all doors and the rear gate. 2. Press the unlock side of the power door locking switch. 3. Insert the key into the ignition switch. 4. While holding down the unlock side of the power door locking switch, pull the key out and re-insert it into the ignition switch at least 5 times within 10 seconds after performing step 2. 5. Open and close the driver’s door within 10 seconds after performing step 4. 6. To indicate completion of the setting, the hazard warning flashers flash 3 times and the chirp sounds 3 times. It took me 2 tries, but it did work. On to the seatbelt chime when I get home from work. Link to comment Share on other sites More sharing options...
0Subie9 Posted August 14, 2013 Share Posted August 14, 2013 2009 models its in the manual on page 2-11. Its the same instructions as the 2006 that was posted earlier in this thread. Sit in the drivers seat. Hold the unlock button while putting the key in and out of the ignition 6 times within 10 seconds and after the 6th time open and close the drivers door. you will see your turn signal indicators blink 3 times to let you know it worked. Link to comment Share on other sites More sharing options...
andyengineer Posted September 23, 2014 Share Posted September 23, 2014 Wow I just had to check my fob and sure enough the instructions are on the back of it. My stupid fob is so sensitive that I've turned the chirping ability on and off randomly with the keys in my pocket just bending over or picking stuff up. It is good to know how to actually control it now. Link to comment Share on other sites More sharing options...
BL5BO Posted October 30, 2014 Share Posted October 30, 2014 Tried this on my 06 and it flashed and everything but as soon as i get out and arm it chrips 5 times to arm! EDIT: Read Manual. When it beeps 5 times it means something is not shut all the way aka, my trunk! Now it works flawlessssly! My "Alpine White" 06 LGT: The Kabigon [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
