SpecBamf41 Posted May 19, 2012 Share Posted May 19, 2012 long story short. im installing one of the bolts the holds the 5mt subframe to the chassis and just snap. the nut that subaru welds to the inside broke free and i have no way to tighten or loosen the bolt. its just sitting there. the car will be drivable with all the the other mounts bolted up. what the hell do i do. BNR18g on 93oct Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted May 19, 2012 I Donated Share Posted May 19, 2012 Don't leave missing bolts on crossmembers or sub frames. I had 3/4 installed on a BMW sub frame (engine cradle) a few years back. It was still on the lift and I was waiting for the new bolt to come in (the missing one had snapped and I drilled it out). While it was on the lift with 3/4 bolts....the one side with only one in it failed....then the sudden pressure on the other side cause the other two to snap as well....causing the engine / subframe / suspension to come crashing down from 7 feet in the air. So yes, that 4th bolt was THAT important... One option you do have is to cut out like a 2x2 inch section around the nut that the weld broke on. Get a piece of sheet metal and drill a hole in the center of it, then weld a nut to it. Then weld that piece of sheet metal into the place where you cut it off the car. Don't do this unless you're confident that your welds will be able to hold up to the stress of the driveline though. There is a lot of force and weight on those bolts. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
SpecBamf41 Posted May 19, 2012 Author Share Posted May 19, 2012 that was one of my ideas. another is to tear into the dash and cut a hole in the less important interior tub and get at the backside of that area. but its the bolt right next to the rear mount for the a arms. basically like a foot below your passengers feet. it this even possible? once you remove the ecu there is sheetmetal. if i cut a access whole in that is there anything else between the metal behind the ecu and the nut im trying to get to. i fell this is my best stongest action to take vs the other idea, also. keep in mind the subfame it still in the way to cut the 2x2. i would need to cut the bolt to free the subframe and leave a jack to support the tranny. BNR18g on 93oct Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted May 19, 2012 I Donated Share Posted May 19, 2012 I don't know if there will be anything in the way if you go from the top. I wouldn't worry about wiring because most of that is under the carpet, not between sheet metal. If you can get to it from the top, that would probably be the better way to go. That way you don't have to worry (as much at least) about rust and corrosion since it will be on an interior section. Just make sure you get both side of the weld as much as you can with spray paint to help prevent rust. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
SpecBamf41 Posted May 19, 2012 Author Share Posted May 19, 2012 rust is not a concern, rust already won ill look into coming from the top. BNR18g on 93oct Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted May 19, 2012 I Donated Share Posted May 19, 2012 Rust already one? What do you mean? Did you mean to type "won"? -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
SpecBamf41 Posted May 19, 2012 Author Share Posted May 19, 2012 yes, won. car is more or less a tinker toy that will be somewhat of a sloppy track car. BNR18g on 93oct Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted May 19, 2012 I Donated Share Posted May 19, 2012 Like a fat and tired Natalie Portman? -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Zues Marine Posted May 19, 2012 Share Posted May 19, 2012 i have a crush on natlie portman. . . Link to comment Share on other sites More sharing options...
SpecBamf41 Posted May 19, 2012 Author Share Posted May 19, 2012 Who is she Sent from my Galaxy Tab using TapaTalk 2 BNR18g on 93oct Link to comment Share on other sites More sharing options...
joelwatts Posted May 19, 2012 Share Posted May 19, 2012 she was princess amidala in the 1,2,3 star wars movies. she also played evey hammond in v for vendetta. I'm a native of South Carolina. I am a dying breed. Link to comment Share on other sites More sharing options...
Reckoner Posted May 19, 2012 Share Posted May 19, 2012 Who is she Sent from my Galaxy Tab using TapaTalk 2 http://images.askmen.com/celebs/women/actress_60/64_natalie_portmanlarge_image-1.jpg Link to comment Share on other sites More sharing options...
Zues Marine Posted May 20, 2012 Share Posted May 20, 2012 ahh... total babe, with a master's in psychology from Harvard Link to comment Share on other sites More sharing options...
That Guy 2-1 Posted May 20, 2012 Share Posted May 20, 2012 Can you drill a hole next to the nut and then tack weld the nut through the hole an essentially fill the hole with it? Link to comment Share on other sites More sharing options...
SpecBamf41 Posted May 20, 2012 Author Share Posted May 20, 2012 i could try. how much of a weld do i really need to keep that nut from moving. maybe ill drill a few holes around it and just lay it in. only problem is the sub frame cant be removed from the car. BNR18g on 93oct Link to comment Share on other sites More sharing options...
That Guy 2-1 Posted May 20, 2012 Share Posted May 20, 2012 You don't need much. Most nuts are only tacked in like 2 spots or friction welded. Did you strip the bolt or was it really tight? Link to comment Share on other sites More sharing options...
SpecBamf41 Posted May 20, 2012 Author Share Posted May 20, 2012 I only got it in a third of the way. This is a bolt hole that nevergets used in auto cars. So this never had a bolt in it for over 200 thous miles. Had just a bit of rust in it. I should of ran a tap though it but the theards are good. Its just like a combo of the bit of rust and lock tight that was on it that made it so I had to use a rachet to tighten it. Instead of by hand. Sent from my Galaxy Tab using TapaTalk 2 BNR18g on 93oct Link to comment Share on other sites More sharing options...
SpecBamf41 Posted May 30, 2012 Author Share Posted May 30, 2012 Fixed http://img.tapatalk.com/4b64260e-670c-01ed.jpg After a good thread clean I just put it back on with out welding. And sealed it up with some windsheild glue and sealed the first hole I drilled and missed by 2 inches http://img.tapatalk.com/4b64260e-6784-8dc5.jpg http://img.tapatalk.com/4b64260e-6799-12c6.jpg Sent from my Galaxy Tab using TapaTalk 2 BNR18g on 93oct Link to comment Share on other sites More sharing options...
