subaruguy509 Posted August 12, 2012 Share Posted August 12, 2012 I can never remember with 5-speeds...Do you want the car warmed up or cold when checking the fluid? Link to comment Share on other sites More sharing options...
monkeyposeur Posted August 12, 2012 Share Posted August 12, 2012 You want it warm iirc. Drive it around a bit and shift through all five gears. Link to comment Share on other sites More sharing options...
subaruguy509 Posted August 12, 2012 Author Share Posted August 12, 2012 My last 5-speed was a 1989 Honda Accord with 189k miles. Seemed like you never had to check it. There was no dipstick or nothing like that. Link to comment Share on other sites More sharing options...
subaruguy509 Posted August 13, 2012 Author Share Posted August 13, 2012 I noticed that the fluid is a little low. Link to comment Share on other sites More sharing options...
Legacy Wagon Posted August 13, 2012 Share Posted August 13, 2012 Well if you haven't changed it out in this car I'd consider putting some Amsoil in there and calling it a day. Obviously drain the other fluid first haha Link to comment Share on other sites More sharing options...
94legacy22 Posted August 23, 2012 Share Posted August 23, 2012 warm it up, check it with dip stick pass side of transaxle down deep get a funnel with a long tube. Justy ............................................................. 75W-90 GL-4 All others ................................................ 75W-90, 80W-90 GL-5 Above 30°F (0°C) ............................................................. 90 Above -20°F (-30C) ......................................................... 85W Below 90°F (32 °C) .......................................................... 80W CAPACITY, Refill: Brat & Hatchback: 2WD ................................................ 2.5 Liters 5.2 Pints 4WD ................................................ 2.8 Liters 6.0 Pints Impreza: 2WD .............................................. 2.6 liters 5.4 pints 4WD .............................................. 3.5 liters 6.8 pints Justy: 2WD ................................................ 2.1 Liters 4.4 Pints 4WD ................................................ 2.8 Liters 6.0 Pints Legacy: 2WD ................................................ 3.3 Liters 7.0 Pints 4WD ................................................ 3.5 Liters 7.4 Pints Loyale: 2WD ................................................ 2.6 Liters 5.4 Pints 4WD ................................................ 3.3 Liters 7.0 Pints XT Coupe: 4-cyl. 2WD ......................................... 2.6 Liters 5.4 Pints 4-cyl. 4WD ......................................... 3.3 Liters 7.0 Pints 6-cyl. 4WD ......................................... 3.5 Liters 7.4 Pints Link to comment Share on other sites More sharing options...
