1996 Subaru Legacy L Wagon AWD 4" Lift
Sounds good! I wasn't sure if the 2 black wires were the ones that went to the side marker, but looks pretty straight forward!
I don't make it to Telluride much, but might be worth a trip sometime soon!
  • Replies 408
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
So, I had this idea to replace all the rear bulbs with LEDs. On eBay.com I found 2 sets of 2 (1157) Brake/Tail lights for total $14.00. The 4 (1156) front and rear Blinkers and Backup LED bulbs for total $16.75 that should be here tomorrow and the (168) license plate bulbs 2 for total $18.00 that should be here week also.
I just installed the four Brake/Tail bulbs. They look great and should never burn out, they use less energy and no filament to break. And all for about 50 bucks. not bad, ha. What do you think?
http://srvtelluride.dyndns.org/Subaru/LEDbulbs1.jpg
http://srvtelluride.dyndns.org/Subaru/LEDbulbs2.jpg
http://srvtelluride.dyndns.org/Subaru/LEDbulbs3.jpg
http://srvtelluride.dyndns.org/Subaru/LEDbulbs4.jpg
Edited by swcolegacyl
Looks good! I have been slowly converting everything to LED's myself. I have already replaced the 2 backup lights, and all 4 bulbs in the 3rd brake light. I have the rear turn signals on order. Only concern I have had about the rest of the lights... do the LED's have the same light output as the bulbs did? Or do they seem to be a bit more dim? I know the 3rd brake lights I have look almost identical in output as bulbs, and my backup lights are about 5 times brighter than the stock bulbs, but the others seem like they may not be as good.
And of course I will have to post some pics soon!! And if the weather holds up, I'm installing my side marker lights this weekend, and have some LED's for those as well!
Hi 1692, not all LED bulbs are created equal. The brake/tail bulbs work great and are very bright. The bulbs I got today, not so bright. I tried putting in the blinker socket and the blinkers, blink very fast. Then I learned that I need to install a “load resister” 50W 60HM Load resister ($10.00 for 4 on eBay.com) because the LED bulbs use too little power. The same bulb is used as backup lights. And nowhere near bright enough to use as backup bulbs. I’ll have to keep looking.
I still have to track down the 3rd brake lights bulbs. Are they the same as the license plate bulbs?
http://srvtelluride.dyndns.org/Subaru/blinkerbulbs.jpg
50W 60HM Load Resisters on order:
http://srvtelluride.dyndns.org/Subaru/loadresister.jpg
EDIT>>
>>Just picked up the new LED Plate lights: I'll install them tomorrow, too cold out now.
http://srvtelluride.dyndns.org/Subaru/PlateLights.jpg
EDIT>>
>>Have some new LED blinker and backup bulbs on the way, they should much brighter then the other ones.
http://srvtelluride.dyndns.org/Subaru/sku021298_1.jpg
OK, i got the new LED plate lights installed. They look pretty good. I ordered 2 sets by mistake. But the bulbs happen to be the same as the 3rd brake lights.
http://srvtelluride.dyndns.org/Subaru/PlateLights3.jpg
http://srvtelluride.dyndns.org/Subaru/PlateLights2.jpg
http://srvtelluride.dyndns.org/Subaru/PlateLights4.jpg
3rd Brake light
http://srvtelluride.dyndns.org/Subaru/PlateLights5.jpg
http://srvtelluride.dyndns.org/Subaru/PlateLights6.jpg
Looks great! They are the same lights so that makes it easier! I have been buying from one specific user on ebay that has had the best quality lights (and it looks like some of yours might have come from them too!
http://www.ebay.com/sch/dt-autotech/m.html?_nkw=&_armrs=1&_ipg=&_from=
I bought these for the 1156 back-up lights:
http://www.ebay.com/itm/1156-High-Power-Samsung-SMD-Cree-LED-White-Turn-Signal-Brake-Tail-Lights-Bulbs-/330998095876?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d11062004
These for the License plates:
http://www.ebay.com/itm/2X-WHITE-T10-6000K-LED-LICENSE-PLATE-LIGHT-BULBS-5-LED-/330718779718?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d00601946
These for the 3rd brake light (and the amber version for the side marker lights):
http://www.ebay.com/itm/SAMSUNG-WHITE-LED-T10-921-LICENSE-PLATE-INTERIOR-SMD-LIGHT-BULBS-BULB-HIGH-POWER-/191050704698?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c7b82673a
All of these have been so much brighter than with other users products, and I have more plans to convert even more of my lights to LED's soon too!
Pics to come very soon!
I'm thinking of getting these next for the rear turn signal:
http://www.ebay.com/itm/1156-Projector-Samsung-Chip-LED-Yellow-Amber-Turn-Signal-Brake-Tail-Lights-Bulbs-/231115946594?pt=Motors_Car_Truck_Parts_Accessories&hash=item35cf957a62
I was debating on doing the load resistors on each of the lights, but I think I'm going to switch out the turn signal relay instead and see if that will be enough to not have the rapid flash.
Just a side note, got my side markers done today... in one of the breaks in the snow that we briefly had! Of course had to put LED's in there as well! Thanks for your write up, it helped a lot!
Hi 1692, your welcome. Still waiting on the blinker/backup LED bulbs for my car. The Post Office lost the last set i ordered. Oh well, they reimbursed me and another set is on the way. But i did get all the rest of the bulbs replaced with LEDs: 3rd brake/4 main brake/tail lights and plate lights. I also received the Load resisters for the blinker LEDs.
http://srvtelluride.dyndns.org/Subaru/RearLights.jpg
http://srvtelluride.dyndns.org/Subaru/LoadResisters.jpg
The new 1156 LED replacements showed up today. I have to install the load resisters with blinkers. maybe i'll get to it tomorrow. I tested them and they are very bright. These 4 are the last of the rear lights to be changed to LEDs. 2 for the blinkers and 2 for the backup lights.
http://srvtelluride.dyndns.org/Subaru/NewBlinkers.jpg
  • 3 weeks later...
So, the bulb to the left is 1 of a new set I got yesterday for the blinkers. The blinkers bulbs I had been using is the one in the middle. But that style seems to work much better for the backup and brake/tail bulb. It has kind of does a weird pulsing and not quite bright enough for the blinker lens. The bulb to the right i ordered thinking it would be a bit brighter, but the LEDs are very small. Good thing that most of the LED bulbs i've ordered have been fairly inexpensive, averaging about $4.00 a piece.
http://srvtelluride.dyndns.org/Subaru/NewLED.jpg
  • 1 month later...
Hi, been a while. 19,000 hits on this thread, Amazing. Thank you all
About 2 years ago in Moab, UT. I met the owner of the Subaru below. I asked where he got the very cool bumper on his car. He told me about an Oregon welder that built his Baja bumper. I contacted the guy and he's no longer making the bumper. So i tracked down a company locally that can build the same bumper for me. with a little twist: I'm installing a winch. My Subaru is headed to the shop this morning to get the new bumper built.
http://srvtelluride.dyndns.org/Subaru/4000LBWinch.jpg
http://srvtelluride.dyndns.org/Subaru/MoabSubaru.jpg
that is great. i just got my car out of the garage this weekend.....4 inch lift and forester struts...now i need bigger tires....need to look at some wheels that have different back spacing to hopefully clear the perches.
Hi natetru, Love to see some pics of your car. i might install Forester struts in my car also.
The new bumper is being built. the bumper is pretty much complete, but it still need to be powder coated.
http://srvtelluride.dyndns.org/Subaru/NewBumper1.jpg
http://srvtelluride.dyndns.org/Subaru/NewBumper2.jpg
http://srvtelluride.dyndns.org/Subaru/NewBumper3.jpg
http://srvtelluride.dyndns.org/Subaru/NewBumper4.jpg
http://srvtelluride.dyndns.org/Subaru/NewBumper5.jpg
Got a few more pics from the shop today. Off to be power-coaded tomorrow. also a scooped hood is on the way.
http://srvtelluride.dyndns.org/Subaru/NewBumper6.jpg
http://srvtelluride.dyndns.org/Subaru/NewBumper7.jpg
The guys at Rockworx in Montrose, Co. did an amazing job. I still have some wiring for the winch to do and some new LED spots to install.
It looks so different now. Doubt that the previous owner would recognize it.
Way Before:
http://srvtelluride.dyndns.org/Subaru/oldfront.jpg
Before:
http://srvtelluride.dyndns.org/Subaru/theride.jpg
After:
http://srvtelluride.dyndns.org/Subaru/HoodBumper1.jpg
http://srvtelluride.dyndns.org/Subaru/HoodBumper2.jpg
http://srvtelluride.dyndns.org/Subaru/HoodBumper3.jpg
http://srvtelluride.dyndns.org/Subaru/BumperFront.jpg
Just got the new LEDs installed.
http://srvtelluride.dyndns.org/Subaru/Front.jpg
  • 2 weeks later...
Over in Moab, UT this weekend. I took the the Subaru out to Slickrock to play. Fins 'N Things trail:
http://srvtelluride.dyndns.org/Subaru/Moab.jpg
http://srvtelluride.dyndns.org/Subaru/Moab2.jpg
And I took a drive out to Islands in the sky in Canyonlands.
http://srvtelluride.dyndns.org/Subaru/CLMoab.jpg
  • 3 weeks later...
Put on cool new SUBARU Racing logo stickers. eBay.com $18.00
Replaced the front brakes with’98 Outback dual-piston calipers and new Outback front disks and pads. (Outback disks are about 1” larger in diameter then the '96 Legacy) And new rear pads.
Replaced heater blower fan. It's been squealing since i bought the car. And i finally got around to replacing it. eBay.com $50.00
And I got the Solar system wired. I already had the charge controller installed under the hood. But now I have a Solar panel connection on the roof rack. So when I’m out camping I can now keep the battery charged up.
http://srvtelluride.dyndns.org/Subaru/FrontLeft.jpg
2 10 Watt panels tied together in parallel for a total of 20 Watts at about 20VDC:
http://srvtelluride.dyndns.org/Subaru/Solar1.jpg
http://srvtelluride.dyndns.org/Subaru/Solar2.jpg
http://srvtelluride.dyndns.org/Subaru/Solar3.jpg
Hi Azonetrooper, your welcome and thanks for the post. And your right she's really becoming a bad-ass car for off road adventures. Out camping this past weekend in South West Colorado.
http://srvtelluride.dyndns.org/Subaru/paradox.jpg
Hi All --Next little upgrade. New Perrin Performance Pitch Stop. I noticed there was quite a bit of play in the OEM Pitch Stop. They Perrin, say "...more power to the wheels by eliminating lost energy." So i decided what the hell, I'll give it a try. I think i notice the difference. much clearer engine sound in the cab. but that's OK i like the way it sounds. One thing i find interesting, is that Subaru has not changed the specs of the Pitch Stop: From 1993 - 2015 models, its exactly the same part.
OEM Pitch Stop: the bushings on both ends are warn.
http://srvtelluride.dyndns.org/Subaru/PitchStop1.jpg
Perrin Pitch Stop installed:
http://srvtelluride.dyndns.org/Subaru/PitchStop2.jpg
Hey 19Outback95, thanks for checking in. The OEM PS on the engine side, the bushing spins easily and on the firewall side the rubber is ripped. though you cant see it in the pics, it's not is the best condition. the car is 18 years old, and i'm guessing that pitch stop is original. I haven't come across Kartboy. i'll check out their stuff.
BTW: the pitch stop from Kartboy is about $25.00 more then Perrin.
