iv_05gt Posted June 29, 2012 Share Posted June 29, 2012 So months and months ago I purchased a infamous tuning tune (along with a bunch of other stuff) I (due to work i didnt have the opportunity to install it). I worked with Shamar a bit a few months ago, but i'm still overboosting. I don't want to overuse my welcome asking him to re-visit the issue... I have a grimspeed EBCS, is there any way to adjust the actuator to prevent the fuel cut/overboost code? or do i need to have the tune adjusted. (bnr 16g, avo inlet, ipr tmic, CNT catted 3" invidia q300 v3, aem cai) i know... derp question, thanks for your help:spin: Link to comment Share on other sites More sharing options...
Max Capacity Posted June 29, 2012 Share Posted June 29, 2012 I was over boosting, found a crack in the vacume line of the turbo compressor housing. Check for leaks. Touch or move every line. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
iv_05gt Posted June 29, 2012 Author Share Posted June 29, 2012 I replaced all the vac lines when i replaced the turbo. all new, clamped down, i tested the system and found no leaks. Link to comment Share on other sites More sharing options...
iNVAR Posted June 29, 2012 Share Posted June 29, 2012 you need to be a LOT more specific. how much are you overboosting, under what circumstances (weather, throttle, gear, etc.). if you're still overboosting as in this isn't a new development, i would think that shamar should be willing to fix this issue for you. Link to comment Share on other sites More sharing options...
iv_05gt Posted June 29, 2012 Author Share Posted June 29, 2012 I overboost in 3rd, 4th, and 5th. @ WOT at roughly 4k RPM, weather & terrain (hills and stuff) make no difference. The tune was set to be 19.5psi it will fuel cut at anything 19psi < (spikes up to 22psi) If I ease into the throttle and very very slowly bring the boost up it wont fuel cut until 5k(ish) rpm in 4th & 5th at any boost over 19psi. Link to comment Share on other sites More sharing options...
iNVAR Posted June 29, 2012 Share Posted June 29, 2012 You're spiking to 22 psi on a tune dialed in for 19.5? I mean, first, 19.5's pretty aggressive for a stage 2. Second, that's too much of a spike in my opinion. You should ask shamar about this. For what it's worth, shamar did my original stage 2 at 18 psi and I never saw it spike above 19.5 I believe. My current tune that i have dialed in mostly right never spikes above about 19.2 and that's only if I actually try to induce the spike. edit: oh, doh, you're stage 3, you have a 16G, that's different, my bad. Link to comment Share on other sites More sharing options...
iNVAR Posted June 29, 2012 Share Posted June 29, 2012 If your tune has *always* behaved this way, I would say Shamar should have no problem fixing it for you. Link to comment Share on other sites More sharing options...
m sprank Posted July 1, 2012 Share Posted July 1, 2012 email Shamar. Link to comment Share on other sites More sharing options...
ktmrider Posted July 3, 2012 Share Posted July 3, 2012 If your tune has *always* behaved this way, I would say Shamar should have no problem fixing it for you. email Shamar.This. If Shamar is not familiar with the GS-EBC it can/could take a few iterations to get the WGDC targeted correctly. Link to comment Share on other sites More sharing options...
