nstg8r Posted August 15, 2013 Share Posted August 15, 2013 btw... I decided to vinyl wrap my wood trim, so now I have a full set of the silver trim if anyone is interested. Link to comment Share on other sites More sharing options...
faded-a-fool Posted August 15, 2013 Share Posted August 15, 2013 btw... I decided to vinyl wrap my wood trim, so now I have a full set of the silver trim if anyone is interested. PM me a price. Link to comment Share on other sites More sharing options...
Brent C Posted August 16, 2013 Share Posted August 16, 2013 I was able to do all mine without having to do all that. How did you do it? Also, anyone know about the shifter?? Thanks for the help fella's! Link to comment Share on other sites More sharing options...
nstg8r Posted August 16, 2013 Share Posted August 16, 2013 How did you do it? Also, anyone know about the shifter?? Thanks for the help fella's! 1st, remove the radio bezel. You'll see a single screw that holds the piece that holds trim piece, remove it. Then you have to pop out the knee bolster below it and the piece will come out. http://legacygt.com/forums/showpost.php?p=3151624&postcount=42 Link to comment Share on other sites More sharing options...
nstg8r Posted August 16, 2013 Share Posted August 16, 2013 For the radio bezel... 4. Audio.pdf Link to comment Share on other sites More sharing options...
s2baru Posted August 16, 2013 Share Posted August 16, 2013 Guess I thought the radio was held in by screws rather than simple clips...Owell, good to know now when I tackle a audio install down the road. Link to comment Share on other sites More sharing options...
Meli Posted August 16, 2013 Share Posted August 16, 2013 Sounds like a good solution. I'd be interested in seeing pics/ figuring out how you did it. Or how much you selling the silver finish trim? Would it fit a '03 wagon? Link to comment Share on other sites More sharing options...
Brent C Posted August 17, 2013 Share Posted August 17, 2013 Ok I got all the trim done, anyone know how to get the shifter off?? Link to comment Share on other sites More sharing options...
nstg8r Posted August 17, 2013 Share Posted August 17, 2013 ok i got all the trim done, anyone know how to get the shifter off?? 16. Rear Accessory Power Supply Socket.pdf Link to comment Share on other sites More sharing options...
nstg8r Posted August 17, 2013 Share Posted August 17, 2013 PM me a price. I pm'ed you a couple days ago. Link to comment Share on other sites More sharing options...
faded-a-fool Posted August 17, 2013 Share Posted August 17, 2013 I pm'ed you a couple days ago. Oops...replied to your PM Link to comment Share on other sites More sharing options...
Aeterna Posted October 23, 2014 Share Posted October 23, 2014 So ive got all the stuff to wrap my interior trim. My question is how easy is it to screw your door paneling up when removing the trim? The last car i did something like this was a mazdaspeed protege and the pins were dry and cracked it didnt really go back the same way it came off.. Link to comment Share on other sites More sharing options...
Zee199969 Posted October 23, 2014 Share Posted October 23, 2014 ^when I replaced my non folding mirror housing with folding ones, the door cards came out pretty easily. With a plastic pry tool and some masking tape, there was no damage to the cards My "Build" Link to comment Share on other sites More sharing options...
s2baru Posted October 23, 2014 Share Posted October 23, 2014 Take off all the doors then behind them there are 4-6 small screws holding those moldings in place. From there its straight forward and just reverse the process. I wrapped mine so it took about 4hrs total since it was the first time I worked with vinyl. Link to comment Share on other sites More sharing options...
nstg8r Posted October 23, 2014 Share Posted October 23, 2014 Hardest part is removing the door handle & lock cables. Just take your time and be patient. It should only take a couple minutes per door to remove the door cards. Link to comment Share on other sites More sharing options...
Aeterna Posted October 23, 2014 Share Posted October 23, 2014 ok thanks guys, would it be smart to leave about a half inch of vinyl to wrap behind the trim in case there is any slip or shrinking? Link to comment Share on other sites More sharing options...
coppertone Posted October 24, 2014 Share Posted October 24, 2014 I've ordered all of my pieces and will take before and after photos once in and installed. 2010 2.5GT limited is for sale. Link to comment Share on other sites More sharing options...
s2baru Posted October 24, 2014 Share Posted October 24, 2014 ok thanks guys, would it be smart to leave about a half inch of vinyl to wrap behind the trim in case there is any slip or shrinking? Would be a good idea to. As for where to start I came to the conclusion that starting at the small points made it because there is a slight angle to them. Also for a pointer made sure the vinyl isnt super cold, its not as forgiving whem working the edges. Link to comment Share on other sites More sharing options...
Aeterna Posted October 24, 2014 Share Posted October 24, 2014 Would be a good idea to. As for where to start I came to the conclusion that starting at the small points made it because there is a slight angle to them. Also for a pointer made sure the vinyl isnt super cold, its not as forgiving whem working the edges. Ok thanks man, ill bust out my gf's blow dryer. Link to comment Share on other sites More sharing options...
LegacyUpNorth Posted January 31, 2016 Share Posted January 31, 2016 Thanks to the OP for this post. I just replaced the aluminum trim with wood trim and looks amazing Link to comment Share on other sites More sharing options...
