Zac88 Posted July 27, 2012 Share Posted July 27, 2012 So I need a new balljoint upfront on my 05 LGT Wagon. I was wondering if there was any type of anti-lift kit or Group N upgrades for it? Thanks Link to comment Share on other sites More sharing options...
derffred Posted July 28, 2012 Share Posted July 28, 2012 Whiteline makes a bump-steer kit.. I believe it comes with outer tie rods & front lower ball joints. I'll copy their description. "The Whiteline bump-steer correction kit extends the factory front end tie-rods to keep the axles at nearly the same distance from the frame at the steering box, eliminating axle tilt and subsequently curing bump-steer. Whiteline includes their bump-steer kit in every roll-center kit for the perfect total suspension solution. Your Subaru never felt this good!" Link to comment Share on other sites More sharing options...
whitetiger Posted July 28, 2012 Share Posted July 28, 2012 ^not needed if not lowered. oem replacements are cheaper, and wont need an alignemnt after install like the whiteline kit will. Link to comment Share on other sites More sharing options...
scoobyscoodle Posted July 29, 2012 Share Posted July 29, 2012 +1 to oem if not lowered. Link to comment Share on other sites More sharing options...
Zac88 Posted August 1, 2012 Author Share Posted August 1, 2012 So on stock springs I wont see any benefits? I'm supposed to buy JDM take-offs soon. Link to comment Share on other sites More sharing options...
compsurge Posted August 1, 2012 Share Posted August 1, 2012 Just get OEM. You may need the sniper ball tugger. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 4, 2012 Share Posted August 4, 2012 Search for ball joint post here. You may be better off to buy the spindle and new ball joint, and save the labor time trying to remove the old ball joint. In the long run, it may work out cheaper and easier if your DIY. http://legacygt.com/forums/showthread.php/ball-joint-replacement-186404.html?t=186404&highlight=ball+joint+replacement 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
scoobyscoodle Posted August 5, 2012 Share Posted August 5, 2012 Getting the ball joint out of the spindle is easy, use a prybar between the spindle and control arm to separate. Then to get the ball joint out of the lca I've found a pitman arm puller works well. Link to comment Share on other sites More sharing options...
bmx045 Posted August 6, 2012 Share Posted August 6, 2012 Just get OEM. You may need the sniper ball tugger. sounds unpleasant.. Link to comment Share on other sites More sharing options...
cypher0117 Posted August 6, 2012 Share Posted August 6, 2012 Just get OEM. You may need the sniper ball tugger. sounds unpleasant.. I enjoyed using that ball tugger. Only lasted about 10 minutes though OP: If you need new ball joints, check your caster bushings in your LCA. They like to tear. Link to comment Share on other sites More sharing options...
compsurge Posted August 6, 2012 Share Posted August 6, 2012 Ha. I have to get replacement washers for mine. They are not thick enough. A 1/8" plate would probably work. LOL at southeast PA car. I can't even imagine what it would be for New England. Link to comment Share on other sites More sharing options...
