Blumpkin Posted November 5, 2012 Share Posted November 5, 2012 So I am just trying to verify with yall, an 06+ sti intake manifold would fit onto my 08 right? Link to comment Share on other sites More sharing options...
underground000 Posted November 5, 2012 Share Posted November 5, 2012 Need intercooler and turbo then yea Why u want an sti manifold?? 5eat downshift rev match:) Powder coated wheels: completed:) Link to comment Share on other sites More sharing options...
Blumpkin Posted November 6, 2012 Author Share Posted November 6, 2012 Why u want an sti manifold?? I want a non-plastic manifold Link to comment Share on other sites More sharing options...
famaya26 Posted November 6, 2012 Share Posted November 6, 2012 Isn't the OEM plastic one more efficient? Link to comment Share on other sites More sharing options...
MooKz Posted November 6, 2012 Share Posted November 6, 2012 Isn't the OEM plastic one more efficient? It's been said, but I would like to see a flow chart sometime. Our manifolds are Drive-By-Wire though. What year did the STi start receiving DBW? Link to comment Share on other sites More sharing options...
Y4555 Posted November 6, 2012 Share Posted November 6, 2012 I have an 06 sti intake on my 05 wagon and the runners measured 2mm larger in internal diameter than the oem plastic one. IRC the 08+ Sti has a better oem map sensor if you aren't already upgraded. Link to comment Share on other sites More sharing options...
Nrw Posted November 6, 2012 Share Posted November 6, 2012 it's been said, but i would like to see a flow chart sometime. Our manifolds are drive-by-wire though. What year did the sti start receiving dbw? 2004 Link to comment Share on other sites More sharing options...
MooKz Posted November 6, 2012 Share Posted November 6, 2012 Hmm That's odd. The reason I heard of ours flowing better is because the ceramic material that the manifold is made of is hotter than the plastic ours are made of. Who knows? I want the STi manifold so I can have a nice powder coated set of runners. Link to comment Share on other sites More sharing options...
Blumpkin Posted November 6, 2012 Author Share Posted November 6, 2012 ^^ that as well Link to comment Share on other sites More sharing options...
ripemeat Posted November 6, 2012 Share Posted November 6, 2012 certainly not worth the time and effort. Link to comment Share on other sites More sharing options...
MooKz Posted November 6, 2012 Share Posted November 6, 2012 It's worth it if you have bling under the hood. My dad always says, "Do what you can afford." So I'll be buying one and powdercoating it white and getting phenolic spacers. Link to comment Share on other sites More sharing options...
Strizzy Posted November 6, 2012 Share Posted November 6, 2012 Manifold flow comparisons: http://forums.nasioc.com/forums/showthread.php?t=2229576 I'm using a manifold from a 07 Legacy 2.5i. I had to drill out the TGV bolt holes a bit, but it fits like OEM. I'm also running a 3" Perrin inlet to a stock location 30r. I also have 8mm TGV spacers. http://www.strizzyphoto.com/photos/i-wRsh2HC/0/L/i-wRsh2HC-L.jpg http://www.strizzyphoto.com/photos/i-Qb2SSNs/0/L/i-Qb2SSNs-L.jpg My bad luck build Link to comment Share on other sites More sharing options...
MooKz Posted November 6, 2012 Share Posted November 6, 2012 Yeah Moore Performance in Pittsburgh fabbed a newer RS manifold with the big tubes to run on their STi. Link to comment Share on other sites More sharing options...
