62beatle Posted May 20, 2012 Share Posted May 20, 2012 I bought an used car of subaru legacy 1992. Today I found there is keyless entry system mounted in the car. Maybe I guess it is from factory, not aftermarket. But unfortunately I have no remote transmitter and sensor unit. I think that the cable near the room mirror was connected to the sensor unit. Can I connect the sensor unit from aftermarket to the Subaru keyless entry system and also use the remote transmitter? I will attach the picture of cable. Link to comment Share on other sites More sharing options...
Legacy Wagon Posted May 21, 2012 Share Posted May 21, 2012 I dont believe there was keyless entry systems on these cars from the factory in 1992. Link to comment Share on other sites More sharing options...
62beatle Posted May 22, 2012 Author Share Posted May 22, 2012 Oh, Really? You may be right. If it is from aftermarket unit, Can I restore it? Link to comment Share on other sites More sharing options...
Legacy Wagon Posted May 22, 2012 Share Posted May 22, 2012 I'm not good with electrical crap, but I suppose if someone had it working once it can be made to work again. Any chance you know what brand it is? That'd probably help you out a ton. Link to comment Share on other sites More sharing options...
94legacy22 Posted May 22, 2012 Share Posted May 22, 2012 could also be a power cable for a radar dector up there. I've seen that b4. put a volt meter to it and see what you get. if nothing, trace the wiring and see where it goes... Link to comment Share on other sites More sharing options...
