Impatient Posted January 27, 2015 Share Posted January 27, 2015 Roadtrip, I think you missed that people are preferring rear KYB's for 02-04 OBs Link to comment Share on other sites More sharing options...
NoRoadtrippin Posted January 28, 2015 Share Posted January 28, 2015 Roadtrip, I think you missed that people are preferring rear KYB's for 02-04 OBs So buy the correct model number KYB for the fronts and buy the ones listed as being for 04-05s for my rears? And they'll still bolt up on the '09? Link to comment Share on other sites More sharing options...
Beacho Posted January 28, 2015 Share Posted January 28, 2015 Correct. I used 00-04 spec, pn341276 in the rear and 05-09 spec fronts; 339099/339098. I absolutely love the way this car rides and handles now. Link to comment Share on other sites More sharing options...
Rhitter Posted January 28, 2015 Share Posted January 28, 2015 take a look at this too for more information http://www.subaruoutback.org/forums/109-gen-3-2005-2009/28368-2005-2009-outback-suspension-faq.html My OBXT build Link to comment Share on other sites More sharing options...
Nightmaresmk Posted January 28, 2015 Share Posted January 28, 2015 I'm at 35k miles on the KYB's 04 rear and 05+ front the ride is starting to feel worn out. It doesn't feel as planted any more. Link to comment Share on other sites More sharing options...
Beacho Posted February 1, 2015 Share Posted February 1, 2015 I'm at 35k miles on the KYB's 04 rear and 05+ front the ride is starting to feel worn out. It doesn't feel as planted any more. What springs are you running? Link to comment Share on other sites More sharing options...
Rhitter Posted February 1, 2015 Share Posted February 1, 2015 What springs are you running? His build thread http://legacygt.com/forums/showthread.php/my-betty-pic-heavy-219077.html My OBXT build Link to comment Share on other sites More sharing options...
thorton0 Posted February 1, 2015 Share Posted February 1, 2015 it seems people are using lgt springs on the obxt struts. I am planning on buying the kyb's for a legacy and using buying new lgt wagon springs. is that a good idea? there are a lot of threads about this, but everyone is doing different things and contradicting each other. I am trying to get all my fact straight before I start anything. Link to comment Share on other sites More sharing options...
Nightmaresmk Posted February 1, 2015 Share Posted February 1, 2015 Wide large tires i have to run oem outback springs for now. Link to comment Share on other sites More sharing options...
Rhitter Posted February 1, 2015 Share Posted February 1, 2015 it seems people are using lgt springs on the obxt struts. I am planning on buying the kyb's for a legacy and using buying new lgt wagon springs. is that a good idea? there are a lot of threads about this, but everyone is doing different things and contradicting each other. I am trying to get all my fact straight before I start anything. They aren't contradicting each other. They have different goals. If you don't mind the low ride height, KYB legacy struts with Legacy wagon springs and a 1/2 inch saggy butt spacers is a great set-up. A better one would be to get some blown legacy struts and Koni inserts with Legacy Wagon springs and a 1/2 inch saggy butt spacer. If the Legacy ride height is too low for you that's where all the different set-ups are coming in. My OBXT build Link to comment Share on other sites More sharing options...
Nightmaresmk Posted February 2, 2015 Share Posted February 2, 2015 I would do legacy struts over outback struts because legacy has better options and more control. Outback- KYB or stock Legacy- Bilstein Koni plus kyb and stock Bilstein HD's with outback springs or koni for adjust-ability. Link to comment Share on other sites More sharing options...
b4wantab Posted February 4, 2015 Share Posted February 4, 2015 it seems people are using lgt springs on the obxt struts. I am planning on buying the kyb's for a legacy and using buying new lgt wagon springs. is that a good idea? there are a lot of threads about this, but everyone is doing different things and contradicting each other. I am trying to get all my fact straight before I start anything. I agree with OB2.5XT, don't think there is contradiction. Just different goals at different price points. There are reasonable mods that can be done relatively cheaply. So, why not try it, some stop there others move in different directions. Basically anything over stock is a vast improvement I have an Bean with the H6, OB struts (KYB's, 05s in front 04s in rear) with LGT springs lowered the front 1 1/8" and the rear 7/8". Very manageable and great mod. Peace, Greg Link to comment Share on other sites More sharing options...
Beacho Posted February 5, 2015 Share Posted February 5, 2015 Agreed with what Greg said. At the time, the Rallitek springs weren't available and LGT springs can be found for a reasonable price. I didn't want my OB to GT height either, hence the LGT springs on OB KYB struts. I did a ton of research and that's the route I went. Good luck with whatever you decide Mike Link to comment Share on other sites More sharing options...
