IceBerge12 Posted March 29, 2012 Share Posted March 29, 2012 Looking to put a new intake on the GT, was wondering what the community feel's is better? SPT intake or K&N Typhoon intake? Link to comment Share on other sites More sharing options...
goneskiian Posted March 29, 2012 Share Posted March 29, 2012 KS-Tech seems to be a popular choice. SPT not so much. Link to comment Share on other sites More sharing options...
scootyc Posted March 29, 2012 Share Posted March 29, 2012 Cobb? Link to comment Share on other sites More sharing options...
.Catalyst. Posted March 29, 2012 Share Posted March 29, 2012 Stay stock - until you get well into Stage 3 your mod money is best spent elsewhere. This is well documented here. Also avoid the SPT at all cost - it's also been documented to be a poor design. If you must get one both the AVO and Cobb look quality (tune required), and the KSTech mentioned above is a good option if you have outgrown your MAF scaling capabilities with a serious build and need a larger one. My spec.B [#163] Project Thread with Pictures Get CryoTuned! Link to comment Share on other sites More sharing options...
Drift Motion Posted March 29, 2012 Share Posted March 29, 2012 I want a K&N but I got the AEM for dirt cheap... Link to comment Share on other sites More sharing options...
Nrw Posted March 29, 2012 Share Posted March 29, 2012 I'm running a K&N. I like it. Hell of a lot better than the Blitz setup that was in my car. Link to comment Share on other sites More sharing options...
charlie_sheen Posted March 29, 2012 Share Posted March 29, 2012 they wont do anything but make the car wooshier...yeah thats a word. some people keep the stock one until they reach 300+ Link to comment Share on other sites More sharing options...
iNVAR Posted March 29, 2012 Share Posted March 29, 2012 stay stock - until you get well into stage 3 your mod money is best spent elsewhere. This is well documented here. Also avoid the spt at all cost - it's also been documented to be a poor design. +1 Link to comment Share on other sites More sharing options...
bmx045 Posted March 29, 2012 Share Posted March 29, 2012 FWIW my stock intake is fine with my 20g/td06 turbo. as the tuner increased the boost little by little the maf still detected more and more grams/sec of air so the intake and stock filter was keeping up with the demand. i sit right now at 21psi with stock intake Link to comment Share on other sites More sharing options...
robitrice Posted March 29, 2012 Share Posted March 29, 2012 anything but SPT....its nothing more than engine bling and sound until you really have to increase the air flow for a bigger power build. Link to comment Share on other sites More sharing options...
IceBerge12 Posted March 30, 2012 Author Share Posted March 30, 2012 Hmm, interesting, thanks for the replies, new to these cars, so dont know too much. Some research is still required! Link to comment Share on other sites More sharing options...
scootyc Posted March 30, 2012 Share Posted March 30, 2012 Getting an intake was my first mistake and it wasn't my last. You wont need one for at while most likely. Link to comment Share on other sites More sharing options...
scoobydoobie Posted March 30, 2012 Share Posted March 30, 2012 Of those two, K&N for sure. I'm happy with my AEM. Link to comment Share on other sites More sharing options...
DeltaNu1142 Posted March 31, 2012 Share Posted March 31, 2012 Stay stock - until you get well into Stage 3 your mod money is best spent elsewhere. This is well documented here. Also avoid the SPT at all cost - it's also been documented to be a poor design. I have a feeling this forum is going to save & cost me a lot of money at the same time... Can you provide some links to the bold stuff? I search religiously, but it's difficult to find a thread by searching "best bang-for-your-buck power mods". Tits mcgee Link to comment Share on other sites More sharing options...
bmx045 Posted March 31, 2012 Share Posted March 31, 2012 links aren't needed. experience is proof. experience says that the stock intake supplies enough flow for up to a 20g sized turbo. if you do decided to get an intake, the only thing you will gain is a whoosh sound and a horrific afr while full throttle (aka bad) unless you're open source tuned for the increased flow neeeext Link to comment Share on other sites More sharing options...
DeltaNu1142 Posted April 1, 2012 Share Posted April 1, 2012 links aren't needed. experience is proof. experience says that the stock intake supplies enough flow for up to a 20g sized turbo. if you do decided to get an intake, the only thing you will gain is a whoosh sound and a horrific afr while full throttle (aka bad) unless you're open source tuned for the increased flow...neeeext Agreed. However, the question still stands; the link request was for suggestions on the "elsewheres" on which to spend the money. Tits mcgee Link to comment Share on other sites More sharing options...
IceBerge12 Posted April 1, 2012 Author Share Posted April 1, 2012 Sounds like the best place to start would be a up and/or down pipe, then tune it to Stage 2? I am looking for a little more turbo noise but I've also seen that can come from opening up the exhaust with the pipes. Link to comment Share on other sites More sharing options...
goneskiian Posted April 2, 2012 Share Posted April 2, 2012 Sounds like the best place to start would be a up and/or down pipe, then tune it to Stage 2? I am looking for a little more turbo noise but I've also seen that can come from opening up the exhaust with the pipes. You got it. You'll get more turbo noise with both a catless UP and a high flow catted DP. If you want more turbo noise, get an AVO or K&N panel filter. Cheers! Link to comment Share on other sites More sharing options...
robitrice Posted April 2, 2012 Share Posted April 2, 2012 You could also always gather all your parts at once (intake, dp, up etc) put it all on at once and get it tuned ONCE and save time and money. Link to comment Share on other sites More sharing options...
