Somerandomguy175 Posted November 16, 2012 Author Share Posted November 16, 2012 I'm also leaning away from cracking open the tail lights, I'm actually working up the courage to do the headlights thanksgiving weekend. I seen a bunch of write ups on here on how to clear the headlights and I didn't know the bumper had to be removed lol Link to comment Share on other sites More sharing options...
FJuan Posted November 16, 2012 Share Posted November 16, 2012 Clearing the headlights is fairly stright forward. The bumper comes off in 10 mins and the headlights take less than 5 mins to remove. Once you do the first one, the second one is a breeze. I've done 3 sets so far, all using the heat gun method. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
xero287 Posted November 16, 2012 Share Posted November 16, 2012 *On legacygt.com* *Presses Forums* *Scrolls down 4th Gen* *Sees a thread named "Tail Lights" *Hopes to see BAC5.2 enforce the law* *Sees BAC5.2 jokingly enforce the law and is still satisfied* Seriously, I think there needs to be a tutorial session for some of the new members on here. USE the SEARCH bar, IF that fails then use the GOOGLE SEARCH bar. THEN AND ONLY THEN make a "new" thread about tail lights. OH AND BTW. http://legacygt.com/forums/showthread.php/no-time-wait-gialla-finished-my-led-project-48426.html?t=48426&highlight=LED+Tail Link to comment Share on other sites More sharing options...
EJ25subie05 Posted November 16, 2012 Share Posted November 16, 2012 don't use the heat gun method for the headlights, imho it sucks using a heat gun, it takes for ever. take your headlight off, set your oven at 215 degrees (thats what i used and just did two sets yesterday).take off the screws in the back of the headlight, then put the headlights in the oven for 10-12 minutes, take them out and just work your way around them, first one i used a knife to pry open, but if you make them warm enough you will just be able to pull them apart by hand, you pull the tabs up and pull the headlight apart. after that you can clear them or black them out (i blacked mine out). Link to comment Share on other sites More sharing options...
Somerandomguy175 Posted November 16, 2012 Author Share Posted November 16, 2012 *On legacygt.com* *Presses Forums* *Scrolls down 4th Gen* *Sees a thread named "Tail Lights" *Hopes to see BAC5.2 enforce the law* *Sees BAC5.2 jokingly enforce the law and is still satisfied* Seriously, I think there needs to be a tutorial session for some of the new members on here. USE the SEARCH bar, IF that fails then use the GOOGLE SEARCH bar. THEN AND ONLY THEN make a "new" thread about tail lights. OH AND BTW. http://legacygt.com/forums/showthread.php/no-time-wait-gialla-finished-my-led-project-48426.html?t=48426&highlight=LED+Tail http://legacygt.com/forums/search.php?searchid=11230378 i searched led tail lights....all those threads/posts contain the words "led" "tail" "lights" how does that help me? and there isnt a rule to posting the same thing someone else did and if there was no one would get anywhere with people bashing them over and over. new posts catch peoples eye and get the new ideas, maybe there should just be 3 people on here making all the posts and dont let no one do anything.....sounds good right? Link to comment Share on other sites More sharing options...
Somerandomguy175 Posted November 16, 2012 Author Share Posted November 16, 2012 don't use the heat gun method for the headlights, imho it sucks using a heat gun, it takes for ever. take your headlight off, set your oven at 215 degrees (thats what i used and just did two sets yesterday).take off the screws in the back of the headlight, then put the headlights in the oven for 10-12 minutes, take them out and just work your way around them, first one i used a knife to pry open, but if you make them warm enough you will just be able to pull them apart by hand, you pull the tabs up and pull the headlight apart. after that you can clear them or black them out (i blacked mine out). im not allowed to use the oven Link to comment Share on other sites More sharing options...
xero287 Posted November 16, 2012 Share Posted November 16, 2012 dont let no one do anything.....sounds good right? That sounds wonderful. I think you missed the part where I mentioned to search via google. That's actually how I found the thread I linked you. Link to comment Share on other sites More sharing options...
EJ25subie05 Posted November 16, 2012 Share Posted November 16, 2012 i waited till mom was at work when i took my headlights off and threw them into the oven, otherwise idk what she would have said Link to comment Share on other sites More sharing options...
Somerandomguy175 Posted November 16, 2012 Author Share Posted November 16, 2012 i waited till mom was at work when i took my headlights off and threw them into the oven, otherwise idk what she would have said Its not mom im worried about its the GF hahaha....im going to try the heat gun method first, just to have a little more control of whats going on. My luck ill forget about them and ill have headlight cookies! Link to comment Share on other sites More sharing options...
EJ25subie05 Posted November 16, 2012 Share Posted November 16, 2012 first set i did with a heat gun was a mess, plastic ripped, cracked all that good stuff probably because it was my first, but the 2nd set i did in the oven went perfect. then you preheat them the same way for reassembly can't get any easier then that. Link to comment Share on other sites More sharing options...
Somerandomguy175 Posted November 16, 2012 Author Share Posted November 16, 2012 Ok that scares me lol other posts one here that I SEARCHED for say a lower temp...now you are saying 215 for 12 minutes? is that letting the oven heat up first? And do i flip the headlights to get an even bake? lol Link to comment Share on other sites More sharing options...
EJ25subie05 Posted November 16, 2012 Share Posted November 16, 2012 nope i let the oven heat up first takes what 2 min? then you put the headlights in for 12 minutes, mine varied i checked them every now and then before 12 minutes to see how warm the plastic was. if it was getting warm i just took em out and it worked perfectly for separating it. nothing to be worried about, you won't melt them at that temp in 12 min. believe me I've done 2 sets already. Link to comment Share on other sites More sharing options...
EJ25subie05 Posted November 16, 2012 Share Posted November 16, 2012 and no you don't flip the headlights unless you have some old school oven, even then never seen one where you have to flip food around to make it evenly cooked) maybe let your gf bake some headlights Link to comment Share on other sites More sharing options...
Somerandomguy175 Posted November 16, 2012 Author Share Posted November 16, 2012 ok since you are the expert in headlight baking....ill be contacting you next friday if i bake my headlights into my oven! Link to comment Share on other sites More sharing options...
EJ25subie05 Posted November 16, 2012 Share Posted November 16, 2012 if that happens you shouldn't be around an oven, just watch them and feel how hot they are getting, if you think the glue is soft enough to pull apart them take them out. if its not put them back in the oven and wait a bit more. Link to comment Share on other sites More sharing options...
Somerandomguy175 Posted November 16, 2012 Author Share Posted November 16, 2012 hey you never know! but you will see a brand new thread that says OOPSIE! if anything bad happens..ill have to take a look at a few more write ups and get it down so i know how to exactly get them apart. thanks again buddy ill letting you know how this goes hah Link to comment Share on other sites More sharing options...
EJ25subie05 Posted November 16, 2012 Share Posted November 16, 2012 here you go, this may help you somewhat. i found this when looking at upgrading my lens, just so you don't think I'm kidding about leaving them in for 10-12 min... he did 265 at 7 min. http://legacygt.com/forums/showthread.php/retrofitting-projectors-trs-hid-178274.html Link to comment Share on other sites More sharing options...
xero287 Posted November 16, 2012 Share Posted November 16, 2012 Stay at 215, check at 9, 11, and 13 minutes. As in, check at 9 minutes if too hard to pull apart, put back in the over for 2 minutes. Rinse, repeat. Link to comment Share on other sites More sharing options...
I Donated Too laff79 Posted November 16, 2012 I Donated Too Share Posted November 16, 2012 Stay at 215, check at 9, 11, and 13 minutes. As in, check at 9 minutes if too hard to pull apart, put back in the over for 2 minutes. Rinse, repeat. ^This. Seriously guys, just man up and do it. Not rocket science, just time consuming (especially if blacking out as well). Link to comment Share on other sites More sharing options...
Somerandomguy175 Posted November 16, 2012 Author Share Posted November 16, 2012 here you go, this may help you somewhat. i found this when looking at upgrading my lens, just so you don't think I'm kidding about leaving them in for 10-12 min... he did 265 at 7 min. http://legacygt.com/forums/showthread.php/retrofitting-projectors-trs-hid-178274.html I'm going to send him a message thanks! Stay at 215, check at 9, 11, and 13 minutes. As in, check at 9 minutes if too hard to pull apart, put back in the over for 2 minutes. Rinse, repeat. ^This. Seriously guys, just man up and do it. Not rocket science, just time consuming (especially if blacking out as well). You're completely right but my car is my only mode of transportation....so let's see.. I mess up my headlights I can't drive, I can't drive I can't get to work, I can't make money if I don't work to pay for a new set of headlights.....its a little unnerving Link to comment Share on other sites More sharing options...
I Donated Too laff79 Posted November 16, 2012 I Donated Too Share Posted November 16, 2012 You're completely right but my car is my only mode of transportation....so let's see.. I mess up my headlights I can't drive, I can't drive I can't get to work, I can't make money if I don't work to pay for a new set of headlights.....its a little unnerving yeah, because you're the only guy who's ever done this to his DD. Link to comment Share on other sites More sharing options...
Somerandomguy175 Posted November 16, 2012 Author Share Posted November 16, 2012 I'm not saying I'm the only one, I'm just saying its a big risk for me. I've never done anything like that before and don't have any knowledge of this mod. I don't have that much confidence in myself lol if it was HID kits, LEDs, systems, or painting I would be all over it! I will be trying it next weekend after I get all my headlight/foglight stuff. Kudos to anyone who dives right into putting headlights in the oven Link to comment Share on other sites More sharing options...
FJuan Posted November 16, 2012 Share Posted November 16, 2012 I was too scared to put my headlights in the over, I tend to over bake things. Try the oven method first, it seems to be the easier way for first timers. I prefer the heat gun, since I have more control of the heat and I can see when the glue is ready to be pulled apart. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
JermTheElf Posted November 16, 2012 Share Posted November 16, 2012 I do 285* for 6 minutes. Link to comment Share on other sites More sharing options...
Somerandomguy175 Posted November 16, 2012 Author Share Posted November 16, 2012 Thanks guys I appreciate all the positive feedback Link to comment Share on other sites More sharing options...
