rdp2n Posted May 1, 2012 Share Posted May 1, 2012 I am looking at the A1 Cardone Legacy (1995) axles at autopartswarehouse.com. The remanufactured cost between $50 and $60, while the new ones cost $120 - $130. On a 17 year old car, would I have any reason to get new axles -- or will the remans do just fine? Thanks, Rob Link to comment Share on other sites More sharing options...
Byll Posted May 1, 2012 Share Posted May 1, 2012 For what it is worth Rob, my wife tore a couple of boots on the right axle of her beloved 95 L wagon, a few months ago. I put on a remanufactured axle. No issues. All is well. Please know that our old Subarus go a heck of a lot longer than 17 years... Best. Byll Link to comment Share on other sites More sharing options...
dspl1236 Posted May 1, 2012 Share Posted May 1, 2012 I was at autozone yesterday and randomly inquired about axels. they have new china ones for like 55$ no core and reman ones for 65$ plus $45 core Link to comment Share on other sites More sharing options...
94legacy22 Posted May 1, 2012 Share Posted May 1, 2012 orleans auto neer me has rebuilt $49 ones with 10 dollar core. lifetime warrantee. no brainer there Link to comment Share on other sites More sharing options...
stevenva Posted May 3, 2012 Share Posted May 3, 2012 Go with the reman. The rubber accordian boot will fail before the CV joint has issues, regardless weather it's reman or new. RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
JJay03 Posted May 3, 2012 Share Posted May 3, 2012 Lots of people have issues with the cheap axles causing vibration. I got new EMPI axles from rock auto and they did cause a bit of vibration but it seems to be going away. If I was to get axles again though ide prob go with Raxles or MWE. Link to comment Share on other sites More sharing options...
TexasLegacy2.5GT Posted May 3, 2012 Share Posted May 3, 2012 When a axle is bent when would you feel the vibration? Link to comment Share on other sites More sharing options...
JJay03 Posted May 4, 2012 Share Posted May 4, 2012 When a axle is bent when would you feel the vibration? Mine is not from being bent I think it is from them being too short or the joints are too stiff. It vibrates more in gear stopped and when under load. Link to comment Share on other sites More sharing options...
TexasLegacy2.5GT Posted May 4, 2012 Share Posted May 4, 2012 Mine is not from being bent I think it is from them being too short or the joints are too stiff. It vibrates more in gear stopped and when under load. ^^^was that vibration evident when accelerating in gear or braking? Link to comment Share on other sites More sharing options...
JJay03 Posted May 4, 2012 Share Posted May 4, 2012 ^^^was that vibration evident when accelerating in gear or braking? Just accel in gear not braking Link to comment Share on other sites More sharing options...
TexasLegacy2.5GT Posted May 4, 2012 Share Posted May 4, 2012 If that's true I don't have a bent axle....maybe my bushings in the front end are done? Link to comment Share on other sites More sharing options...
Baddog Posted May 4, 2012 Share Posted May 4, 2012 If your rear brakes are shot ^ replace those first regardless. Then go from there Link to comment Share on other sites More sharing options...
Stang70Fastback Posted May 4, 2012 Share Posted May 4, 2012 I have aftermarket axles on my car and indeed it suffers from that idle vibration. If I had known how much of a nuisance it would be, I would have forked over the extra cash... Link to comment Share on other sites More sharing options...
JJay03 Posted May 4, 2012 Share Posted May 4, 2012 I have aftermarket axles on my car and indeed it suffers from that idle vibration. If I had known how much of a nuisance it would be, I would have forked over the extra cash... How many miles have yours been on? I still might change mine out. Link to comment Share on other sites More sharing options...
Stang70Fastback Posted May 4, 2012 Share Posted May 4, 2012 Quite a while. Probably at least 100k on these axles. The shuddering is annoying... Link to comment Share on other sites More sharing options...
johnegg Posted May 4, 2012 Share Posted May 4, 2012 i could have sworn i already posted this, i must be getting old. used subaru axles with new boots are a better choice than parts store remans or new. subaru axles are a very very very high quality and as long as they are not making noise or clicking, new boots will put them back on the road for a very long time. rebooting is messy and may cost as much as replacing the axle, but if you have subaru axles, (green inner cup) on the car, it is a much better solution than a cheap replacement. Link to comment Share on other sites More sharing options...
JJay03 Posted May 4, 2012 Share Posted May 4, 2012 Quite a while. Probably at least 100k on these axles. The shuddering is annoying... Ugh guess ill send my originals in to raxles after a bit. Link to comment Share on other sites More sharing options...
rdp2n Posted May 7, 2012 Author Share Posted May 7, 2012 All good food for thought. I have removed both axles from the car -- very hefty, heavy all-black affairs -- only one has a torn boot and may explain some vibration at higher speeds on the passenger front side. I went to autozone and switched them both out for DuraLast remans -- then read horror stories about them on the web " .. to be avoided at all costs .. ", and reversed the transaction the next day. Indeed, the DuraLast remans look and feel like matchsticks compared to those on the car (not sure whether they're originals may well not be). Then I went to NAPA and theirs look much more substantial than the DuraLast and have much better reports on the web. Having read johnegg's comments I'm inclined to put the one with intact boots back on the car and swap the other for the NAPA reman. It's around $50 if you render your existing axle in exchange. Link to comment Share on other sites More sharing options...
