dr_sharp Posted July 1, 2012 Share Posted July 1, 2012 I'm thinking of taking it to the dealer to have them do this. What is a reasonable price to expect? I've heard stories of people not getting the correct amount of fluid back into the car otherwise I'd try it myself. lol Link to comment Share on other sites More sharing options...
bluesuby Posted July 1, 2012 Share Posted July 1, 2012 It's not too difficult to get this done yourself. You need the large Torx bit to drain the manual transmission and it gets refilled through the dipstick for the tranny located under the engine cover on the passenger side. It holds around 4 quarts of 75-90 gear oil. I used Redline NS but others rave about Subaru's own fluid which I believe isn't available in reasonably sized retail containers. The diff holds a little under a quart and removing the drain and refill plugs can be tricky because of access. Make sure you remove the refill plug (top) before you drain anything. Buy a fluid transer pump on Amazon for 5 or 6 bucks and use a recommended fluid (not NS) or Mobil 1 gear oil comes in a squeeze refill bottle which is messy unless you're quick and lucky. With the rear of the car supported by jackstands just keep adding until the fluid runneth over. I don't think you can overfill either the trans or diff because lubrication is not by pump, it's splashed. Link to comment Share on other sites More sharing options...
dr_sharp Posted July 2, 2012 Author Share Posted July 2, 2012 fred beans has extra-s http://www.fredbeansparts.com/subaru-75w90-extra-s-gear-and-transmission-quart-bottle.html Maybe I'll read up on it a bit more before I decide to go to the dealer. They quoted me $216.31 for both diffs + transmission lol Link to comment Share on other sites More sharing options...
angeltalin Posted July 2, 2012 Share Posted July 2, 2012 http://legacygt.com/forums/showthread.php/pictoral-guide-changing-transmission-and-rear-diff-fluids-5mt-05-94834.html?t=94834 here^^ StageIII Cryotune-Kinugawa STS TD06H-20GTX 9 blade turbine, ID1000, DW65c, 73mm MegaMAF , GS EWG up-pipe, Downpipe and EBCS, FMS FMIC, TGV Delete, Brembo swap Link to comment Share on other sites More sharing options...
mwm5094 Posted July 7, 2012 Share Posted July 7, 2012 Damn, thats crazy. Trans and both diffs take me about an hour. Link to comment Share on other sites More sharing options...
Refuge Posted July 10, 2012 Share Posted July 10, 2012 Did you Do it? Link to comment Share on other sites More sharing options...
