Screechers Posted November 9, 2012 Share Posted November 9, 2012 Check your header to uppipe bolts, I've had those wiggle loose Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted November 9, 2012 Author Mega Users Share Posted November 9, 2012 Check your header to uppipe bolts, I've had those wiggle loose the FMIC solved it "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
Screechers Posted November 14, 2012 Share Posted November 14, 2012 What type of gaskets did you use? If you used the cheap ones with a filler they blow out really easy. I always use exhaust gaskets from subaru Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted November 14, 2012 Author Mega Users Share Posted November 14, 2012 What type of gaskets did you use? If you used the cheap ones with a filler they blow out really easy. I always use exhaust gaskets from subaru ok. but im still not sure what you mean, exhaust gaskets? mine are OEM gaskets. my exhaust doesn't leak anywhere. It had nothing to do with the drone. the fmic did. "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted November 14, 2012 Author Mega Users Share Posted November 14, 2012 you mean the turbo flange and the bpv flange? "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
Screechers Posted November 15, 2012 Share Posted November 15, 2012 yeah, I had my old BPV leaking air and it was the worst noise ever Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted November 15, 2012 Author Mega Users Share Posted November 15, 2012 I made paper gaskets. They were not the root of the problem "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
stuck686 Posted March 29, 2013 Share Posted March 29, 2013 in relevance to this thread, I have a dp/midpipe leak and i bought the grimmspeed adapter 3' to 2.5. Is this hard to put in? how long should it take a shop to do it? Also is it possible to lose a couple Psi of boost with a leak that far from the turbo? Link to comment Share on other sites More sharing options...
spec.B Dream Posted April 1, 2013 Share Posted April 1, 2013 I wouldn't expect a post-turbo exhaust leak to have much impact on boost at all. A shop should be able to install this in a matter of minutes. You could do it in under an hour if you have a jack, stands, and a couple wrenches (12mm and either 14 or 10mm). Link to comment Share on other sites More sharing options...
fahr_side Posted April 2, 2013 Share Posted April 2, 2013 in relevance to this thread, I have a dp/midpipe leak and i bought the grimmspeed adapter 3' to 2.5. Is this hard to put in? how long should it take a shop to do it? Also is it possible to lose a couple Psi of boost with a leak that far from the turbo? Leaks downstream from the turbo are more likely to increase boost, especially on cars with larger turbos and / or more restrictive exhausts. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
