Queue Posted May 14, 2012 Share Posted May 14, 2012 The rear window, on the drivers side (05 OB XT) suddenly quit operating - does not respond to either the drivers switch or the switch on the back door. Any thoughts on the root cause? Thanks Link to comment Share on other sites More sharing options...
car_cursed Posted May 14, 2012 Share Posted May 14, 2012 Doesn't sound like a switch as both going out at the same time is unlikely, could be a relay Link to comment Share on other sites More sharing options...
Queue Posted May 15, 2012 Author Share Posted May 15, 2012 Thanks Link to comment Share on other sites More sharing options...
atchipmunk Posted May 16, 2012 Share Posted May 16, 2012 Or a window motor. The driver's side window motor went out on my LGT before. Not to hard to replace either, but i'm also a professional automotive technician (BMW Level 1 Master Technician). You should pull the door panel for the affected door and test for power on the wires to the window motor when you activate the switch. If you have voltage to the motor when the switch is pushed, you got a bad motor. If not, it's either the switches or the relay or wiring somewhere upstream. Since BOTH switches don't work, my money would be either on the relay or motor. Hope this helps... Link to comment Share on other sites More sharing options...
Leviman Posted May 16, 2012 Share Posted May 16, 2012 It could be a power wire in the boot going from the body to the door. But as atchipmunk said, test for power at the motor. Link to comment Share on other sites More sharing options...
terrible001 Posted May 16, 2012 Share Posted May 16, 2012 second what atchipmunk said, start at the bad door and work your way up stream Link to comment Share on other sites More sharing options...
Queue Posted May 16, 2012 Author Share Posted May 16, 2012 Thanks everyone! I am a bit of a novice when it comes to this type of work...where is the relay located? I appreciate it. Link to comment Share on other sites More sharing options...
car_cursed Posted May 17, 2012 Share Posted May 17, 2012 check the motor in the door first Link to comment Share on other sites More sharing options...
MikeAldea Posted January 16, 2013 Share Posted January 16, 2013 Is there anyway to check the motor other than running a couple of wires directly from the battery to the motor? If the motor checks out good where would I find the relay for the, passenger side, rear window in an 05 LGT Wagon? I'd rather not pay a dealer to fix this if it is a simple job. I was very surprised that the window circuits are not fuse protected. Link to comment Share on other sites More sharing options...
robinlsb Posted January 16, 2013 Share Posted January 16, 2013 Try a reflash first. Really!!!!!2005's heal. I don't know why, but I had the same problem. The first reflash worked at first, then failed. The second cured it two years ago. Go figure:eek: "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
