2furious Posted October 26, 2012 Share Posted October 26, 2012 One of the gasket from Y to the can was shot. I tried to buy one but not sure what the size was? Is it 2.5 or 3". I guess it was 2.5" diameter.... From Desert to Rocky to SLC !!! Link to comment Share on other sites More sharing options...
Max Capacity Posted October 26, 2012 Share Posted October 26, 2012 Thats a good guess. It may even be 2" I would think most auto parts stores should have something that will fit. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
BigBad Posted October 27, 2012 Share Posted October 27, 2012 Its a 2.5" at the Y, 3" where the Y meets the main pipe. I've replaced mine a couple of times now. If you get the gaskets through Greddy its technically 60 mm at the Y and 70mm where the Y meets the main pipe. Link to comment Share on other sites More sharing options...
