4RunnerKid Posted June 27, 2012 Share Posted June 27, 2012 perfect, thanks guys Link to comment Share on other sites More sharing options...
dan04103 Posted August 18, 2012 Share Posted August 18, 2012 Did this upgrade to my 3.0 a few days ago with oem front rear calipers, stoptech blanks, and stoptech pads. In a word... nice! Much much better. Love having rear vented too. This upgrade might be my favorite mod to date. Even fills out the 17s nicely. Highly recommended for outback owners. I really shake my head at some of the shortcuts Subaru took with the outback. Shameful Subaru shameful. Sent from my Transformer Prime TF201 using Tapatalk 2 Link to comment Share on other sites More sharing options...
tLewis7 Posted October 15, 2014 Share Posted October 15, 2014 ~ Just to be clear. I do NOT need to change the OBXT mounting brackets to the LGT mounting brackets? ~ Just bolt up the LGT calipers to the OBXT mounts, green pad or turn the used LGT rotors, upgrade pads/lines, bleed and bed in? Thanks Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted October 15, 2014 Moderators Share Posted October 15, 2014 yes. LGT calipers will bolt right up. Edit: I was assuming a set of take-offs that would include stock LGT brackets. If JUST the calipers, they may not mount up. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Rhitter Posted October 15, 2014 Share Posted October 15, 2014 yes. LGT calipers will bolt right up. I guess I should check, but I thought the mounting brackets (at least for the front) were difference sizes. The mounting bracket and caliper bolt right up. but I think the bracket is different. But I want to make sure we are talking about the same thing. The bracket is the loose thing right? http://i.imgur.com/xIKuwed.jpg My OBXT build Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted October 15, 2014 Moderators Share Posted October 15, 2014 Sorry, I may have misread the question and you might be right. If ONLY replacing the calipers I'm not sure. I'm just used to seeing calipers/brackets sold as a set. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Rhitter Posted October 15, 2014 Share Posted October 15, 2014 I think the front bracket needs to be changed as it's sized for a smaller rotor and I think the rear bracket needs to be changed because it's sized for a thinner rotor. I could be wrong though. I remember reading you needed the LGT mounting brackets and calipers but I never verified it when I did the installation. I just changed everything out. My OBXT build Link to comment Share on other sites More sharing options...
tLewis7 Posted October 15, 2014 Share Posted October 15, 2014 I think the front bracket needs to be changed as it's sized for a smaller rotor and I think the rear bracket needs to be changed because it's sized for a thinner rotor. I could be wrong though. I remember reading you needed the LGT mounting brackets and calipers but I never verified it when I did the installation. I just changed everything out. Where did you read about this upgrade. My search did not lead me to a post that seemed definitive. Thanks. Link to comment Share on other sites More sharing options...
Rhitter Posted October 15, 2014 Share Posted October 15, 2014 Oh I pieced together information from as many threads as I could find from Subaruoutback.org and Legactgt.com. I just searched with Google with the name of the forum and whatever I was looking for. My OBXT build Link to comment Share on other sites More sharing options...
InTheBay Posted October 17, 2014 Share Posted October 17, 2014 How much of a difference is there between the XT brakes and the LGT brakes? Here's a couple pics to illustrate, I'm doing the front swap at this very moment. http://photos-a.ak.instagram.com/hphotos-ak-xaf1/914757_156911064479280_70712701_n.jpg http://photos-b.ak.instagram.com/hphotos-ak-xaf1/10723903_1477727262487481_544024886_n.jpg You'll need the caliper brackets, caliper, pads, and rotors for the swap. That's it. Link to comment Share on other sites More sharing options...
ssbtech Posted October 17, 2014 Share Posted October 17, 2014 Let me know what sort of a difference you notice Link to comment Share on other sites More sharing options...
InTheBay Posted October 17, 2014 Share Posted October 17, 2014 I'm doing a grimmspeed master cylinder brace at the same time, so my views will be slightly skewed Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Rhitter Posted October 17, 2014 Share Posted October 17, 2014 Ssbtech it's a huge difference. I love it. My OBXT build Link to comment Share on other sites More sharing options...
tLewis7 Posted October 18, 2014 Share Posted October 18, 2014 Let me know what sort of a difference you notice The difference is very significant. Link to comment Share on other sites More sharing options...
tLewis7 Posted October 18, 2014 Share Posted October 18, 2014 I'm doing a grimmspeed master cylinder brace at the same time, so my views will be slightly skewed Sent from my iPhone using Tapatalk Nice comparo! Will you change out too stainless steel lines? I (and others) would consider this an important piece to any brake upgrade. Link to comment Share on other sites More sharing options...
InTheBay Posted October 22, 2014 Share Posted October 22, 2014 I am not, because I cannot locate OBXT specific braided lines, and don't want to purchase lines and have them end up being too short. I am however, measuring them, and will do braided lines DIY when I get some time. Got the brake rotors and caliper brackets mounted last night, see my build thread post here: http://forums.nasioc.com/forums/showpost.php?p=42677370&postcount=21 Link to comment Share on other sites More sharing options...
dukeneverwinter Posted October 22, 2014 Share Posted October 22, 2014 I wish these would fit under forester 16" wheels!! Link to comment Share on other sites More sharing options...
Rhitter Posted October 22, 2014 Share Posted October 22, 2014 I am not, because I cannot locate OBXT specific braided lines, and don't want to purchase lines and have them end up being too short. I am however, measuring them, and will do braided lines DIY when I get some time. Got the brake rotors and caliper brackets mounted last night, see my build thread post here: http://forums.nasioc.com/forums/showpost.php?p=42677370&postcount=21 http://www.infamousperformance.net/servlet/the-2211/Techna-dsh-Fit-Stainless-Steel-Brake/Detail Here you go. This is what I have used. No issues so far with them. Had them on for 4 months and a track day. Here is what they look like outside of the box http://i.imgur.com/pXIA2s8.jpg My OBXT build Link to comment Share on other sites More sharing options...
Nightmaresmk Posted October 23, 2014 Share Posted October 23, 2014 Technafit makes outback specific lines. KNSbrakes sells them. Link to comment Share on other sites More sharing options...
