A_A_ron Posted September 6, 2017 Share Posted September 6, 2017 Amazing bit of info. I wonder what exactly they are doing for reverse in this transmission. Build Thread Link to comment Share on other sites More sharing options...
GTEASER Posted September 6, 2017 Share Posted September 6, 2017 magic. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
cww516 Posted September 6, 2017 Share Posted September 6, 2017 From the looks of it, it has the teeth like you'd get on a synchronized gear, but not the synchro plate itself. Shifting into reverse when stopped is pretty much the same as shifting into a forward gear while moving, but manually rev-matching, so they synchro doesn't actually do anything. Link to comment Share on other sites More sharing options...
BBPeik Posted September 7, 2017 Share Posted September 7, 2017 FWIW I opened up my trans before the STI swap. These are a super easy trans to open and rebuild if needed. I have the gear assemblies sitting in the garage. Let me know if you would like some pics of them to give you a better idea about the reverse gear setup. My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
A_A_ron Posted September 7, 2017 Share Posted September 7, 2017 FWIW I opened up my trans before the STI swap. These are a super easy trans to open and rebuild if needed. I have the gear assemblies sitting in the garage. Let me know if you would like some pics of them to give you a better idea about the reverse gear setup. Yes please. I am seriously considering trying to do this myself as it's going to cost 8 hours of labor just to have the dealership look at it. If you wouldn't sending me or posting pictures of the reverse gear assembly and maybe a fun down on the tools needed. I am considering picking up a transmission jack. Build Thread Link to comment Share on other sites More sharing options...
A_A_ron Posted September 7, 2017 Share Posted September 7, 2017 magic. I don't think it's right but I also don't know enough about transmissions to prove it wrong. I guess you're right. Build Thread Link to comment Share on other sites More sharing options...
BBPeik Posted September 7, 2017 Share Posted September 7, 2017 Here are a couple pics. One is just a pic of the case open and the gears and diff sitting there, just for reference. The next pic is the actual gear assemblies. The top set is the engine side of the gears. Reverse is towards the left of that set. As far as tools it is pretty basic. 12,14, maybe a 17mm socket, can;t remember for sure. You will need something to support the engine while the transmission is out though. My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
A_A_ron Posted September 8, 2017 Share Posted September 8, 2017 Thanks for the photos. I think I'll need a beater car to drive around while I have the transmission pulled if I do it myself. There's no way I'm getting that taken care of in a single day. Build Thread Link to comment Share on other sites More sharing options...
FLlegacy Posted September 10, 2017 Share Posted September 10, 2017 Have you tried a different fluid yet? It might help. Link to comment Share on other sites More sharing options...
A_A_ron Posted September 11, 2017 Share Posted September 11, 2017 Have you tried a different fluid yet? It might help. No I haven't tried that yet. Might have to do that this weekend. Build Thread Link to comment Share on other sites More sharing options...
A_A_ron Posted October 5, 2017 Share Posted October 5, 2017 Section CS95-CS100 of the factory service manual refers to cable adjustment. If you need the PDF I can try to post it. Do you still have a pdf of this section? Build Thread Link to comment Share on other sites More sharing options...
GTEASER Posted October 5, 2017 Share Posted October 5, 2017 Do you still have a pdf of this section?Just download a FSM. And then you have it all. PM cww916, or 516, he can give you the link. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
cww516 Posted October 5, 2017 Share Posted October 5, 2017 You rang? A_A_ron, PM inbound. Link to comment Share on other sites More sharing options...
A_A_ron Posted October 17, 2017 Share Posted October 17, 2017 So after a long talk with my transmission shop they informed me of a few interesting things. Their go to re-manufacture company has done 5 of these transmissions with the same issue and they have all come back within 30 days, even when they use the new Subaru parts that were supposed to fix the issue. I have bought a used transmission from California with 81k miles on it. LGT was rear ended. RIP in piece but I'm glad it chose to be an organ donor. My shop is swapping them out this week. I ended up going with the BG syncro shift gear lube. They did let me know my motor mounts are just about blown so I am trying to find part numbers for compatible motor mounts that I can get relatively quickly. Any help is appreciated. Build Thread Link to comment Share on other sites More sharing options...
GTEASER Posted October 17, 2017 Share Posted October 17, 2017 Nothing compatible as far as engine mounts. They are unique to the 5th Gen. OEM or HardRace are your only options. BigBopper adapted Group N mounts to our platform but it required custom machined adapters. Did you get the transmission from AutoGator or somewhere else here in CA? GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
A_A_ron Posted October 17, 2017 Share Posted October 17, 2017 What about transmission mounts? Build Thread Link to comment Share on other sites More sharing options...
GTEASER Posted October 17, 2017 Share Posted October 17, 2017 What about transmission mounts?Stock or Group N 5-speed fits our cars. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
