Kelvrick Posted January 4, 2013 Share Posted January 4, 2013 To be clear, you're putting oem legacy wagon springs on kyb outback replacement shocks (05+ for front, 04 for back), right? From reading what you said, I think I might be happier just getting rid of outback parts and using spacers to get the height I want. Maybe koni dampers with oem legacy wagon springs and spacers. My Outback Link to comment Share on other sites More sharing options...
Oregon OBXT Posted January 5, 2013 Author Share Posted January 5, 2013 To be clear, you're putting oem legacy wagon springs on kyb outback replacement shocks (05+ for front, 04 for back), right? From reading what you said, I think I might be happier just getting rid of outback parts and using spacers to get the height I want. Maybe koni dampers with oem legacy wagon springs and spacers. Yep, 05 LGT wagon springs on 05/04 KYB struts. If you're looking for extra firm this isn't for you. If you want to firm it up slightly while lowering it and retaining a comfortable ride then it's perfect. And economical. Looking forward to see what bars will do for it. Link to comment Share on other sites More sharing options...
Heffernan Posted April 18, 2013 Share Posted April 18, 2013 Bump this for pics! Looking to do the same thing. Link to comment Share on other sites More sharing options...
oclvframe Posted April 24, 2013 Share Posted April 24, 2013 Can you post pictures? Also, did you get it properly aligned after the swap? If so, what were your camber and toe final values? Last, did the drop affect your steering geometry much? Dd you have to put in a roll center kit to correct angles? -r Link to comment Share on other sites More sharing options...
Mad Matt Posted May 16, 2013 Share Posted May 16, 2013 Looking for lower, but not harsher ride. Want to improve the suspension geometry but still have the ability to plow over Michigan's canyon sized potholes. Was originally thinking that OB springs on Leggy dampers might be a good option if I could get them assembled. I am wondering how different your setup is from just going with all stock Leggy. Link to comment Share on other sites More sharing options...
Mad Matt Posted May 16, 2013 Share Posted May 16, 2013 Oh, and pics please! Link to comment Share on other sites More sharing options...
Heffernan Posted June 18, 2013 Share Posted June 18, 2013 Would still like to see pics... Link to comment Share on other sites More sharing options...
Sideways the Seven Posted June 18, 2013 Share Posted June 18, 2013 The taller Outback springs squeezed onto the LGT dampers sounds like a stiff, bouncy ride. Sent from my SGH-T699 using Tapatalk 2 -Brandon 2007 Chevrolet Suburban LT3 1981 Chevrolet C10 LWB Link to comment Share on other sites More sharing options...
Heffernan Posted June 19, 2013 Share Posted June 19, 2013 Its actually the other way around. Outback spec KYB struts and LGT springs. Link to comment Share on other sites More sharing options...
Nightmaresmk Posted June 19, 2013 Share Posted June 19, 2013 OBXT springs combined with Bilstien HD's or Koni struts should be fine. KYB's are a question. Link to comment Share on other sites More sharing options...
Sideways the Seven Posted June 19, 2013 Share Posted June 19, 2013 Its actually the other way around. Outback spec KYB struts and LGT springs. It will work, but the shorter LGT springs will be underdamped with the KYBs Sent from my SGH-T699 using Tapatalk 2 -Brandon 2007 Chevrolet Suburban LT3 1981 Chevrolet C10 LWB Link to comment Share on other sites More sharing options...
b4wantab Posted December 4, 2013 Share Posted December 4, 2013 Sorry to bump this back from the dead. Oregon how about an update? I am new to the 3rd gen and am looking to improve handling at a reasonable cost. I am came from a 2nd gen GT wagon, don't think I will get to that level. But I am looking for options. Thanks, peace, Greg Link to comment Share on other sites More sharing options...
Oregon OBXT Posted December 4, 2013 Author Share Posted December 4, 2013 Hey guys! Been off the forum for a while. I really like the setup. It's lowered enough to look different without looking 'slammed'. Ride quality is a little more stiff but far from objectionable. Really enjoy driving the car. http://img.tapatalk.com/d/13/12/05/ytabaruj.jpghttp://img.tapatalk.com/d/13/12/05/adyryruv.jpg Link to comment Share on other sites More sharing options...
b4wantab Posted April 25, 2014 Share Posted April 25, 2014 Sorry to bump from the dead. However, I finally got around to doing this and am very happy with the results. It ended up lowering the back 7/8" and the front 1 1/4". I have newer OB spec KYBs all around, with the rears being second gen units. Now I am at 29" ground to wheel well in the rear and 27 3/4" in the front. I will get an alignment in the next week or so, I am sure the toe is way out in the rear. However, the non-calibrated butt-g-force meter likes the ride. More responsive and less wallow. I will try to get a pic or two up when I can. My measure showed OB springs: Front @ 13 1/8" Rear @ 14 1/2" The GT wagon spring I put on: Front @ 11" Rear @ 12 5/8" Peace, Greg Link to comment Share on other sites More sharing options...
Nightmaresmk Posted April 26, 2014 Share Posted April 26, 2014 Nice. Link to comment Share on other sites More sharing options...
Beacho Posted June 14, 2014 Share Posted June 14, 2014 This looks perfect and after doing a ton of research this is the way I'm going to go. 2 questions; where did you guy get your LGT springs at? I think I tracked down the correct P/Ns I have, F- Part Number: 20330AG02A, R- Part Number: 20380AG01A, R- Part Number: 20380AG05A... anyone confirm? Link to comment Share on other sites More sharing options...
b4wantab Posted June 25, 2014 Share Posted June 25, 2014 Sorry can't confirm the PNs. I just keep an eye out on the classifieds. Here are some pics of a bean next to my bean. Hope these pics work. Link to comment Share on other sites More sharing options...
Beacho Posted June 26, 2014 Share Posted June 26, 2014 Sorry can't confirm the PNs. I just keep an eye out on the classifieds. Here are some pics of a bean next to my bean. Hope these pics work. Looks really good! I got the part numbers confirmed; fronts= 20330AG02A and rears = 20380AG05A. Link to comment Share on other sites More sharing options...
b4wantab Posted June 26, 2014 Share Posted June 26, 2014 compsurge has 05 wagon springs he will part with, go over to the classifieds. There is a guy looking for a complete wagon suspension and people are chiming in about struts and springs or just springs. Not sure if they are LGT or just Legacy wagon. Don't know if springs were different between LGT and Legacy. In the 2nd gen the springs were the same and the struts were different. Peace, Greg Link to comment Share on other sites More sharing options...
Beacho Posted June 26, 2014 Share Posted June 26, 2014 compsurge has 05 wagon springs he will part with, go over to the classifieds. There is a guy looking for a complete wagon suspension and people are chiming in about struts and springs or just springs. Not sure if they are LGT or just Legacy wagon. Don't know if springs were different between LGT and Legacy. In the 2nd gen the springs were the same and the struts were different. Peace, Greg Im on it Now to order my KYBs. Has anyone done the LGT sway bars as well? Opinions or just jump to an aftermarket bar? Thanks Mike Link to comment Share on other sites More sharing options...
Rhitter Posted June 26, 2014 Share Posted June 26, 2014 I don't think the difference is enough. I think it's something like oem outback is 15 and oem lgt is 16. I could be wrong. I jumped right to aftermarket and it made a huge difference in the way the car handles and feels. OEM the rear would sway behind you around turns (super noticeable around turns) Aftermarket the rear feels like it stays right in line with the car and turns with you (instead of swaying off to the side). I should have done it much much sooner. It makes a very noticeable difference in the feel and balance of the car. I got the whiteline adjustable and will be putting it on the stiffer setting next weekend. My OBXT build Link to comment Share on other sites More sharing options...
Beacho Posted July 4, 2014 Share Posted July 4, 2014 Sorry to bump from the dead. However, I finally got around to doing this and am very happy with the results. It ended up lowering the back 7/8" and the front 1 1/4". I have newer OB spec KYBs all around, with the rears being second gen units. Now I am at 29" ground to wheel well in the rear and 27 3/4" in the front. I will get an alignment in the next week or so, I am sure the toe is way out in the rear. However, the non-calibrated butt-g-force meter likes the ride. More responsive and less wallow. I will try to get a pic or two up when I can. My measure showed OB springs: Front @ 13 1/8" Rear @ 14 1/2" The GT wagon spring I put on: Front @ 11" Rear @ 12 5/8" Peace, Greg Greg, I was doing some searching and came across this post, Im assuming you over on OB; http://www.subaruoutback.org/forums/81-wheels-tires-brakes-suspension/28368-2005-2009-outback-suspension-faq-27.html#post1071146 How much better does the car feel now with the LGT springs? Do you recommend doing the KCA399 bushings? Did you do anything to the bumpstops? Also, looks like you did the LGT RSB as well, thoughts? My springs are found and bought, ordering shocks mid July and have the install set for end of July. Thanks Mike Link to comment Share on other sites More sharing options...
b4wantab Posted July 7, 2014 Share Posted July 7, 2014 Yup that is me. I think/feel the car is 2-3 times better than stock. Half of that probable comes from the lowering alone. I just feels more stable. Now I also came from a 02 GT wagon so I had high hopes of control. I needed the bushings to get the rear toe and camber in spec. So yes I would recommend them. The rear toe is the biggie to me. The suspension is just sensitive to rear toe. I didn't cut the bump-stops. I was going to wait and see how it road. I haven't bottomed-out yet. I actually forgot that I was keeping and eye on them. I did the RSB because it was free. I am looking to go bigger with aftermarket options. Peace, Greg Link to comment Share on other sites More sharing options...
Beacho Posted December 7, 2014 Share Posted December 7, 2014 Im gonna bump this, I just installed my LGT springs on KYB 05/09 fronts and 04 Rears, I also installed a 25mm front Tribeca bar w/Kartboy endlinks and a WL RSB with Kartboy endlinks. I cant believe how much better this car drives now. Its definitely firmer then stock, but doesnt ride like a slammed car. My pregnant wife noticed the difference and didnt find the ride to be to harsh. Here's a dirty picture right after I finished. I need to get it aligned this week and my WL KCA399 bushings installed. I also have a spring popping sound in the front left that I need to find out where the noise is coming from. http://i13.photobucket.com/albums/a265/mikebeach/20141206_123619.jpg LGT brakes next and then Im done with the car for a while Link to comment Share on other sites More sharing options...
NoRoadtrippin Posted January 27, 2015 Share Posted January 27, 2015 So for an '09 OBXT... 1. Outback model KYB's...from the correct year as listed wherever I order from? 2. LGT springs...from any '05-'09 model year? 3. Whiteline KCA399 bushings And with these three items, I should be good to go and get the 1 1/4" up front and 7/8" in the back? And then be able to get a decent alignment on? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
