Cone_Killer Posted June 28, 2012 Share Posted June 28, 2012 Hey guys, I just finished putting my daily back together and I need to do some tuning. I really don't want to do opensource, I would much rather just buy an AP. All I have done is a modified airbox with a K&N. Catless up & down pipes with 3" downpipe back and a Vf46 (blew the 40). Will an AP suit my needs? Link to comment Share on other sites More sharing options...
NWSPECB Posted June 28, 2012 Share Posted June 28, 2012 Well if you don't want to do OS then your only real choice is an AP. Now I assume you know that and are really asking whether the OTS maps on the AP will do what you want. The answer is yes, but you should get pro-tune of some sorts for it to really run as good as it should. You can do a simple E-Tune if you don't have a local tuner. This is usually a much cheaper and convenient way to go as well. Link to comment Share on other sites More sharing options...
Cone_Killer Posted June 28, 2012 Author Share Posted June 28, 2012 I didn't see any OTS maps available for it when I last checked COBB. Link to comment Share on other sites More sharing options...
NWSPECB Posted June 28, 2012 Share Posted June 28, 2012 OTS MAPS Link to comment Share on other sites More sharing options...
Cone_Killer Posted June 28, 2012 Author Share Posted June 28, 2012 Well thank you haha. I swear I couldn't find them. Link to comment Share on other sites More sharing options...
NWSPECB Posted June 28, 2012 Share Posted June 28, 2012 No problem. It's under the Maps tab on the Cobb homepage Link to comment Share on other sites More sharing options...
lieutenantcolumbo Posted June 28, 2012 Share Posted June 28, 2012 You should not just use the OTS maps that come with the AP as they are not correct for your intake. You should look at a modified OTS map from InfamousPerformance.net for $100 or for $250 you can get an e-tune from them. There are many other e-tuners as well, but probably very few have tuned as many LGT's as Infamous. Link to comment Share on other sites More sharing options...
NWSPECB Posted June 28, 2012 Share Posted June 28, 2012 ^Yup. I would check out all your options though. From what I have been reading Shamar (Infamous) is kinda backed up and taking a while to get back to people on their revisions. Not saying he is bad at what he does I just think he has a full plate and if this is your DD you should get a correct tune as soon as you can. Link to comment Share on other sites More sharing options...
Cone_Killer Posted June 28, 2012 Author Share Posted June 28, 2012 I have another airbox that I can use for a bit just to use the OTS. BTW, I think I was in the map archives. Link to comment Share on other sites More sharing options...
NWSPECB Posted June 28, 2012 Share Posted June 28, 2012 Its not the airbox it's having an aftermarket intake that makes a modified OTS tune necessary. The stock intake is more than sufficient for stages up until stage 3+ish. Link to comment Share on other sites More sharing options...
