Frougy Posted June 20, 2012 Share Posted June 20, 2012 i just bought this 96 legacy L wagon last week. it has 143500k miles. its an automatic. i checked the fluid and its fine but when im driving it shifts really hard into 2nd gear. theres not CEL on. i did research and it said it could be a MAF sensor? or fluid flush? i had a 1999 chevy astro with the same problem, i repaced the sensor on the astro van and it fixed it right away. will that work for the legacy? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted June 20, 2012 I Donated Share Posted June 20, 2012 How do you know the fluid is fine? Do you have a way to check the fluid for break down to see if its still doing the job it was designed to do? -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Kennyfvholla Posted June 20, 2012 Share Posted June 20, 2012 That hard shift is a common thing among our cars. A few drain and fills and a new filter should help out with it some. It doesn't have anything to do with the MAF. Link to comment Share on other sites More sharing options...
gergeek Posted June 20, 2012 Share Posted June 20, 2012 You can try doing the "Engine Grounding Kit" mod...that seems to work....One of the subaru gurus backed me up and had said it in the one of the stickies. Link to comment Share on other sites More sharing options...
Kennyfvholla Posted June 20, 2012 Share Posted June 20, 2012 I refer you to... http://legacygt.com/forums/showthread.php/97-legacy-l-4eat-shifting-issues-124026.html Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted June 20, 2012 I Donated Share Posted June 20, 2012 And I refer you to http://legacygt.com/forums/search.php -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Frougy Posted June 22, 2012 Author Share Posted June 22, 2012 i will get the fluid flushed. also when ever i start the car and drive it feels sluggish, then after it warms up the sluggishness is gone. i can also feel the car rock back and forth Link to comment Share on other sites More sharing options...
kakarotoni Posted June 22, 2012 Share Posted June 22, 2012 What kind of fluid go you guys usually use for the 4EAT? I read to avoid using dexron and stick with subaru fluids. Should one use a synthetic ATF fluid? Or just stick with OEM fluids? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted June 22, 2012 I Donated Share Posted June 22, 2012 DO NOT flush it. Do a few drain and fills. Do your first one, then drive a week, then do another.....then drive another week...then do it a third time. Use just standard DexIII fluid. Its what the car calls for. If you want an "upgraded" fluid, you can run Dex6...its DexIIIs replacement. Its full synthetic fluid and its backward compatible with III. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
BXR4T Posted June 22, 2012 Share Posted June 22, 2012 You flush your tranny, and you pretty much send it to the grave depending on previous maintenance. Do as broknin says. Link to comment Share on other sites More sharing options...
harrumphicus Posted June 22, 2012 Share Posted June 22, 2012 What's the difference between draining and flushing? Link to comment Share on other sites More sharing options...
BXR4T Posted June 22, 2012 Share Posted June 22, 2012 Think of a toilet and a sink. The toilet has gobs of power to send all of the shi* down the hole, along with cleaning the skid marks on the bottom. The sink drains in a calm state when compared to the flush of a toilet. Does this help? The drain is supposed to keep your metal shavings in your transmission to help as lubricant, this is why you do it in 3 to 4 steps. If you flush those out, your lubricant is all gone and we all know what happens when the lube dries up! This is correct right broknin? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted June 22, 2012 I Donated Share Posted June 22, 2012 Somewhat. Ill explain a little better when I'm not on my phone -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Kennyfvholla Posted June 22, 2012 Share Posted June 22, 2012 DO NOT flush it. Do a few drain and fills. Do your first one, then drive a week, then do another.....then drive another week...then do it a third time. Use just standard DexIII fluid. Its what the car calls for. If you want an "upgraded" fluid, you can run Dex6...its DexIIIs replacement. Its full synthetic fluid and its backward compatible with III. Agreed on all of the above. Just make sure that you refill the exact amount of fluid that drained out. That way you don't overfill. Link to comment Share on other sites More sharing options...
stevenva Posted June 23, 2012 Share Posted June 23, 2012 "Do a few drain and fills. Do your first one, then drive a week, then do another.....then drive another week...then do it a third time." How come there is no mention of the filter being changed? When should it be done during this procedure? RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
monkeyposeur Posted June 23, 2012 Share Posted June 23, 2012 To get at the filter you have to take off your transmission pan iirc. Link to comment Share on other sites More sharing options...
Kennyfvholla Posted June 23, 2012 Share Posted June 23, 2012 "Do a few drain and fills. Do your first one, then drive a week, then do another.....then drive another week...then do it a third time." How come there is no mention of the filter being changed? When should it be done during this procedure? I had already mentioned replacing the filter in my first reply. I would replace it during the first drain and fill. Link to comment Share on other sites More sharing options...
soloz2 Posted June 23, 2012 Share Posted June 23, 2012 My wife's 98 seems to really like mobile one atf. Sent from my SAMSUNG-SGH-I727 using Tapatalk 2 Current: 16 Crosstrek Premium w/ Eyesight & 05 Outback XT 5MT Past Subies: 14 FXT Premium, 14 WRX hatch, 06 Legacy 2.5i SE 5MT, 98 Outback wagon Link to comment Share on other sites More sharing options...
kakarotoni Posted June 30, 2012 Share Posted June 30, 2012 Hey guys, I dont mean to bring this thread back but better then creating a new one. Its my first 4eat transmission fluid change so I want to get some things cleared up. (5mt is so much easier to change) I read the stickys on here and it says that the 4eat requires 2.6 quarts on the 4eat but total capacity is 10 quarts? And to use Dexron III but I heard I can use Subaru ATF-HP. How many quarts should I get? I understand the whole drain and fill and repeat 3-4 times process. However, do I need to drain and fill for the front and rear diff fluids multiple times or just once for the front and rear diffs? And can I use the same Subaru-ATF fluid on the front and rear diffs or should I just use a 75w-90 gls type fluid instead? Thanks! Link to comment Share on other sites More sharing options...
