leggyman17 Posted September 8, 2012 Share Posted September 8, 2012 Yesterday i got my car (stage 2) dyno tuned. It was boosting 18.5lbs with a stock tubro and a stock top mount. Today it ran fine up until i hit peak boost one time and now i can olny boost up to 11 psi. So i guess my question would be how much boost can the OEM top mount take up to? Link to comment Share on other sites More sharing options...
SBT Posted September 8, 2012 Share Posted September 8, 2012 Reliably day-after-day. ~13.5psi. Some are running higher boost, but not without reinforcing the TM. See BarManBean's GB on the reinforcment kit. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
leggyman17 Posted September 8, 2012 Author Share Posted September 8, 2012 Ill look into the top mount issue. Ill take it off tomarrow to inspect.. Link to comment Share on other sites More sharing options...
iNVAR Posted September 8, 2012 Share Posted September 8, 2012 1) Check for TMIC leak. While you have the the TMIC removed, do 2) Check under the TMIC for the T-fitting that may have popped off. This will result in you throwing a CEL and will limit your boost to wastegate pressure. 3) Post a LearningView. Search to figure out how. Link to comment Share on other sites More sharing options...
fahr_side Posted September 8, 2012 Share Posted September 8, 2012 Reliably day-after-day. ~13.5psi. Some are running higher boost, but not without reinforcing the TM. 16.5psi from almost new to one year old and two years at 18~20psi, stock IC no kludging. Moved on to a Spearco now but had no issues with the stocker. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted September 8, 2012 Share Posted September 8, 2012 Reliably day-after-day. ~13.5psi. Some are running higher boost, but not without reinforcing the TM. See BarManBean's GB on the reinforcment kit. ^^This Link to comment Share on other sites More sharing options...
leggyman17 Posted September 9, 2012 Author Share Posted September 9, 2012 The T fitting popped off at the TB..replaced one line with a smaller size line so now it doesnt pop off under boost!. TMIC is OK but i want a better one just for my own sake.. Link to comment Share on other sites More sharing options...
fahr_side Posted September 9, 2012 Share Posted September 9, 2012 TMIC is OK but i want a better one just for my own sake.. Kind of overkill for stg2 but it's your money. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
