SUBILGTFTW20052124 Posted May 5, 2012 Share Posted May 5, 2012 Just swapped in a new engine/ turbo about 3500 miles ago and up until now it has been running great. Today I just noticed that it has a complete loss of power....could it be my transmission?? It's an automatic and I'm not sure when the last ATF drain and fill was, But I am going to do one on Monday. Does anyone have any suggestions or concerns about what this loss of power and grinding sound is when I get into high Rpms? I am very worried, someone please help me out. Than you all, your help is much appreciated Link to comment Share on other sites More sharing options...
apexjapan Posted May 5, 2012 Share Posted May 5, 2012 First advice - don't drive it right now. Especially don't drive it at high rpm's. Check everything, especially engine oil, and seriously consider trucking it to a trusted mechanic. An A/T isn't going to be a source of power loss. Regards, Paul Hansen http://www.avoturboworld.com http://www.facebook.com/avoturboworld Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted May 5, 2012 Moderators Share Posted May 5, 2012 Check the TB hose connection at the intercooler. I just had an issue with that connection and it sounded like it was coming from the transmission. It made a noise like a duck (seriously) but after having seen it I can see how it might make a grinding type noise as well. Easy to check also, just remove engine cover and look. The general consensus for my issue was that it wasn't my trans (which I thought it was) since I'm not running at power levels that should lead to trans issues (stage 2 w/ trans cooler). Hope your issue is small and easy to fix! Also check all the vacuum lines under the intercooler if you don't see an issue with the TB connection. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted May 5, 2012 Share Posted May 5, 2012 Check engine Light? What type of tune?? If you have a cobb whats the a/f look like? Need more info Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted May 5, 2012 Moderators Share Posted May 5, 2012 This is a video I took of my issue, in case it helps! http://s934.photobucket.com/albums/ad187/BarManBean/?action=view¤t=IMG_0292.mp4 "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
xt2005bonbon Posted May 5, 2012 Share Posted May 5, 2012 This is a video I took of my issue, in case it helps! http://s934.photobucket.com/albums/ad187/BarManBean/?action=view¤t=IMG_0292.mp4 That was a weird and somewhat funny sound actually. Thanks for sharing. I'll remember your advice in case this happens to me. As for the OP, I am with apexjapan: don't drive the car and get it checked. In the mean time, you could also record a video (with high quality soundtrack). This will be much easier for us to help you troubleshoot. Link to comment Share on other sites More sharing options...
SUBILGTFTW20052124 Posted May 5, 2012 Author Share Posted May 5, 2012 I think it might be my turbo going out...? But what is the grinding sound at high rpms when it is about to shift?? Link to comment Share on other sites More sharing options...
