suboogru Posted June 8, 2012 Share Posted June 8, 2012 Y would my passenger side tires wear more than the driver's side when all 4 have same psi Link to comment Share on other sites More sharing options...
Leviman Posted June 8, 2012 Share Posted June 8, 2012 Bad alignment. Or you take a lot of left hand corners very very hard. Also, it's 'why' not "Y". Also periods and question marks exist too. Link to comment Share on other sites More sharing options...
suboogru Posted June 8, 2012 Author Share Posted June 8, 2012 Sorry I'm using my phone and its a force of habit. All the punctuation marks are on a separate screen Link to comment Share on other sites More sharing options...
pillboy Posted June 8, 2012 Share Posted June 8, 2012 Asymmetrical tire treads lead to asymmetrical tire wear. It is still ugly. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 9, 2012 Share Posted June 9, 2012 I agree with the bad alignment idea. Have it checked. As a rule these cars are pretty good with even tire wear as long as you rotate the tires. Which is something your center diff will thank you for. You want to keep even tire diameter. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
BXR4T Posted June 9, 2012 Share Posted June 9, 2012 Or you take a lot of left hand corners very very hard. Some one care to explain this to me in deeper detail, or the reason why this happens to the passenger side when taking hard left hand turns? *edit* Could the wear also be due to uneven weight distribution? i.e. gold plates on the passenger seat and back seat passenger side or other large heavy objects on the passenger side of the car? But I agree with the alignment. Especially if he was sliding around on the snow through the winter and accidentally slammed into a curb. Link to comment Share on other sites More sharing options...
suboogru Posted June 9, 2012 Author Share Posted June 9, 2012 Usually I just drive by myself. I'll have to schedule an alignment Link to comment Share on other sites More sharing options...
