tonybuttons Posted October 16, 2012 Share Posted October 16, 2012 So... I know, I know. But I had some questions and I found a set of 7.5 watt LED H7 lamps on Ebay for under 15 dollars, and I couldn't resist. Overall conclusion: Not to be used. A couple of observations: It did light in the drl setting, but it was dim and blinky. When in full lowbeam headlight mode, it looked way bluer behind the projector, and didn't kick out nearly enough light. Are the projector lenses tinted? It was really pretty bright outside of the housing. I took a few pictures, but I'm only posting one, because it shows the light output against a wall, and that's all you need to tell you that you can't use it. Oh well... DRL disable and HID's here I come. Link to comment Share on other sites More sharing options...
Gire Posted October 16, 2012 Share Posted October 16, 2012 Conclusion: junk. Thanks for sharing. Honestly. LED lighting when done right is effective. But there is a big difference between what Porsche puts in their cars and this 15 buck eBay experiment. Link to comment Share on other sites More sharing options...
Drift Motion Posted October 16, 2012 Share Posted October 16, 2012 if you have gotten some $200 LEDs, then it'll be bright as hell my friend did that mod on his Genesis... Link to comment Share on other sites More sharing options...
blacksun Posted October 24, 2012 Share Posted October 24, 2012 Has anyone tried the CREE LEDs in the high beam? Link to comment Share on other sites More sharing options...
SCHM1AN Posted October 24, 2012 Share Posted October 24, 2012 Never heard of them-- I just checked the CREE LEDs out and they look like they have some serious potential! Link to comment Share on other sites More sharing options...
tonybuttons Posted October 25, 2012 Author Share Posted October 25, 2012 I actually found the same 7.5 watt LED for the high beam, and it works a lot a better in the reflector than behind the projector, but still isn't incredibly bright... I did a test in the dark and it does throw more light to sides and higher up, but I wouldn't use them if I actually needed to see more. I left them them in because I never use them, they look kind of cool with the aluminum housing, and they match the color of the HID H7's I got. Link to comment Share on other sites More sharing options...
