Cube Posted July 31, 2012 Share Posted July 31, 2012 Sup, guys. I just owned a reconditioned Legacy Wagon GT2.0 for the past 14 to 15 days.. Suddenly, my engine started to vibrate roughly and at first I thought it was the spark plugs. Had that changed but still the same problem. Checked the ignition coils, but it still had the same problem. Now the car is still at the shop and the mechanics will have the fuel system checked tomorrow. Hopefully, it won't be that serious. Any other possible reasons for the rough idling? Link to comment Share on other sites More sharing options...
AkumaMax Posted July 31, 2012 Share Posted July 31, 2012 Well sounds like they are doing it right. First three things to check on a car that is running rough is check AIR/Spark/Fuel. Could be a clogged injector. Is there any ticking at all? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 31, 2012 I Donated Share Posted July 31, 2012 Sounds like you have some kind of misfire. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Cube Posted July 31, 2012 Author Share Posted July 31, 2012 AkumaMax, yes there were ticking sounds for a brief moment during start up and on some occasion during idling. The RPM would drop a bit lower than normal after giving it a bit of gas and also. Brief ticking sound could be heard. Link to comment Share on other sites More sharing options...
AkumaMax Posted August 1, 2012 Share Posted August 1, 2012 I would have a compression check done just to be sure there is nothing serious wrong. Link to comment Share on other sites More sharing options...
HipsterDoofus Posted August 1, 2012 Share Posted August 1, 2012 Stop calling it a Scooby. Then check in on us after a week and see how the problem fixed itself Link to comment Share on other sites More sharing options...
StoplightAssassin Posted August 1, 2012 Share Posted August 1, 2012 This is a JDM or EDM 2.0GT turbo? It's most likely a simple vacuum leak. Subaru engines all tick to some degree. Link to comment Share on other sites More sharing options...
Cube Posted August 2, 2012 Author Share Posted August 2, 2012 AkumaMax, The mechanic found that there is an air leak in one of the intake pipes. it seems that the surface was uneven causing the air leak as seen below: http://imageshack.us/photo/my-images/100/imag0665v.jpg/ http://imageshack.us/photo/my-images/834/imag0666j.jpg/ So this afternoon the mechanic grind it down to make it as flat as possible so to avoid further leaks. Hopefully it will solve the rough idling problem. StoplightAssassin, To be honest with you, im quite 'alien' when it comes to Subarus. I find it hard to locate aftermarket parts for my car. But what i can tell you is that it is a 2.0GT and also it could be a Spec B. Production year could be between 2003 to 2005. I derived to this conclusion due to the fact that it has an electronic shifter on the steering wheels and 18 inch rims as standard. Also it has an EJ20X engine. unfortunately the workshop where im sending my car couldn't even identify the car and also i found out yesterday that Fujitsubo needed to confirm which model it is after various information has been sent to them. HipsterDoofus, thanks for the warm welcome. Link to comment Share on other sites More sharing options...
HipsterDoofus Posted August 2, 2012 Share Posted August 2, 2012 Its what I do! Welcome to the forum! Link to comment Share on other sites More sharing options...
StoplightAssassin Posted August 2, 2012 Share Posted August 2, 2012 I can't tell from that pic, but it looks like that piece is fine. The gasket is still in good condition. I know it bolts to the turbo and gets very hot, but I doubt it would warp. What country did you purchase the car in? you can get a ton of aftermarket parts on japanparts.com Link to comment Share on other sites More sharing options...
Cube Posted August 2, 2012 Author Share Posted August 2, 2012 Yup. Actually, the gasket side is a bit curved and it fits unevenly on the turbo which caused the leak. Hopefully sanding the pipe down solves the problem. Fortunately all the intercooler hoses is still in good condition. I'm from Brunei. I got it off from a friend about 2 weeks ago who used it for roughly about 2 years. It was docked for a few months for which I don't know the reason for. The main origin of the reconditioned car could be from Singapore which they might get it off from Japan since the deck includes a Mini Disc player. Thanks for site. I will definitely check it out. Link to comment Share on other sites More sharing options...
StoplightAssassin Posted August 2, 2012 Share Posted August 2, 2012 JDM markets are the only markets to get the Mini Disc as far as I know. Link to comment Share on other sites More sharing options...
Cube Posted August 2, 2012 Author Share Posted August 2, 2012 Btw, how do I know on what applied model my legacy is? Japanparts.com categorizes the models on chassis and applied models. Link to comment Share on other sites More sharing options...
AkumaMax Posted August 2, 2012 Share Posted August 2, 2012 Get some pictures up of your car and we can tell you. Link to comment Share on other sites More sharing options...
Cube Posted August 3, 2012 Author Share Posted August 3, 2012 The Front: http://img441.imageshack.us/img441/6656/frontlct.th.jpg The Back: http://img515.imageshack.us/img515/8315/backqc.th.jpg And the Vin: http://img690.imageshack.us/img690/636/vinplatez.th.jpg Link to comment Share on other sites More sharing options...
Dujo Posted August 3, 2012 Share Posted August 3, 2012 VIN decoding: http://www.cars101.com/subaru/vin.html Link to comment Share on other sites More sharing options...
StoplightAssassin Posted August 3, 2012 Share Posted August 3, 2012 USDM VIN decoding doesn't apply to JDM vehicles according to your tag and the pictures, you have a 2.0 Spec B wagon. congrats! Link to comment Share on other sites More sharing options...
Cube Posted August 3, 2012 Author Share Posted August 3, 2012 thanks, StoplightAssassin! So how do I know which applied model it is? Link to comment Share on other sites More sharing options...
Thorr Posted August 3, 2012 Share Posted August 3, 2012 what is this 'applied model' you speak of? Link to comment Share on other sites More sharing options...
StoplightAssassin Posted August 3, 2012 Share Posted August 3, 2012 you can decode a JDM frame ID # in the same manner like a USDM or EDM VIN. most of it is in Russian, but you should be able to figure it out. http://www.carrol.ru/_pages/subaru/index.php?st=11&l=bWFya2V0PT11c2E= Where it says 20GTB, that's how you know it's a Spec B Also, that's a JDM Spec B bumper Link to comment Share on other sites More sharing options...
Dujo Posted August 3, 2012 Share Posted August 3, 2012 ^ Dammit, I thought that might be a problem, but I didn't see anything about location in my quick scan of the page. Sorry for the misinformation, OP and thanks for the correction Assassin. Link to comment Share on other sites More sharing options...
Cube Posted August 3, 2012 Author Share Posted August 3, 2012 what is this 'applied model' you speak of? If you see at japanparts.com link:http://japanparts.com/db/maker.php?maker=Subaru the site suggest 2 types of Legacy with the same chassis type (in my case it's BP5) and also the site suggest to make sure the applied model in which there is a variation from A to F. How do I know which one my legacy is? Link to comment Share on other sites More sharing options...
StoplightAssassin Posted August 3, 2012 Share Posted August 3, 2012 applied = revision. in JDM markets there were many different revisions for each model, usually denoting suspension changes according to your tag, the applied model is BP5A5GV I found this: http://legacygt.com/forums/showthread.php/jdm-spec-b-rev-b-impressions-3801.html send a pm to the OP of that thread, apexjapan. he can help you way more with figuring your car out and parts for it than I can. Link to comment Share on other sites More sharing options...
Cube Posted August 3, 2012 Author Share Posted August 3, 2012 Thanks for the link. I found out in one of the posts that a member has a similar applied model. Link to comment Share on other sites More sharing options...
Cube Posted August 7, 2012 Author Share Posted August 7, 2012 So I got my car back from the shop the other day. I was still disappointed due to the fact that the engine still idles roughly. Better than before but still idles abit roughly. They tried tuning the timing after they he found out it was off. But the mechanic insisted that it'll go away after awhile. But still I have an uneasy feeling about it. Later that evening I found out it had a misfire as well. *sigh*. I'm trying to read up other possible issues that might contribute to the problem in this thread: http://legacygt.com/forums/showthread.php/cylinder-misfires-bad-injectors-please-post-here-85099p6.html?highlight=Misfire+knocking What a bad first experience on a Subaru... Link to comment Share on other sites More sharing options...
