locolgt2.5 Posted October 2, 2012 Share Posted October 2, 2012 Does anybonr know if the JDM brembos from a sti Will fit on a 2005 legacy gt with out any modificatons or brackets? Thanks for the help. Link to comment Share on other sites More sharing options...
Whatisit Posted October 2, 2012 Share Posted October 2, 2012 jdm brembo's are identical to usdm brembo's Link to comment Share on other sites More sharing options...
V8lolsubie Posted October 2, 2012 Share Posted October 2, 2012 JDM Version 8 Brembos on my car. Straight forward install, same calipers. You will obviously need to follow the same procedure for the rears in that some mods and brackets will need to be employed. Link to comment Share on other sites More sharing options...
locolgt2.5 Posted October 2, 2012 Author Share Posted October 2, 2012 Thanks guys I have a full set that I'm getting for 600. I did not know if hey would fit. Where can I get the brackets? Link to comment Share on other sites More sharing options...
Whatisit Posted October 3, 2012 Share Posted October 3, 2012 As long as you have brake rotors from a 2004 sti (they have the 5x100 holes) The fronts are plug and play. as for the rears you have 2 options... you can get brackets for the calipers, and then special brake shoes for the e-brake so that you can use the oem 2004 sti brake rotors. or you can get brackets for the calipers and new brake rotors that are special so that you can use your oem legacy brake shoe's. i went with option #1 from Onkelracing.com (also can go to knsbrakes.com and buy from them as i just realized onkelracing is banned from this site) . Also please note that the stainless steel brake lines for the rear are not the same as either STI or LEGACY. you need to buy a custom setup sold by Magentic1 (also a user on here). i got the full stainless steel front and rear set from him. Link to comment Share on other sites More sharing options...
Guest Posted October 10, 2012 Share Posted October 10, 2012 Indeed I just noticed my original vendor account OnkelRacing has been "banned". I have not been actively selling/advertising the product here so I did not think this was a problem. Anyway if anyone has technical questions about the adapter parking shoes please feel free to contact me. And, yes, KNS has been re-selling the shoes I have been making. Link to comment Share on other sites More sharing options...
scobaru5 Posted October 11, 2012 Share Posted October 11, 2012 wow 600 thats super cheap, did it come with rotors? Link to comment Share on other sites More sharing options...
locolgt2.5 Posted October 15, 2012 Author Share Posted October 15, 2012 No it didn't come with rotors, I need to find some now. Link to comment Share on other sites More sharing options...
510Finn Posted January 30, 2013 Share Posted January 30, 2013 As long as you have brake rotors from a 2004 sti (they have the 5x100 holes) The fronts are plug and play. as for the rears you have 2 options... you can get brackets for the calipers, and then special brake shoes for the e-brake so that you can use the oem 2004 sti brake rotors. From my research I found out that the rear brake shoes fit 170mm diameter, the '04 STi use 190mm diameter for the rear brake shoes, hence the 20mm thicker rear parking brake shoes. Is there a link to where these rear shoes are sold? or you can get brackets for the calipers and new brake rotors that are special so that you can use your oem legacy brake shoe's. i went with option #1 from Onkelracing.com (also can go to knsbrakes.com and buy from them as i just realized onkelracing is banned from this site) . Also please note that the stainless steel brake lines for the rear are not the same as either STI or LEGACY. you need to buy a custom setup sold by Magentic1 (also a user on here). i got the full stainless steel front and rear set from him. The special rotors are basically, 316mm which use a 170mm rear brake drum with 5x100 bolt pattern. DBA 42657 SL/SR but they a little pricey, around $195 each. I know KNS has this setup too, but shipping to the west coast from NC is pricey. Is there any other vendors who might carry these parts? Lastly, anything else I haven't covered here? 08 Spec B details Link to comment Share on other sites More sharing options...
Waxiboy Posted January 31, 2013 Share Posted January 31, 2013 rear brake hose http://legacygt.com/forums/showpost.php?p=2702189&postcount=124 Link to comment Share on other sites More sharing options...
