06legsleeper Posted October 13, 2012 Share Posted October 13, 2012 as stated above i bought a, ap v1 off a member good price fast shipping .. but besides that ... i plug the power wire into the wall just to check what maps were on it .. has 3 maps which is good ... the 4th map says married stock mode... is that normal ? now he said it was unmarried so .... i first turn it on i get (choose a new map to flash to the ecu ) ive looked into it and i just want to make sure its unmarried i seen that if its still married to the ecu u wont get the choose new map to flash screen .. anyone else have any input on this any help would be appreciated Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted October 13, 2012 Moderators Share Posted October 13, 2012 Geez. ESL combined with too lazy to spell out Philadelphia. Yikes. I have no input for you, sorry. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
.blackgt. Posted October 13, 2012 Share Posted October 13, 2012 Sounds like you should be fine. If it doesn't immediately block you as soon as it is plugged in, I think you are okay. Link to comment Share on other sites More sharing options...
.blackgt. Posted October 13, 2012 Share Posted October 13, 2012 You should have also asked for a picture of the AP in the car showing the unmarrying process at the least. Link to comment Share on other sites More sharing options...
technicalgarage Posted October 13, 2012 Share Posted October 13, 2012 As far as I can remember thats completely normal for an unmarried apv1. When you connect it to the car, you'll have to select the map you want to flash and it will marry it using that map (you can then switch to any of the others again using the ap). Once married your ap will show more options in the menu. Married stock mode is just there to run stock rom values without having to unmarry the AP (which takes a loooong time ~20 mins on an apv1). Link to comment Share on other sites More sharing options...
Max Capacity Posted October 13, 2012 Share Posted October 13, 2012 You should use the trade in program at Cobb and up grade it. Check out Cobbs site for the manual for it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
project13 Posted October 15, 2012 Share Posted October 15, 2012 The ver 1 you just bought is just fine. conect the green test wire, plug in the AP to the car, turn the car on, but dont start, pick your map and press enter. when done do in reverse, start the car and drive and do a 3rd gear pull, pull over and re start the car and it should be good to go. later if you upgrade just pay for a cobb AP, have them send it to you with maps pr loaded, then you can just write over the ver 1 maps and ren th enew AP, just send the old one in for a refund. Link to comment Share on other sites More sharing options...
