ripstik Posted October 9, 2014 Share Posted October 9, 2014 A shop I no longer go to installed my x-member and diff bushing and left two screws out when they put everything back together (at least that's my guess). When the next shop pointed it out I drove to Subaru and claimed warranty. I have no way to prove those bolts were ever there, Subaru could have forgot to install them. did they give you the bolts? Link to comment Share on other sites More sharing options...
acumenhokie Posted October 9, 2014 Author Share Posted October 9, 2014 did they give you the bolts? Yup but my local Subaru dealer knows me pretty well as a groupie. Link to comment Share on other sites More sharing options...
ripstik Posted October 9, 2014 Share Posted October 9, 2014 ^^i think my dealer freakin hates me. my car is always in for the same issues over and over, not to mention the fact that each time it goes in it goes in twice because they never have parts in stock. sometimes i feel like they are just giving me a car wash and pretending like they are doing the work. Link to comment Share on other sites More sharing options...
tdelker Posted October 11, 2014 Share Posted October 11, 2014 Had the sound on one pull, but not again. Car felt sluggish over the last few weeks, not really giving me that 'kick in the pants.' Started to wonder if I had a boost leak, found this thread, and sure enough, the side on the TB slipped right off without loosening the clamp, rubber gasket was sticking out, clearly leaking. Just to be clear, people say 'rip it off.' I wasn't quite sure what that meant. Really, it's a separate rubber gasket under the clamp that wraps round to the inside of the pipe The whole gasket just slips off, and you tighten the clamp down in the pipe directly. It seems like a good idea that keeps that pipe from cracking potentially, but it seems to be a weak link because it is hard to tighten the screw clamp and I think the guy at the factory decided not to do it. Link to comment Share on other sites More sharing options...
ripstik Posted October 14, 2014 Share Posted October 14, 2014 Had the sound on one pull, but not again. This happened with my car too but once i drove it around for a bit I'm assuming it warmed and softened a bit then the noise was back. Link to comment Share on other sites More sharing options...
MySubieII Posted May 11, 2017 Share Posted May 11, 2017 I did this DIY this week. Prior to replacing this hose I was pulling 14-15 psi boost w/ the fart sound... Drove my car for the first time today... 18+psi boost and no fart sound!! Easier than I thought it would be too Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
